Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Monitor non functional
I have a black macbook 13" /2.4Ghz, running OS X 10.5 with DVI-D connection  to Viewsonic VP2130b monitor. Screen remains blank. Message "DVI-D no signal." Any suggestions?
  • Anonymous Mar 30, 2014
    After upgrade to iOS 10 there are problems with DVI signal to HP2159m monitor.
    New Friend:
  • 28 Answers
Am I correct in understanding that your MacBook is operating properly, but when you attach your external monitor it doesn't show anything?
I often connect my black MacBook 2GHz to my flat screen's VGA port. Sometime the screen doesn't respond for one reason or another. The fastest solution is typically to mirror the screens then return to normal. When that doesn't work, it's usually enough to restart the MacBook while it's still plugged in to the external monitor. If neither of those work, try connecting to a different monitor or finally try replacing the connector.
Unfortunately those connectors don't have the best life spans. (See Apple's customer reviews on DVI connectors.)
iKnow Apple Dan (919) 280-3101
Posted on Aug 16, 2008
Screen flickering on windows 7 boot
This is more than likely an issue with the monitors themselves. Does this happen on the main monitor is you move the secondary cable over to it? What kind of monitors are you using, how old are they, and do you know the refresh rates on them?
Nov 21, 2013 | Nvidia Computers & Internet
My screen shows start up screens but while my computer loads, i cannot view my window screen... it became black but however the power button is still green
Welcome to FixYa!
here is the things you should do .
1. download a drivers click here
2. Restart the system in safe mode and install drivers (these are up-to date)
3. Check the LCD have you plugged the DVI cable or simple VGA cable ..
3A. And if are you using any Graphic cards remove the DVI cable just use motherboard's own VGA
outlet and connect it to the LCD , if it works then you might have the problem with graphic card,.
4. Check either your LCD is displayed on 1 or 2 check the button near power button on LCD.
If it does or doesn't solve your problem do comment here ill know.
Best Regards
Apr 13, 2011 | ViewSonic Pro VP2130b 21.3" LCD Monitor
Had a look at a ViewSonic VP2130 with a friend of mine who used to fix TVs. He found a bad cap and has replaced it, however the LCD will still not function. We've looked at all the caps in the power...
its the J2 noise reduction. my **** did the same thing i changed it and now my **** works if u still have problem just post it here and ill go from there
Feb 08, 2010 | ViewSonic Pro VP2130b 21.3" LCD Monitor
Blank Screen
Common problem in monitors are bad caps in the power supply, that is the first place to check, look for bad caps with bulging top/bottom, see example of failed VIEWSONIC monitors due to bad caps here (worst case will be bad lamps): http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can help you further.
Feb 06, 2010 | ViewSonic VG2230WM LCD Monitor
Viewsonic VG2230wm 22 Blank screen
Look for bad caps in the power supply first, see example of failed VIEWSONIC monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you furhter.
Feb 06, 2010 | Relisys RLT1720 17" LCD Monitor
Won't power up
1.This could be the transformer on the power supply board that needs replacement along with a bad rectifier diode in the full bridge mode.
2.check diodes in the power supply should read .535 with the digital meter leads ( red ) on the anode and the black lead on the cathode. this indicate good is lower then the diode needs replacement.
check the internet on how to test diodes in a circuit. If you are savvy enough you will successfully repair this unit.
Jan 29, 2010 | ViewSonic Pro VP2130b 21.3" LCD Monitor
My monitor suddenly went black and will not respond...
try to boot in safe mode....if it starts in safemode.. then uninstall vga driver......do reply
Oct 01, 2009 | ViewSonic Pro VP2130b 21.3" LCD Monitor
Need Power Supply for VP2130 Viewsonic Monitor
try ebay, i've found a few for Samsung monitors there.
Aug 03, 2009 | ViewSonic Pro VP2130b 21.3" LCD Monitor
Viewsonic VP2130b monitor no post black screen
Here is a suggestion:
By looking at the power board you should see the light, and where it is connected to, so diagnose the circut from that point foreward eliminating any potential of damging the board. try any cables or ribbons.
Jun 20, 2009 | ViewSonic Pro VP2130b 21.3" LCD Monitor
VG910s not recognizing DVI input
Graphics card need setting to DVI out put Check your manual
May 16, 2007 | ViewSonic VG900 19" Flat Panel LCD Monitor
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
254 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
