Question about DISH Network IR Remote Control
We're having problems with our remote. It will work fine for a while, and then stop working, but when we put it up close to the box, it works again. We don't want to have to get up every time to change the channel though.
  • 3,018 Answers
First how old are the batteries? Old batteries work off and on and often only at closer distances. You might want to try a fresh set of batteries. Also make sure the sensor on the remote and box are clean and free of oils and dust. Spray a bit of Windex on a cloth and clean them both.
Posted on Mar 18, 2011
I have a Humax PVR 9300T with a RT-531B remote. Suddenly the remote has stopped working although the batteries in it are fine. What can I do to fix this?
from "sceptical Glenn". I had the same problem & saw solutions so thought why not!!!.unplugged box, removed batteries,waited 10 mins.Held down "ON" button for a good minuet.Pressed all buttons from top left to right all the way down"like reading a book" even the ones under the slidey bit.Replaced batteries pressed buttons again in the same sequence,plugged the box back in pointed remote at box held "ON" button down for another minuet, then crossed my fingers.Pressed a button and it worked,"Wheay" success it worked it worked.Never again will anybody call me sceptical Glenn again.Thanks for the solution I am now a happy remote control using person once again, never having to leave my settee again only for a beer,or the loo or food,but that can also be rectified as I sit near the window...the pizza man can pass it through to me.
Dec 14, 2011 | Televison & Video
I would like iform you my car have some problems(land cruiser vxr)due to remotelock not working door swich manualy lock unlock its fine when i door close after remote not working propperlly i check...
3 things remote box bad or (they also have relays ) small square box's near fuse box, may need replaced or door door actuator is bad. u will have to test all wires with a voltmeter to see if its gettin power from fuse box to remote box, remote box to relays and relays to door actuator.
Mar 31, 2011 | Toyota Land Cruiser Cars & Trucks
Direct TV RC64 Remote ''Up'' button stopped working.
Sounds like the box. try to reset the box and hopefully it will solve the problem.
Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
Raynor garage opener-remote only works close up sometimes
check to seee if the little wire that hangs out of the operator is hanging out. This wire is the ant. if this is not the problem replace the 12volt battery you can buy them anywhere. make sure you didn't cut off the ant. wire (I have seen customers cut thios wire thinking its an extra and not needed or place the wire inside the box very little signal that way have to be very close)
Jun 05, 2009 | Building Materials
Remote will not open or close door when temperature is cold.
if this is an outside remote the best you could do is maybe put someting to insulate the remote if it is in your car don't leave it on the visor put it in the glove box or maybe the center console it is obvious that expansion/contraction physics are playing a part
Apr 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Unknown disk type
Press 'Disc Menu' and wait for 'no disc' to appear on the screen. Eject the tray by pressing the 'open / close' button on front of the recorder. Enter the following numbers very slowly on the remote control ' 0086000 ' Press ' OK ' button on your remote control. Close the tray by pressing ' open / close ' button on the front of the recorder. You can check this has worked by pressing ' 0009 OK ' on your remote after the tray has closed. A display will pop up on screen showing the Region as 0. This means you should be able to play discs from all Regions. If this doesn't work the first time! try again! Hope this helps!!
Jan 24, 2009 | Philips DVDR3380/05 DVD Recorder
Sony RM-ASP001 for 400 disk changer stopped working
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Dec 23, 2008 | Sony RM-ASP001 Remote Control
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
Remote Problems
Put new batteries in and try again. Sometimes the IR sender may also not be working properly due to a loose connection.
I would also suggest to open the remote and clean the contacts using alcohol. Rub the contacts on the key pad and remote gently.
Hope this works.
Feb 26, 2008 | Toshiba 36A61 36" TV
Hitachi tv
I have the same problem. I got mine from a friend and my comcast universal remote does not work with it at all. For some reason it does not acknowlege it.
Oct 22, 2007 | Televison & Video
DISH Network IR Remote Control Logo
44 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
