Question about Kenmore Kitchen Ranges
I have a Kenmore 790.94479801 electric range. While using the Bake function, I noticed that the broiler element was on and the oven had gotten very hot. I hit the Stop button and noticed a small puff of smoke that appeared to come from behind the display. All functions work, including the clock, but the broiler always comes on when Bake is selected. Could this be a simple preheat issue or is it the controller?
  • Kenmore Master
  • 2,699 Answers
When you bake the broil element also comes on with the bake element for even cooking,if you or a friend has a newer oven that's digital and you look at it on some of them it lights up showing you when the broil element comes on and when the bake element comes on and you'll see that the broil also works when baking,most likely you cooked one of the relays on the clock assy. and will have to change out the whole assy.even though the clock is working it's connected to a computer board that runs the machine,if you remove the back panel with the stove unplgged you can see the relay smoked.the broil should come on but it sounds like it's running all the time without the bake element.i would tell you to check just the bake element but if you saw smoke something deffenitely got cooked.hope this helps you out.
Posted on Jun 21, 2011
  • 24 Answers
When the broil function is off, check for continuity between the broiler relay output terminals. If there is no continuity, check for an external short. If there is continuity when the broiler is supposed to be off, you need to replace or repair the board.You can get your old board repaired at appliancetimers.com.
Posted on Mar 18, 2011
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Kenmore electric range model 790 oven stopped functioning, both broiler and bake. however, oven light still comes on.
I believe there is a thermal fuse (also called a TCO or Thermal Cut-Out) located either on the back of the oven, or between the top of the oven and the cooktop that has opened up. Did this happen after running a self-clean cycle?
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 09, 2014 | Kenmore Kitchen Ranges
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
Kenmore electric range - oven temp low and takes forever to heat
if lower element tests open with continuity meter then it for sure is bad. i would also check the wire ends that connect to the element and/or the control board, they could have loosened allowing a bad connection and low voltage to elementor burnt off.. most ovens do not use the broil element at all during the bake cycle, only during the broil cycle.. some however do utilize the broil element during baking, but at a lower wattage or something..
best of luck,
ttfn
Oct 25, 2009 | Kenmore 30169 Electric Single Oven
Kenmore range bake element doesn't work
check that the wiring is not bad and every thing is conected
Jun 04, 2009 | Kenmore 95922 / 95924 / 95929 Electric...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore range
If this range has electric elements in the oven, you may have blown one of the heating elements. Do any of the oven functions work? If you were attempting to BAKE when this occurred, have you attempted to turn on the BROILER to see if it works? If the BROILER still heats up, you may just have a bad heating element. If both features quit working, the problem may be with your Electronic Range Control (ERC) board. Post back with comments and let me know.
Feb 18, 2008 | Kitchen Ranges
Stove is suddenly haunted
F3 Oven too hot Replace oven temperature sensor it also sounds like you need a main control too..hope this helps
Aug 25, 2007 | Kenmore 75503 Stainless Steel Dual Fuel...
Kitchen Ranges Logo
394 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
