Question about Seagate Barracuda 7200.10 ST3250310AS SATA Hard Drive
I had windows vista and tried upgrading to windows 7. the upgrade failed (it was a download from windows) and it tried to resort back to windows vista however that failed. Now the computer wont start vista and I get no boot device availabel error message. do I just need to reinstall the SATA drivers? I have a seagate barracude 7200.10
  • Seagate Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
Posted on Mar 18, 2011
Can Vista Home Premium be upgraded to window's 7?
      If you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version ofWindows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
      Upgrading from Windows Vista to Windows 7 - Windows Help
      windows.microsoft.com/.../windows7/.../upgrading-fro... Microsoft Windows
    Feedback
    windows.microsoft.com/.../windows7/.../upgrading-f...
    Microsoft WindowsIf you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version of Windows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
    How To Upgrade from Vista to Windows 7 Home Premium ...
Feb 08, 2016 | Computers & Internet
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Can initialize a vista system to windows 7 system
Do you mean you want to upgrade from Windows Vista to Windows 7?
First you should check it your laptop will work with Windows 7.
You can run a Windows 7 upgrade advisor to check if your computer is suitable for Windows 7.
Click on this link to download the check upgrade program :- http://www.microsoft.com/downloads/en/details.aspx?familyid=1b544e90-7659-4bd9-9e51-2497c146af15&displaylang=en
If it is OK to install Windows 7 then you need to purchase a Windows 7 upgrade installation disc.
Mar 21, 2013 | Sony VAIO VGN-NS190D/W Notebook
Can I install Windows 7 over badly infected with drivers missing Windows X P? I'm trying to delete everything, but can't. I turned off my security system, but it comes back on and won't let me delete. I...
To my knowledge you cannot upgrade from Windows XP directly to Windows 7. You will have to upgrade to Vista and then to 7. Also there are limitations as to which Windows 7 version (Home, Professional, Ultimate) you can upgrade to from certain Vista versions.
If you dont have any information / data on the PC that you mind loosing, i suggest a clean install of Windows 7 by booting up from the Windows 7 dvd and formating the HDD before the installation procedure.
Windows 7 has a host of built in drivers that will probably cover all of the devices that are present on your system. If not then you can always download the drivers from the manufacturers site for the items that fail to install automatically under 7.
Let me know how it goes.
:)BD
Sep 08, 2010 | Gateway Computers & Internet
Can i update window 7 ? now i hv window XP is there any effect of my files available in system during downloading wndow7
Windows 7 does not allow an upgrade from Windows XP. You would have to upgrade to Vista first and then on to 7. Also, it depends on which Vista you have that will determine which Windows 7 you can upgrade to. If you have Vista Home basic for instance, you cannot upgrade to Windows 7 Premium or professional. It is really screwed up. You can however do a clean install but you will lose all your old files unless you back them up on an external drive before running the new OS.
May 16, 2010 | Acer Aspire One PC Notebook
Drivers
I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
Apr 04, 2010 | Toshiba Satellite A300-ST6511 Notebook
I have a HP Pavilion tx2620es with Windows Vista 32bits working perfectly, i buy Windows7 Upgrade Kit from HP, so i installed it and all sort of problems became: -Rotation of screen has stop working -Touch...
TRY TO DO CUSTOM/CLEAN INSTALL OF WINDOWS 7, BUT BEFORE INSTALLING IT DOWNLOAD WINDOWS 7 upgrade advisor , HERE IS THE LINK http://www.microsoft.com/downloads/details.aspx?FamilyID=1b544e90-7659-4bd9-9e51-2497c146af15&displaylang=en RUN IT ON VISTA TO MAKE SURE WINDOWS 7 IS ABLE TO BE INSTALLED ON YOUR PC. BECAUSE WINDOWS 7 IS NEW OS IT MIGHT GIVE YOU MORE TROUBLES ON TABLET PC`s, MICROSOFT STILL UPDATING THEIR DATABASE FOR CORRECT DRIVERS FOR WINDOWS 7, ANYWAYS , I`LL SUGGEST YOU RUNING UPGRADE ADVISOR ON VISTA.
Mar 09, 2010 | HP Pavilion Tablet Notebook
I tried to upgrade my acer t180 to windows 7 from vista basic, no i"m having dmi problems... seems like it's stuck... help please
Hello kelajo34,
There might be a Desktop Management Interface (DMI) compatibility problem with Windows 7 and the Acer T180 Vista Basic DMI. The Acer support Windows 7 eligible systems link shows all the Acer computers that are fully compatible with windows 7. (Acer T180 is NOT in this list !):
http://www.acer.com/windows7upgrade/eligible.html
Also, It might be a good idea to run the Windows 7 Upgrade Advisor before upgrading from vista basic to Windows 7 on the Acer T180. The Windows 7 Upgrade Advisor download link is at: http://www.microsoft.com/downloads/details.aspx?FamilyID=1b544e90-7659-4bd9-9e51-2497c146af15&displaylang=en
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jan 30, 2010 | Acer Aspire™ T180 PC Desktop
Want to update p200 1JV t windows 7 from vista 32
Download and run the upgrade advisor from here to see if you will have any problems.
http://windows.microsoft.com/en-GB/windows/downloads/upgrade-advisor
Jan 01, 2010 | Toshiba Computers & Internet
Seagate Barracuda 7200.10 ST3250310AS SATA Hard Drive Logo
103 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
