Easy capture is not digitally signed to miicrosoft
    Brigadier General:
  • 10,406 Answers
Companies that write device-driver software can submit it to Microsoft, to be "certified" that the device-driver will work with Windows XP and/or Vista and/or 7.
So, Windows is reporting that the device-driver from Easy Capture has not been through that process, and thus is not "certified".
It does not mean that the device-driver will not work.
If you know that you obtained the device-driver from Easy Capture, then click "install anyway",
despite the fact that the device-driver has not been submitted for certification.
If you suspect that the device-driver comes from a "suspicious" or an "unofficial" source,
then it could be virus-infected.
Posted on Mar 18, 2011
What is the best HDV1080i 50 settings for finale cut pro 5? My easy setup wont let me log & capture.
It complete depends what you are recording in! PAL or NTSC? and how many frames... FCP is customized to your camera settings, match them up and then capture away!
I capture mine using a PC because then you can play around with both MAC and PC editing platforms as MAC captures are encrypted to only run on MAC.
- Scott
Mar 28, 2011 | Sony HVR-Z1 Mini DV Digital Camcorder
JVC GY-HD100 is unable to capture to final cut pro. It shows "no communication" in the log and capture window. But It will capture useing IMovie with no problem. This creates an extra step in my...
You should select the Easy Setup preset that matches the cameras output before capturing.
You may need to start a new project for the Easy Setup to take effect.
Mar 03, 2011 | JVC GY-HD100 Mini DV Digital Camcorder
How do you capture footage on a miniDV cassette from a Sony DCR VX-2100 Digital Handycam on to a PC?
If you have Windows Movie Maker installed, this would be very easy. Just connect the Camcorder via the FireWire supplied. Go to Windows Movie Maker and select CAPTURE from device
Feb 19, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
Tv tuner 1730 stopped scanniong tv channels
If you reinstall the driver and get the message "Driver not digitally signed", you should be able to click on "Continue anyway". Please try this first.
Jul 18, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
How do I ente 8x - 1 over 10 on my TI 84 plus silve edition
I am not sure what the cross (x) means: is it a multiplication or the variable x, so I took a screen capture of both cases.
The top case is obtained as follows the asterisk is the multiplication sign to thr right of digit 9; the small minus is the change sign key the minus sign in parentheses under digit 3 and to the left of ENTER key.; the forward slash is the division sign, above the multiplication sign.
This small minus called change sign makes a positive number negative and a negative number positive, hence its name. If your expression starts with a negative sign that is the one to use. Use it also for negative exponents.
As you can see the result is -.8. Notice how the - before the dot is small with respect to the regular minus, as in the last expression.
For the last expression on the screen capture, there is nothing special, except that you have two ways to enter the variable X.
1. Press [ALPHA] [STO->]
2. Press the key [X,T, Theta, n] to the right of the green [ALPHA] key.
Hope it helps.
If x is the multiplication sign
8[x] [(] (-)1
Oct 06, 2009 | Texas Instruments TI-84 Plus Calculator
VHS to Easy capture to computer
The plugs you speak of are called RCA plugs, (Male side has an outside ring with "slots" around the edge, and a pin in the center. Female side has a short round "riser" with a hole in it). You need just standard Audio/Video hookup cables, available at any electronics store.. Walmart/Target/Kmart has them in the TV section. They get plugged into the Audio (Red & White) OUT of the VCR, into the Audio IN (Red & White) of the Easy Capture. The Yellow lead is for Video In/Out between the VCR and Easy Capture. The black is probably the S-Video connector, (round, has very small square hole, surronded by 4, 5, or 7 tiny pin holes) that can be also used to connect video/audio between VCR(if so equipped) and Easy Capture. Get a set of audio/video dubbing cables (abt $10 usually), connect Red to Red, White to White, Yellow to Yellow. Plug the Easy Capture USB cable into your computer (most likely), start the capture program. Start your vcr, hit Play. You should see your vcr tape playing on the computer screen.
Aug 18, 2009 | Televison & Video
Easy capture
Syd...I'm not sure what exactly your looking for...so I found this site for a free download...as far as i can tell i did not install it ..obviously...but anyway
http://www.tucows.com/preview/502111
And if you want to pay for the software
http://www.filesland.com/download/easy-capture.html
interestingly they have the Easy Capture and Thumbnail software (that I gave you the link to up above) for $19.95.
Hope this helps...good luck...please rate me....The Fang
Mar 24, 2009 | Lenovo 3000 Y410 Notebook
Use of digital camera Lumix DMC-LS70 as a web cam.
It will not work through USB like a standard webcam. Ls-70 only lets you access camera memory card/onboard memory when connected via USB.
However you could connect the camera video-out socket to a PC with graphics card with video capture function. Some cards with video capture work with skype (check this URL:
http://forum.skype.com/index.php?showtopic=41101 )
There are also various software solutions which can fool your webchat client into thinking that video capture stream is actually an output of a usb webcam. (Try google for "video capture into skype".
At the moment this seems to be the only easy way to use LS-70 as webcam.
Good luck,
Raf
Mar 12, 2009 | Panasonic Lumix DMC-LS70 Digital Camera
My TV capture card have the problem saying, TV Capture card MFC Application has encountered a problem and needs to close. we are sorry for the invconvenience. Plz tell me how could i solve this problem
you may have a virus or a worm
if this is new 2008 the drivers are digitally signed and your o/s may need an up date
if it is old your program mey need update
check maufacturers web site for newer version
Jan 02, 2009 | Philips TV Tuner Video Capture PCI Card -...
Transferring analog to DVD
I envisage two options for you: 1. Install a video capture card in your pc. Choose one that has ports that match your analog camcorder ports. Best option: Separate capturing using S-video + a separate audio connection. Common and simpler option: Campture "composite" video using one video + one audio jacks. You don't need a new camera to make DVDs from your analog tapes. 2. Buy a pass-through (must be this type, not all digital cameras have this function!) digital camera. Connection and flow: analog camera (or your analog VHS VCR)to digital camera (via RCA cables); digital camera to pc (preferably using Firewire)- all simultaneously. Here, the digital camera will perform the function of a capture card. You will certainly need a software to capture via capture card/pass-through digital camera to your pc hard disc. Your captured video on pc can be initially in AVI/ DV AVI(better options to edit) and then convert to MPEG2 (DVD) format, or directly in mpeg format (with poor editability). Frame size (capture resolutions) should be as big as possible. In any case you will need some basic knowledge on digital video, capturing, and editing. And all the nitty-gritty that you will need to know can be found somewhere like "Digital Video Primer" and "DVD Primer".
Sep 06, 2005 | Panasonic AG-185 Camcorder
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
