Question about Garden
I have Poulan 42cc. 18 in.,no chain break it is older model.Where does the carb.get it signal to run pump diaphram. Under the intake port, or from lower crank case. The carb.is not drilled for intake port to be used
  • 2,239 Answers
There is only two ways the impulse from the piston riseing and falling can get to the carb, either through a drilling in the intake side of the carb, or a pipe directly to the top of the pump cover on the carb, the pulse from the engine can come from many places, the crankcase, the transfer port, the cylinder intake port.
Posted on Mar 18, 2011
Poulan 42 cc chain saw that is hard to pull the rope like the compression release is not working. How do I repair it?? Built in 2007
I do not think they had a compression realese on a saw that small, it is more likly to be an issue with the starter, remove the screws and take away the starter does it pull easily off the saw? if it is ok try turning the engine with the flywheel, is the flywheel rubbing the ignition unit, the gap here should be 0.5mm.
Apr 08, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan will run but when I press the gas trigger, it shuts off
Sounds like it is running out of fuel supply. Pull the carb. out and part. If you disassemble one side at a time it is very simple. Spray out real well with gum cutter or carb and choke spray. Make sure the hole under the need valve located below the diaphram is clean and the needle is replaced the same way it came out.
Feb 20, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan pro 42cc,18",PPB4218 is very hard to start and runs for a short time and then will not start when hot. It worked well first year, badly this season.Changed spark plug and cleaned fuel filter and...
check basics 1st fuel , air, compression, spark , timming
then secondary compression ie crankcase air tightness
2 strokes need air tight c/case in order to draw in & pump mixture
check your tank breather is working,
has this saw been sitting a while ? if so might pay to rekit carb
check your carby diaphrams are pliable and inlet screen is not blocked and metering needle is set flush with chamber floor,
are hi / lo needles set base settings are 1-1/4 turns out from lightly seated , final hi setting is done while @ full rev and needs to 4 stroke slightly
check ignition spark under load ie while under compression load- could be a weak spark
check timming key
check for a air leak at cylinder / manifold block gasket or carb joint
check barrell bolts are tight everything been = engine should run
cheers
Aug 29, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
Apr 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Carburetor overflowing
Gas line from primer bulb to carb may be cracked or broken. Check gas lines for damage. If not that then there maybe an overflow problem in side the carb caused by the float shut off not seating correct or worn "o" ring etc.
May 16, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain sprocket
I looked at a breakdown for the 42CC not sure if the same one or not but it appears that the chain sprocket is held on by an Eclip and behind that a flat washer. If this doesn't look like yours give me the model number and I will research another breakdown
Feb 25, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan PP4218AUX will not start
I have a 42 cc 14"bar will not start. poulan chain saw.
Feb 18, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
