Question about Linksys by Cisco WAP610N Wireless-N Access Point with Dual-Band
It does not make much sense. But it seems the WAP610N has a limit on concurrent connections. We just started to use this device in a small office network. There are about 15 laptops on wireless connection. But we had two computers unable to connect wireless for all day today. But towards the end of the day when some users left the office, these two computers got onto the network wirelelly without any problem.
    Brigadier General:
  • 10,406 Answers
Two possibilities:
1. the router is configured to hand-out IP-addresses in a limited range, e.g., 192.168.1.100 to 192.168.1.110, namely 11 different IP-addresses. When the 12th computer asks for an IP-address, there is none available. Remedy: configure the router to use a larger range of IP-addresses.
2. when an IP-address is handed-out, attached is a 'TTL' ("time to live") value, indicating how long the IP-address remains valid, e.g., 10 minutes or 100 minutes or 1 day or 1 week. If the TTL is too large, then each computer "hogs" the IP-address (even after being shut-off in mid-afternoon).
Remedy: configure the router to use a shorter TTL. Don't worry: when a TTL value drops to 50% of its original value, on a specific computer, the computer will "renew" the lease.
Posted on Mar 18, 2011
Ip address for linksys access point wap610n
Anon,
This link has a tutorial that is well written and easy to follow.
Setting up the WAP610N
Take care and have a great night! -Alex K.
May 13, 2014 | Linksys by Cisco WAP610N Wireless-N Access...
How can I connect my notebook to another pc without installing LAN??
A Local Area Connection, or LAN, is generally a small home or office network used to link all the devices in the area. With the advent of wireless technologies, LAN networks are no longer limited to the amount of cords you own. Laptops can connect to wireless LAN easily with their built in wireless adapters. Connecting two laptops together over wireless LAN is also easy, but requires a few special steps to give the laptops access to each other.
1Connect both laptops to the wireless network you wish to use. Once connected, click the "Start" button and navigate to the "Network" menu.
2.Click the "Network and Sharing Center" link. Press the "View Computers and Devices" button. A list of devices currently on the network is displayed.
3.Check the list for the names of both laptops. If both laptops are displayed in the list of devices connected to the network, the devices are connected wirelessly to a LAN network.
Sep 06, 2011 | IBM ThinkPad R50e Notebook
Can't communicate with Linksys WAP610n from laptop via straight or crossover cable. Fixed IP network won't find WAP610n either.
If on Xp go onto start then run in run enter cmd this will open a command prompt in dos
then type in ipconfig and check settings if the ip and dns settings seem incorrect then type ipconfig/release then ipconfig/renew this will reset the system hope this rectifies your problem
Mar 01, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
IS CISCO LINSYS WAP-610 AN AP REPEATER Range extender?
You cannot use the WAP610N in repeater mode unless you connect it to your router using a cable.
Dec 14, 2010 | Linksys by Cisco WAP610N Wireless-N Access...
How many computers can the router handle?
The 2701hg-b Wireless Access Point (WAP) has 4 ethernet connections, that's the physical limit, for that, unless you "cascade" a bridge or another router off of a port.
It also supports wireless. I know of no documented limit as to the number of concurrent wireless connections... there probably is one, but it isn't "published", that I know of.
The "real" limits on the wireless side are "activity" and "channel" conflicts.
The "activity" conflict factor has to do with how much somebody/anybody is using "doing" with your WAP. Sooner or later, you'll see "saturation" of the wireless bandwith.
The "channel" conflict factor usually occurs when there are two (or more) WAPs (or other wireless devices) within "range", that are using the same "wireless channel".
From the "user" perspective, the effects of "conflict" are similar to "saturation", except that you'll likely see more "dropped connections" with "conflict".
Nov 10, 2010 | 2wire (2701HG-B) Wireless Router
If I will create a program using Visual Fox Pro 7, up to how many concurrent users can connect to the database that will have acceptable response time of 1 to 2 seconds?
That depends on several factors, from the characteristics of the network, to the way in which the application was developed. Windows hosts also has its limitations, for example, XP has a limit of 10 concurrent connections.
Best regards.
Oct 29, 2010 | Microsoft Visual FoxPro Professional...
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
Linksys by Cisco WAP610N Wireless-N Access Point with Dual-Band Logo
881 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
