Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissle red pro x2 . The brushers are not going around, i have changed the brush moter and the belts are ok
3 Suggested Answers
  • 20 Answers
SOURCE: bissle vacume can not fit belt around motor
It sounds like you got a belt that was too small, if it is the right belt it will be hard to get on. But once its on you will be all set.
Posted on Jan 17, 2010
heatman101
  • 43501 Answers
SOURCE: How do I change the belt on my Bissell Pro Heat
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
twerw
Posted on Sep 30, 2010
Where is belt located on Hoover wind tunnel vacum. And how to replace it. My brushes are not spinning.
Its usually located underneath the body of the unit, turn it upside down and you should see the beater brush. You need to open the bottom cover to get at the brush and drive belt.
Mar 25, 2015 | Hoover U8126-900 Wind Tunnel Dual V...
How do I unblock the brush part of my cleaner. The rollers are not going round.
remove a few screws and you will be able to pull out the brusher, usually it's the motor end of the drive belt blocked as well as the bushes each side of the brush, pull all the hairs and threads off then put back together
Feb 21, 2015 | Vacuums
Hi,dyson dc25 overdrive,my brusher's wont go round,i have cleaned the brusher's and filter,loads of suction.the belt is intact and the roller move's feely by hand,could it be the switch
Hi Stephen,
I'm sorry to hear you've had difficulty with your DC25 Overdrive. If the brush bar won't rotate, and you've already checked the cleaner head is free of obstructions, it's likely it just needs resetting.
You might like to take a look at the video below to make sure everything is correct with the machine. Once you've done this, if you turn the machine on, recline it into the vacuuming position, then press the silver brush control switch twice, this should reset the brush bar.
If you'd like any further assistance or advice, please give our Helpline a call on 0800 298 0298. Just to let you know, calls are free from UK landlines, and the Helpline is available from 7am-10pm, 7 days a week.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Aug 01, 2012 | Vacuums
Bissle vacume can not fit belt around motor
Jan 17, 2010 | Bissell 6594 PowerForce Bagless Upright...
How do i change the belt on the bissell powersteamer 1697w????
Ok taking the cover off is good. I believe the the little red thing is the beater bar. This beater bar has brushes on it an extends the width of the vacum. Pull the beater bar out straight. Some times it is tight. Next is to place the new belt around the spindle in the back and slide the beatrer bar into the belt. No twists! Besure to have the beater bar with the seperated area with no brushes inline with the belt.Now place the beater bar in place. Make sure you turn the beater bar so on the side the slotted portion slides all the way in place. Replace your cover. Turn it on and try it.
I believe this will work. Let me know.
desmjs
Dec 14, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissel pro heat /brushes do not turn
Belt worn or hair build up can clog it from spinning. I've seen this on other models. Just remove the hair slowly. If the Belt is worn you can replace that from Bissel or any store that sells their product.
Check to ensure that the pump belt and brush belt are intact and installed according to the instructions provided in the User's Guide.
The pump belt is located under the belt access door on the side of the machine. This belt should be looped around the red pulley and the silver motor shaft.
To check the brush belt, please follow these directions:
Turn the machine OFF and unplug from the wall outlet.
Step on the handle release pedal to lay the handle down on the floor.
Remove the Tank-in-Tank and SmartMix Bottle and set them aside.
Turn the machine over to expose the brush.
Look for the red retainer plates, which hold the black brush arms in place. Remove the two Phillips head screws to access the toothed brush belt. Check to ensure the belt is intact and looped around the brush end, as well as the red pulley with the ridges.
Remove any dirt or debris from the brush assembly.
Inspect brush, brush arms, red brush arm retainers and red pulley for damage and replace parts if applicable.
Jul 30, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Keep replacing belt that drives brusher but keeps breaking. When feel belt driver rod it is superheated.....could it be melting into the stretched belt causing it to weaken?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559226
Generic problem for all Vacuums
Posted by andy78billy on Apr 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Depending on the brand name and model # it is my opinion that it is not the belt, it may be that your brushroll is bound up with thread, hair, dirt, etc., and is not spinning well – place the brushroll on end and try to spin it, if it does not spin freely, then you are bound up, try to clean it up and lubricate by using one drop of oil and then wipe off the excess, you don’t want the oil to hit your carpet, if that does not work replace the brush and the new belt, am average flat belt change is every 4 to 6 months – also you may have the wrong size belt of which would cause the to burn up fast. Always use the genuine vacuum belts when replacing.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Bissell 1697w
First take off the belt cover on the side,
then turn it over, on the belt end of the brush roll, there is a red piece to hold in the brush roll, take out that screw and pull it off, the you can remove the end cap and cogged belt, Put the pump belt up thru the opening and around the bigger part of the pump pulley, grab the belt from the top side and put it around the motor shaft. Re-install the cogged belt, brush roll, cap and red lock.
Nov 07, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
27 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
