Question about Canon CanoScan 8400F Film Scanner
Code2,178,0 Scanner will not function cites error code 2,178,0 Have tried checking connection and rebooting but no use. can you help
  • 2 more comments
  • bart1960 Nov 26, 2008
    Unfortunately I have he same problem. Tried everything; installing new drivers; rebooting... nothing helps. Who is gonna help me out this ****
  • James_Canbra Jan 08, 2009
    Here's a FixYa link to the same problem, but under the heading Twain Error. Link
  • Sharkovar Jan 19, 2009
    I had the same problem---error 2. 178, 0 after I installed a Microsoft Patch months ago. I am just getting around to try and fix it. I reinstalled CanoScan and this didn't help. I will check back in to see if anyone has a solution to fixing what I think is a Microsoft Patch that confliced with the CanoScan 8400F
  • Anonymous Jan 22, 2009
    Code2,178,0 problem
  • 4 Answers
This is caused by a faulty FAU cable. One, or more, of the eight wires within this cable has fractured and unless you are handy with fine wires and a soldering iron, it's off to the scanner shop, I'm afraid.
Posted on Mar 28, 2009
OK. I checked this by buying a working 8400F. I swapped the Film Adapter Unit (ie, the scanner top and the attached cable). The problem stayed the same.
Therefore it is NOT a faulty FAU cable.
It must be something in the body of the scanner.
(btw, I also greased the support shaft that the scanner unit runs along, because that fixed a problem with another scanner. It made no difference to the 2,178,0 error).
James.
Posted on Dec 21, 2009
How do I fix error code c-6740 on Konica Minolta c7000pro
C6704 Description Image input time out
Image data is not input from the scanner to the MFP board (MFPB). Remedy 1 Select [Service Mode] - [State Confirmation] - [Memory/HDD Adj.] - [Memory Bus Check] - [Scanner-Memory], and conduct the memory bus function. 2 Check the connectors between scanner section and MFPB for proper connection and correct as necessary. 3 Replace MFPB. 4 Replace CCDB.
Dec 09, 2014 | Konica Minolta bizhub Office Equipment &...
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Hi, my lex1270 scanner is not working. printer and copy is fine. when i want to scan i get an error code!!! please help.
What is the error code displayed on the screen?
1. Disconnect the printer from your computer.
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X1270 All-In-One InkJet Printer
I have problem canon ir 5000 e355,,....please help me
How to clear the error code:
1. Enter Service Mode: Press * Additional Functions, 2&8 simultaneously, then * Additional Functions again.
2. Then select the [COPIER] option. Under [COPIER], select the Function tab.
3. Under the [FUNCTION] tab, select the [CLEAR] option.
4. In [CLEAR] there is a selection E355-CLR. Select it and hit OK.
5. Reboot the machine.
If the error occurs again:
1. Make sure the connection is secure and tight to the Main-Controller board from the connector cable to the Serial Number board below.
2. Reseat the Main-Controller board into its slot.
3. Go into service mode and clear the error code as explained above.
* If the error still continues, you probably have a bad Serial Number board and it needs to be replaced.
Aug 27, 2010 | Canon imageRUNNER 5000 Copier
Background changeover unit failure on 6130dj scanner. Tried cleaning it, rebooting pc & downloading driver . . . what else can I do?
When a background switching malfunction occurs, "F" and "4" will display alternately on the function number display panel of the scanner.
Wipe the top and bottom glasses located inside the ADF with the Cleaner F1 and check if the problem persists.
If turning on the scanner again does not recover the situation, then follow the procedures provided below:
1 Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2 Are the cables between the Control PCA and the BW Motor damaged? Or are the connectors connected correctly?
3 Is the white reference work properly? If not, then replace the BW Motor.Perform background changeover test.
4 Is the OPT Unit installed correctly? Check ADF (Front) and ADF (Back)
5 Replace the Control PCA and see if the error is resolved.
6 Replace the OPT Unit and see if the error is resolved.
Hope the above information is helpful.
Thanks,
ScanCare
Apr 26, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
When I try to scan - I get a "lamp error" message.
open upper cover remove glass panel and lamp assembly clean up that are and return for testing. if not working replace lamp assembly.
Apr 15, 2010 | HP Scanjetâ„¢ G3010 Flatbed Scanner
My canoscan fb620u shows device offline.
It your using a newer windows you probably need new software. Try Vue Scan it worked for me on Windows 7 64bit and I have the same scanner. With out dated software it wont recognize the scanner. Hope it helps
Dec 24, 2009 | Canon CanoScan FB620U Flatbed Scanner
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Artec e +48u scanner
quite possible the scanner motor finnaly gave out but lets look at other things first
try connecting to another usb port on comp before that completly take out all of the scanners drivers and programs this could be a simple file corrupt
i know you tried this but sometimes putting a new driver over old driver doesnt usually change the old drivers properties this is when you completly take out all drivers and software and start from scratch for this scanner
May 11, 2008 | Office Equipment & Supplies
Kodak I-40 Scanner
8 Face up light check failure is the only code listed, not "88" for this model.
If code 8, the top lamp may well be occasionally flickering. Could be the Lamp or the Inverter (Ballast) check connections to lamp.
Jan 12, 2007 | Kodak i40 Path-Through Scanner
Canon CanoScan 8400F Film Scanner Logo
716 people viewed this question
old marine
old marine
