Question about Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Tamper proof LED is on. Blinks twice when power button pressed ( RC or local ). Will load a VCR and then eject, will open/close DVD tray. I have checked both power packs. I somehow have the feeling it is trying to tell me something.
  • Lincoln Hubbard Mar 18, 2011
    Thank you. You nailed it, TV works perfect. The remote control was so dirty that I never saw the T.PROOF button or knew it was there. Only by my patience or the set would have been trashed. Thanks again. Lincoln Hubbard, N1ATU
  • Lincoln Hubbard Mar 20, 2011
    Yes, very much so and also so prompt. I have been servicing TV's since 1950 and after rontine service on this set I could find nothing failed and was not ready to give up.
    I will give you another interesting service. A TV brought in with a white line, no vert. Replaced IC, Set was back a few days later, no vert. could not find cause. Looking at CRT HV terminal - it was covered with a varnish like crud. Apparently HV would arc to the yoke, taking out the vert. IC. Cure = clean CRT HV terminal. I asked the owner if someone smoked at his house. Reply - There were two heavy smokers, one has died. Here is a case where cigaretes killed a TV set.
    Thanks again Lincoln Hubbard N1ATU
    President:
  • 1,140 Answers
Hello there,
It's trying to tell you that you've (accidentally) activated Tamper Proof Mode. It will not allow you to insert cassettes or DVDs until it is deactivated.
To deactivate, press and hold the T.PROOF button on the original Sharp remote for at least 3 seconds. (Possibly up to 10 seconds).
This is the remote for the 27DV-S100 as listed above. If you have a different model, look for a button on your Sharp remote labelled T.PROOF or TAMPER PROOF and press and hold it for at least 3 seconds. If you don't have the original Sharp remote, please let me know the brand and model number of the remote you are using with the TV (if any).
Hope this helps. Please try the above, then let me know if you need further assistance, by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Mar 18, 2011
  • DILLIGAF
    DILLIGAF Mar 18, 2011
    No problem Lincoln - glad I could help.
    I would appreciate it if you could close this question by clicking on "Accept" below my solution. This will ensure both that I am credited for solving your problem and prevents your question from being returned to FixYa's unsolved problems list.
    Thanks,
    BElectric.
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
Plustron lcd TV/DVD NEED CODE
Try this solution posted by Ipsita: http://www.videohelp.com/dvdhacks/coby-tf-dvd7006/8694
thank you to IPsita if this work:
The contain below:
icon_minipost.gifRegion code hack posted by ipsita, January 11 2008:
1) Remove the dvd (if present) from the player
2) Open the tray
3) Press STOP on the remote
4) Press 7 0 on the remote
5) Press MENU on the remote
6) You can see the current region on the top of the screen
7) Press the appropriate region code, e.g. press 5 if the region code needs to be Russia. Press 0 to make the dvd player region free.
8) Press MENU
melnavz
Aug 23, 2008 | Televison & Video
Will not play DVD from other regions. Specifically, plays a few but mostly does not play DVD from Australian region. I resdie in Serbia. thansk for any advice or work arounds on this issue. We inherited...
Your dvd is locked to a region code so will only play dvd's for region it was made for.
good news is that you can unlock most dvd players to be region free.
URC-3445 ONEFORALL
First of all set the command mode of the recorder to "DVD1"
from the menu and from the remote.
After that
1. Press DVD on the remote control
2. Hold MAGIC button (or SET Button) until the led flashes twice.
3. Press 0, 5, 3 and 3 and the led flashes twice.
4. After that the URC can manage the recorder...check it
If not, then use the code search (have a look in the manual of the remote control).
When the rc works, then step over to
MAIN PROCEDURE (DON'T HAVE ANY DVD INSIDE THE PLAYER)
1. Hold MAGIC button until the LED blinks twice
2. Now type "994" (then LED blinks again)
3. Press the MAGIC button (shortly)
4. Now type 001891
5. LED blinks twice
6. Repeat steps 1-5 and enter instead of step 4 the codes 002552,000953,002214,000795
7. Put the player on standby (and be sure that there is no DVD inside)
8. Press 1,2,3,4,5 (pause briefly between each button and make sure LED of remote flashes) then the display shows "TIMER OK" and the DVD-Player goes on
9. Press 1,2,3,4,5 (pause briefly between each button and make sure LED of remote flashes) then the display shows "TIMER OK" and the DVD-Player goes off
10. Then it is done. Your DVD-Player/Recorder is Codefree
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Sony SLV-D990P DVD Player/VCR
Instructions on how to program
Hi
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn't work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thank You
Sep 18, 2010 | One For All URC4220 Remote Control
Im trying to program a remote the tv is a zenith
Configuring codes:
CBL/SAT or TV).
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
blink twice.
Thanx
Aug 06, 2010 | One For All URC4110 Remote Control
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
What sequence do I use to punch in codes 4 a VCR,start to finish?
1. Press the "DVD/VCR" button on the remote.
2. Press and hold the "SET" button on the remote until the red LED blinks twice, then release the button.
3. Enter the 4 digit code for the VCR. (Red LED should blink twice after you enter the code.)
4. Aim the remote at the VCR and press power. The VCR should turn on. If not, try another code until you find the right one.
Oct 07, 2009 | One For All URC-3021 Remote Control
Radio Shack 5 in 1 remote has no p button
NOTE: To program a TV/DVD, TV/VCR/DVD, or TV/
VCR Combo, use the TV key.
1. Turn on the device (for example, DVD player)
and, if needed, load media (for example, DVD).
2. On the remote, press a device key (that is, VCR/
DVD, CBL/SAT, or TV).
3. Press and hold P until the red LED blinks twice,
then release.
4. Enter the first four-digit code for your device.
The LED blinks once as each digit is entered. If
the code is correct, the LED blinks twice.
NOTE: If the LED does not blink twice, repeat steps 2
to 4 and try entering the code again.
5. Aim the remote at the device and press Power
(or Play, if it does not have a Power key). The
until you find one that works. If you cannot find
a code that works, see “Searching for Your
Code”.
6. Repeat steps 1 to 5 for each device you want to
control. For future reference, write down each
working device code in a safe place.
Sep 12, 2009 | Radio Shack (15-2147) Remote Control
DVD tray won't open
Try to reinitialize the DVD functions, in the manual:
http://books.jvcservice.com/booklist.asp?Model=DR-MV1SU
Page 84
Turn the player OFF,
Press and hold the power button, While holding it, press the Stop button for 2 seconds or more.
Once its reset, see if it will eject.
Dec 27, 2008 | JVC DR-MV1SU DVD Recorder/VCR
DVD will no eject
This is not helpful. The power is on and display is on, but no response.
Jun 20, 2007 | Zenith XBV443 DVD Player/VCR
Sharp 27DV-S100 27 in. TV/VCR/DVD Combo Logo
335 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
