Question about Exercise & Fitness
I have a T71 treadmill the motor will shut off fairly quickly after starting. It seems to happen as it is accelerating. The time and other treadmill elements will keep going as if the treadmill is working
  • 84 Answers
Take hood off and take the wires from the motor. the ones that power go through, and test with a fully charged cordless drill one at least 18volt that should run your motor . not fast but it will cycle.if motor runs then its the controller board
Posted on Mar 18, 2011
I have a proform 505cst. When I push start, the motor seems to short out. The motor controller LED blinks four times.
Customer Reviews: Proform 505 CST Treadmill (2014 Model)
www.amazon.com/Proform...Treadmill.../B0048HS02...
Amazon.com, Inc.Start here. ..... I was worried it would fall out with the vibration but, as I mentioned earlier, ... The 10% incline and the max speed on this unit more than serves the need ...The sound from the belt and motor is very acceptable (but then its only been .... This morning i was using it for the first time and this treadmill seems great.
Amazon.com : Proform 505 CST Treadmill (2014 Model ...
www.amazon.com > ... > Cardio Training > Treadmills
Amazon.com, Inc.Start here. ..... The ProForm 505 CST Treadmill is designed to get you moving. ....This morning i was using it for the first time and this treadmill seems great. ... I would suggest for anyone that gets this to open up the motor cover and take a look at ...graphics on the instruction manual and figure out what piece went where .
505 CST ' Proform
Jan 11, 2016 | Proform 505CST Treadmill Walking Deck
Proform V650 Treadmill - Main motor does not turn
The board will most probably need replacing. Almost certain.
I repair this brand for the manufacturer.
Nov 06, 2013 | Proform Exercise & Fitness
Just got Nordictrack 1750. Assembly was easy but incline does not work. Everything else seems to be okay. Took motor cover off and do not seem to be getting any power to incline motor.
go HOOD cover motor follow the steps or ready your owner manual, and RUN the software calibration for easy diagnostic and fix it.
The
Steps for Newer Style Console Calibration
1. Locate the calibration area on the
rear or underside of the console (a hole, near the console\'s center, that goes
through to the electronics board. (This hole should not have a screw in
it.)
2. Insert a pencil (eraser end),
into the hole and feel around for the cal button (will click when
pressed).
3. Press the button 2 times
(with the pencil eraser). The first click should show CL11 in the
console, the second click should show CL21.
4. If the process was done correctly,
and CL21 appears in the console, you are in "calibration mode."
The next few steps consists of pressing buttons on the console
and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in
the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in
7. Press ENTER. CL24 should display in
8. Press ENTER. CL25 should
display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should
display in the TIME window. You should then see the letter
"E."
10.
Press
ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be
off, the treadmill.
12.
Push
the ENTER button. The walking belt should start to move, accelerate to maximum
speed, then stop on its own.
13.
When
the belt stops, the incline should self test by raising to its
highest incline position, then lowering back down to its lowest position.
14.
Once
the incline test is complete, push the POWER button 2 times. The unit should
shut off and the console should go completely blank. If this
happens, the treadmill is done calibrating and is ready for use.
If the letter
"F" appears in the SPEED or INCLINE window when the power button is
pressed 2 times, the treadmill is indicating a failure somewhere
either in the SPEED or INCLINE (depending on the window the
"F" appeared in). Troubleshooting the failure would be the next
step.
God bless you
Oct 17, 2013 | Nordic Track Exercise & Fitness
Treadmill
see the video and proceed according+ rollers bearing too
However if the problem persist, time to REPLACE the old deck belt board.
God bless you
Jan 14, 2013 | RTO Health Trainer HT-720T Treadmill
My nordicktrack exp1000 runs for about 20 minutes, starts to smell like its getting hot and will shut itself off, can I fix or do I have to buy a new treadmill
Step 1:
this happen because the lack of LUBE, do it
Step 2:
1) troubleshoot the main motor see my personal TIPS for motor help
2) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
Jan 08, 2013 | Nordic Track Nordictrack Exp 1000...
Precor 933i belt error
Please read my personal TIPS for treadmills and test it.
However LUBE inmediately the deck belt, this happen because the lack of maintenance by 5 hours aprox, So the system protect itself for electronic system and shut down.
2) LUBE the rollers bearing too.
3) Test the main motor bearint, measure the input voltage motor, if there are the motor is faulty. Repair. see my personal TIPS
God bless you
Nov 15, 2012 | Precor Exercise & Fitness
System cannot connect wire
you must test the quick start button for defective, this is closed all the time, this connect the machine,and of course pass to RUn . You must LUBE the deck belt, for to avoid the system shut down.
I strong recommend try to RUN the software calibration Hunder the HOOD motor, for easy diagnose, troubleshooting, and fix it.
3) test the input voltage motor, if there are voltage the motor need repair.
4) test the output voltage boad, if there are NOT the board is faulty.
God bless you
Aug 29, 2012 | Life Fitness 9500HR Next Generation...
Hi, our proform 790 tr treadmill is aorund six years old and the walking belt and height motor seem to be going. Is it worth replacing these and is it fairly straightforward?
Changing a walking belt takes about an hour for someone who has done it before. Check the walking deck for scratches, damage as well. Often times if the belt is worn out, the deck needs to be replaced as well. Belts vary in price depending on the make and model of treadmill. Parts can be ordered by calling the number found on the model number sticker on the treadmill. There are 10 different machines with the 790t model name. To get the correct parts find the actual model number (will start with "H"). The parts come with replacement instructions.
Belt $105 Deck $190
As for the incline motor, it is very rare to change that part. It may just require calibration. Start the machine . Press incline up and hold, remove the safety key. Now reinsert the safety key. The machine should rise to full incline then back down to minimum. Once the cycle is complete, the treadmill should work normally. If the incline sensor is defective, the motor will have to be replaced. Incline motor $150.
Feb 26, 2011 | Proform 790T Treadmill
Tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Exercise & Fitness Logo
123 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
