Question about Cycling
Where can I find the expanded wedge for my daughters 16" youth bike made by Dyna Craft? It is Barbie bike
    Brigadier General:
  • 8,546 Answers
Do you mean the expander wedge in the stem? Is it lost or you just don't know where it is?
Register and download the manual for free audio.manualsonline.com
Posted on Mar 18, 2011
  • umanne Mar 19, 2011
    Yeah - I donno if it is lost or where it is....Do you know where I can get it?
  • David Dunn
    David Dunn Mar 19, 2011
    If you removed the stem yourself and you unscrewed it too far and removed the screw the wedge likely just fell inside the steerer tube.
    Oh, apologies for that erroneous link. I'm having some trouble with my cut n paste sometimes.
    Read this. It explains everything about stems.
    http://www.sheldonbrown.com/handsup.html
    If it really is lost you'll have to take the stem and screw to a Bike Shop and see if they have a wedge in their junk box somewhere. Threads and angles may vary from one to the next.
Dynacraft Girls 16" Barbie Bike pedals don't move
The problem could be the coaster brake hub, it could be that the cranks are not properly adjusted, or any number of other weird things. My advise--take it to a bike shop. If they're kind, they should be able to get things moving in the proper circular motion quickly for a reasonable charge. If they're not kind, they'll laugh at the bike first, but they will still help.
Dec 28, 2013 | Dynacraft Girls 16" Barbie Bike
My neighbor ran over my daughter's 16" Barbie bike
any bike shop or toys-r us- or toy world bikes.
Jun 16, 2013 | Cycling
Left pedal arm for a barbie bmx bike broken. Where can I find a replacement?
You should talk to your bike shop because they can find the correct one and also install it because you need expencive bike spicific tools to remove them and replace.
Jul 22, 2011 | Dynacraft Girls 16" Barbie Bike
The very first time my daughter rode her new 14" Dynacraft Barbie bicycle, one of the tassels came out of the side of the handlebar when she laid it down. How can I get a replacement tassel/tassels?...
I went to a five and dime and bought streamers for my kids, they made their own and had a blast doing it,, you can use a ziptie, once they add all the colors they want, and stuff that in the handlebar grip hole to mount them,
May 28, 2011 | Dynacraft Girls 16" Barbie Bike
16 inch bicycle tire is flat. Need replacement, where to buy?
Call Dynacraft (bike maker) at 1-800-551-0032. My daughter's rear tire was flat and they sent out a new tube for free. She had the bike for only about 4 months. They also sent out a new rear tire as bearing/coaster brake assembly was make noises. The only problem is her original rim was purple and they sent out a silver colored rim as they don't have purple replacement part. I also had to install the tube and tire on the new rim. They only send replacement parts not assemblies.
Sep 16, 2010 | Dynacraft Girls 16" Barbie Bike
Where do I find a replacement tire for a barbie dynacraft bike?
Its either a 12" or 16" tire replace with any tire you like in that size
Aug 16, 2010 | Dynacraft Girls 16" Barbie Bike
How do I attach the hadlebars?
the bars go throuhg the hole down into the front wheel. on the bar where the the neck goes into the frame there is a hole in that a long bolt goes in that, then the wedge shape nut goes on the long that runs down the neck into the frame that the front is in. make sure that the wedge bolt will line up with wedge on bar. place through frame into wheel so the neck bottem out get your ratach and start cranking as it get tight line up neck w/ tire and lock it down pull up to check turn head just in case
Feb 21, 2010 | Dynacraft Girls 16" Barbie Bike
Fork is too narrow for front wheel
One solution, is a large, wedge shaped piece of wood.
Try hammering that into, or the forks onto it.
That should open them up, without damaging the finish.
Good luck with that.
Jul 22, 2009 | Dynacraft Girls 16" Barbie Bike
Which way do the front brake pads face, out or in?
Yes, The front brakes are designed for the torque of stopping to "Pull" away from the neck. if you look at a bigger bike it has brackets to help support it in the rear brakes as it rests on the frame while stopping...the front brakes do not have these brackets. However if you DID install these same brackets on the front and had them mounted backwards then i see no harm. granted its just a little barbie bike. but still...you want your daughter safe at all costs.
Hope this helps...post a comment if you need me to explain or clarify anything .
8-)
Jun 07, 2009 | Dynacraft Girls 16" Barbie Bike
Cycling Logo
48 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
