Question about Kenmore 22422 Top Load Washer
My kenmore washer fills up starts doing its thing and it makes a noise and then i smell something burning and it runs for a minute or so and then it cuts off and if it sits for a little it will work again and do the samething smells and then cuts off.
    Sergeant:
  • 170 Answers
Sounds like your motor is shutting down on the thermal overload/that is a safety device inside the motor.If unit was worked on lately maybe something was not put back the rite way..If not then most likely gearcase is getting bad and causing motor to work too hard .Could take unit apart to see if gearcase shaft turns freely.I have a post on here on how to take direct drive unit apart..'Good luck and thanks for voting
Posted on Mar 18, 2011
Loud noise while running
Hello. Did you get an answer to this inquiry. Mine is doing the same thing. Smell of burning plastic; continues to fill and drain at the same time?!! I have to manually shut of water to stop the water and then manually set to spin so it will drain!
Mar 22, 2014 | Bosch Nexxt Premium WFMC6400UC Front Load...
I have a Sears Kenmore washer (Model # 11092281100). I replaced the motor coupler, and I checked the alignment of everything before reconnecting the motor clamps/clips. It seemed like the motor shaft was...
It could be the grease. It could run without noise if it was not installed all the way. Here is a link for properly installing Motor coupler video Now if everything looks right it is probally just the grease.
Nov 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series electric dryer. metalic sound/burning smell
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Will not agitate
Bad pump Pump bearing locked up something up in pump brazzierre underwire shoulder suppet thing IN pump. Check pump
Feb 13, 2009 | Kenmore 63942 Dryer
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Freezer motor has burning smell
disconnect from mains. take cover off compressor electrics. check starting device - easy to replace
Aug 09, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My kenmore washer fills up but then just stops
it could be several things, something is lodged in pump, so the motor wont run, the motor is bad, or you have a bad transmission.
Start with the pump and see if it has sock or something stuck in it.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Dec 08, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Loud noise and smell
It would help to know the brand and model number of the washer. If it has a belt that also runs the pump, something may have gotten into the pump during drain and locked the pump causing the belt to slip.
Oct 07, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
64 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
