Question about Samsung HXMU050DA/M72 500 GB USB 2.0 Hard Drive
My SO dont recognition samsung hxmu050da - Samsung HXMU050DA/M72 500 GB USB 2.0 Hard Drive
    President:
  • 1,768 Answers
Several things could be happening here:
1. your electronic controller in the hard case has failed.
2. you didn't properly disconnect the external hard drive in Windows > with the
"Safely Remove Hard ware and eject Media" in the task bar.
3. if you have a power supply to the USB drive it may have a damaged power connector or not supply proper power to the device.
4. the drive may not be supported by the motherboard for your PC.
Posted on Mar 18, 2011
How can I disable VoiceOver?
Return to the initial set up procedure and disable it.
Jan 15, 2016 | Samsung UN50HU6950 50 4K Ultra HD 120Hz...
Tip
Samsung Intensity: How to avoid the voice recognition prompt
The Samsung Intensity has many nice features. It comes equipped with voice recognition software, which many people like. However, for others it is merely annoying. If you keep your phone in your pocket or purse, you might hear a muffled voice saying "Please say a command" from time to time as the phone's voice recognition button is bumped.
Fortunately, you can disable this voice prompt (if you want to) with just a few simple steps:
1. Press the voice recognition button on the upper right hand side of the phone.
2. Press the right options button to go to the Settings.
3. Select Prompts (#5).
4. Select Mode (#1).
5. Select Tones Only (the last choice).
6. Hit OK to save the change.
Now, when you accidentally bump that button, you'll just hear a short single tone, rather than the voice prompt.
If you want to reduce the volume for the voice recognition (either for the voice prompt or for the tone) that can be done easily as well. Follow the steps above to get to the Prompts menu, and select Audio playback (choice #2). Highlight the choice for Earpiece, and hit OK to save your choice.
The voice recognition function will now use the earpiece to play any sounds, rather than the speakerphone, so whether you set it for a voice prompt or a tone, the sound will be much quieter and hopefully you won't even notice it.
You can also lock the phone when you're not using it, which will disable the voice recognition button so you don't have to worry about bumping it. To lock your phone, just hold down the zero (0) key for two seconds. You'll see a message on the screen that the phone is now locked.
on Jul 09, 2010 | Samsung SCH-U450 Cell Phone
My vs840 verizon phone camera stopped working and the voice/speech recognition dont work...what happened?
your little brother was mashing buttons and changed some settings. Restore the phone to factory settings.
Mar 10, 2014 | LG Lucid VS840 4G Verizon
I have Samsung HXMU050DA Portable HDD. My Notebook is feel it, but the Files nothing. "Your Hard Drive is Not formatted! Please formatting now?". I would like to Not lose My Files and datas....
If it asks to format the drive one of two things is most probably
  • The hard drive comes with software used to unlock the drive. If yes run the software and unlock it. If no next...
  • The file system is damaged. You can try repairing the file system by the following
  1. Open a command prompt (Windows key), type cmd
  2. type the following without the quotes "chkdsk [volume] /f" replace [volume] with the drive letter followed by a : so if Im checking drive E then it would be chkdsk E: /f
  3. If your running windows vista or 7 you will need to replace step 1 with (press window key), type comm and right click on command prompt and select "Run as Administrator", click yes.
  4. If you still can't get into the drive then you will need to either format it or just replace it as it is probably failing
You can download this http://www.ntfs.com/disk-monitor.htm and test the hard drives health to help you make a decision of whether or not to replace
Comment back if you need more assistance
Aug 30, 2011 | Samsung HXMU050DA/M32 500 GB USB 2.0 Hard...
I am having problems with my Samsung s2 portable (HXMU050DA) When I fist got it I put loads of films, videos, pics etc on it and it then said I needed to format it, so did so and lost all the data......
You might have a virus in your computer try to format the drive in other free computer and scan the other one with a good antivirus like Nod32
Aug 15, 2010 | Electronics - Others
Is there a way to disable the voice recognition button on my Samsung intensity??? Whenever I go to slide it, I hit the button, and my phone talks, even when i hav the volume on vibrate only.
I have the same problem with my Intensity every time I keep it in my pocket. Unfortunately, you can't disable the voice recognition function completely, but you can make it more managable.
You can get rid of the voice that says "Please say a command" when you hit the voice recognition button, and instead make it just a single tone by following these steps:
- Hit the voice recognition button on the side of the phone
- Press the right option button to go to the Settings
- Go to #5, Prompts
- Select Mode
- Select Tones Only (the last option)
- Hit OK
You can also reduce the volume by changing the output from the speakerphone to the ear piece, to make it quieter. Go to the Prompts menu like you did above, and select #2, Audio playback. Set it to "earpiece" and hit OK.
Now, when you accidentally hit that button, the phone will just emit a short tone that you probably won't even hear. Hope that helps!
Jun 07, 2010 | Samsung SCH-U450 Cell Phone
Hanging
u must be holding on the voice recognition button thats voice recognition and nothin else avoid pressing the button long
Aug 12, 2009 | Nokia 6300 Cellular Phone
Samsung SGH-D900i phone
Hi
sorry bad news this model only supports micro SD cards upto and including 2gb.
Mar 24, 2009 | Samsung SGH-E900 Cellular Phone
Vista Speech Recognition will not start.
Dont worry.This issue can be resolved.I did research on this.Create another administrator account and see whether it works there.I dont have an answer why it is not in this account as i couldnt find one
Mar 17, 2009 | Computers & Internet
Face recognition in java
http://www.ifp.uiuc.edu/~krejcark/Demo/DemoParams.dat
Mar 21, 2008 | Computers & Internet
Samsung HXMU050DA/M72 500 GB USB 2.0 Hard Drive Logo
108 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
