Silva Multi-Navigator Handheld GPS Receiver Logo
Posted on Apr 02, 2017
Dear Expert. I loaded rechareable batteries into my Silva Multi Navigator and the message appeared stating; DEBUG. This was followed by all the screen messages being highlighted. I did manage to start the unit next day up but when I turned it off, it will not start again. I can press the compass screen and the compass works OK. Is this unit repairable, is there a reset button. Is there anyone in Melbourne Australia that can repair this unit - MACSON, the original distributor do not appear to exist anymore. HELP!! I do not want to dispose of this GPS unless the unit is totally irrepaiable. Any suggestion please. Regards Paul Melbourne
Debug message on far side of Screen
Firmware corrupted. Contact the authorized service center.
Gopakumar Gopalan Google
2answers
My 2005 lincoln navigator air suspension doesnt want to work how do i make it lift up?
my 2005 lincoln navigator air suspension doesnt want to work how do i make it lift up?
What does debug mean , it stops me from doing anything .
Just click no. This message is intended for the people that created the application.
May 07, 2010 • Yahoo Mail
DST Short Status Test Fail Error Code 1000 0146
DST (Drive Self Test) failed. this simply means that the drive is no longer stable. If you are unable to boot to windows or safe mode and this is the error you get you might need to do a low level format if you still want to use it or do a debug script then repartition and re-format the drive.
The Low-level partition - will reinitialize your drive to the factory settings.
Debug Script - removes DOS and non-DOS partitions on the hard drive. It also allows you to convert a drive from an incompatible partition structure to one that will work with FDISK.EXE such as, converting Linux partitions to MS-DOS partitions.
For you to use the Low-level format and to completely wipe out HDD data. Use the format software from http://www.killdisk.com, download the CD ISO image , burn to CD, ad boot from CD , the rest can be found in the menu.
In using the debug script use this :
Insert the boot diskette that contains the Debug command into the respective drive.
Restart the computer.
A black screen with Microsoft Windows® 95 Startup Menu will appear. Press the <5> key on the keyboard followed by the <Enter> key. The boot process will conclude with an A:\> prompt, followed by a blinking underline (cursor).
From the A:\> prompt, type the following commands and press the <Enter> key after each command:
NOTICE: Performing the following will remove all data from your hard disk drive.
NOTE: Type the bolded text only (the debug prompt is a dash). You will receive an error if you type anything other than the bold text. The non-bolded text represents the system response that will appear after typing each command and press the <Enter> key.
debug
-F 200 L1000 0
-A CS:100
xxxx:0100 MOV AX,301
xxxx:0103 MOV BX,200
xxxx:0106 MOV CX,1
xxxx:0109 MOV DX,80
NOTE: Type 80 for the Main hard drive - HD 0, or type 81 for the Second hard drive - HD 1.
xxxx:010C INT 13
xxxx:010E INT 20
xxxx:0110 (Leave this line blank and press the <Enter> key)
-G
The message, Program terminated normally, appears. Turn off the computer by pressing the power button.
On the next startup the hard drive must be partitioned and formatted.
Hope this helps to save your drive.
1helpful
Documents will not feed from the ADF
Is there a more permanent fix in the meantime? I'm just tired of fiddling each time that I use the ADF
Error message request to load paper when paper is loaded. Appears that it doesn't detect paper or can't pick it up.
I recommend you to follow the instructions given in HP web-site only to ensure the proper functionality of your product.
Please Click Here and follow the instructions to check the functionality.
If problem still persists Click here and follow the instructions to clean paper rollers using Cleaning kit.
DeBug appears whenever
what IE are you using?
the debug will appear when you using IE6. the reason is that most of th web site have activex. IE6 can't handle it. you need to install IE7 sp1.
Lost manual
Hi wnysoccerdad,
It appears that the manual for the Silva Outdoor Computer can be found on the manufacturer's website at this link.
Best Regards,
Ken
"Go Ahead. Use Us."
24helpful
4answers
QUEST SQL Navigator 3.2 with Oracle 10g Fails
I followed the advice given above and copied the ORACLE_HOME/bin/ociw32.dll to ora73.dll in the same directory. copy ociw32.dll ora73.dll
And the software worked immediately.
Top Silva GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Silva GPS Expert? Answer questions, earn points and help others
