Question about Ricoh Aficio 250 Copier
Hello everyone. I just replaced the polygon mirror on my Savin 2515 and the copier is again operational, however I noticed that the output is not as sharp and crisp as it was before the failure. I did not touch any of the mirror's surfaces during replacement (although I do not remember if I left any fingerprints on any other reflective surfaces.) Could it be that the new unit requires some kind of alignment? (I noticed that there were tamper detection marks on the screws when I removed the old unit; a sign that replacement requires something more that only a technician would know?) Any feedback would be much appreciated.
  • Ricoh Expert
  • 287 Answers
Hi chro,
Send me an e-mail and I will send you the whole manual. I will give you my email address now,but it will look funny because "fixya" has an email filter to make sure we can't do what we are gonna do. jdh6211#####comcast#####net. If you can figure it out you win. I'll be watching. But you DO indeed have some fine tuning to do. Service mode and all that.
Posted on Mar 19, 2011
  • chrohnoh Mar 22, 2011
    Hey Spinal; just in case it got lost somewhere in a digital abyss, did you get the message that I sent to your comcast account?
How do i locate the polygon motor for sharp arm160
Hello ARAM,
The operation manual can be viewed here: http://www.gfive.net/pdf/manuals/AR-M160-Manual.pdf
The part you requested can be ordered here; Sharp ARM160 Polygon Mirror Motor Genuine J0349
Good Luck!
Rich Lilja
Mar 04, 2015 | Sharp Office Equipment & Supplies
Drum Replacement
Its more involved than you think, you should change the drum blade and charge roll also, developer need replacement at 60K also (in the same unit) all fixed for about 350 from your service guy
Apr 11, 2014 | Savin 2515 Drum Only Genuine
My sharp Digital Photo copier AR-5020 have display L6 give the solution of the problem & what is the rate of LC polygonal mirror motor
check the POLYGON motor operation with SIM 61 - 1.
Check the polygon motors if it is rotating if not while it is receiving PD replace it, if this does not w2ork the problem is in the MCU power supply.
Jul 12, 2011 | Sharp AR208D Copier
Sc335 ricoh 2045 copier
  • Code: 335
  • Description:Polygonal Mirror Motor Error 1: ON Timeout
    The XSCRDY signal is not issued (LOW: Active) within 25 s after the polygonal mirror motor switches on.
  • Causes:• I/F harness of the polygonal mirror motor disconnected or defective. • Polygonal mirror motor or polygonal mirror motor driver defective. • Polygonal mirror motor drive pulse is not output incorrectly. • GABIC cannot monitor XSCRDY signal.
Apr 12, 2011 | Office Equipment & Supplies
Aparece el error SC 320 que puedo hacer??
320
Symptom
Polygon motor error
The polygon motor does not reach its operating speed within 10 seconds after the polygon motor on signal, or the lock signal is not detected for more than 200 ms continuously during operation.
Possible Cause
• Polygon mirror motor defective
• Poor connection between the polygon mirror motor driver and the SBCU board
• SBCU board defective
Nov 13, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
I have code SC320 of my copier NASHUA D425
SC320: Polygon motor error
-Definition- [B]
more than 40 ms continuously during operation.
- Possible causes -
· Polygon motor defective
· Poor connection of the interface harness which connects the polygon
motor driver and the IOCSS board
· IOCSS board defective
u need new polygon mirror
Nov 07, 2010 | Ricoh Aficio 250 Copier
Sharp AR-M205 - Error Code L6
L6 10 Content Polygon motor lock detected Detail It was judged that there is no output of polygon motor lock signal of LSU. The lock signal was checked at about 10-second intervals after the polygon motor started rotating. As result, it was judged that the polygon motor failed to operate normally. Cause Disconnected connecter to LSU or detached harness inside LSU or broken wire. Polygon motor defective Check and remedy Check polygon motor operation with SIM61-1. Check harness and connector for connection. Replace LSU if needed
Dec 14, 2009 | Sharp AR-M205 Copier
Error 320
Polygonal mirror motor error.The polygon mirror motor does not reach the operating speed within 10 sec or the polygon motor remains out of the operating speed.Possible cause:defective polygon mirror motor,loose connection between the polygonal mirror motor and the BICU,defective cable between the BICU and the polygonal mirror motor or defective BICU.Turning the main power switch OFF and ON resets the SC codes if the error is caused by incorrect sensor detection.
Nov 22, 2009 | Ricoh Office Equipment & Supplies
Error SC320 appear on screen..
Polygonal mirror motor error change...
reach operating speed within 10
seconds after the motor ON signal is
sent, or does not turn on within one of
the 200 ms check intervals during
operation.
• Poor connection between the polygonal mirror motor driver and the BiCU board
• Damaged cable between BiCU/IOB and polygonal mirror motor driver
• BiCU board defective
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Funtion problem
Sc 322 means there is a problem with the laser unit,and 99% of the time it is the polygon mirror motor within the laser unit. You have 2 options.Replace the entire laser unit which is in a neat little black box and is relatively easy to replace. Better yet,merely replace the mirror motor which is enclosed within the laser unit. But one or the other must be replaced as there is no adjust/oil/clean/tinker/fudge to be done. I wish I had better news but really the news aint bad and the advice is free so if you have to get "copier dude" to come out he/she wont try to hose you !!! Well they might try,but YOU know better. :-) hope this helps,take care. .......spinal.......
Mar 25, 2008 | Office Equipment & Supplies
Ricoh Aficio 250 Copier Logo
128 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
