Question about Dryers
The dryer runs but dont heat up i changed the heating coil but it still wont heat up need advice
  • Dan Sharpe
    Dan Sharpe Mar 18, 2011
    Model # please. Should be on a tag on the panel behind the door.
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Mar 20, 2011
Why wont dryer heat up after changing out coil ?
most dryers are 220. its possible your breaker is half tripped. try cycling the breaker.. you should get 220 across it while its running. (Be careful).
Sep 09, 2015 | Haier Dryers
Heat turns off while clothes still wet
change the gas coils on the gas valve by removing the 2 screws holding the bracket for the coils,remove the wire harnesses to each coil,dont worry one coil has 2 wires the other has 3 so quite hard to reverse
Jun 16, 2012 | Kenmore HE5
Gas dryer, runs fine for maybe 10 minutes than the heat goes off and doesn't come back on...change the thermal kit and no fix
The reason your gas heated dryer starts off heating ok,but a part way through the cycle it is no longer heating as it did when it started,is beacuse the coils that open the gas valve are getting hot and breaking down when they are warm. At start up of cycle the coils are cool,but when the dryer heats up as it runs the coils that are weak can not handle the heat and do not open the gas valve. Replacing the gas valve coils with fresh,strong ones will open the gas valve the entire duration of the drying cycle. All appliance manufactures use the same exact gas valve coils and label them with their unique part number. Having been in the service business i know they are all the same and the part number for the least expensive gas valve coils is 279834
They can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
midwestapplianceparts.com
To replace the coils,remove bracket over them(dont worry about where it says dont grip thats for when dryer is plugged in) unplug them and install new ones,that bracket has notches in it and the coils have tabs that inter lock so they position them self exactly where they fit.
This is what the coils looks like
Aug 25, 2011 | Dryers
The drum turns. It heats up. But only small loads of cotton get dry! We have changed the vent tube. Vacuumed the vent the lint catcher area and around the drum to remove lint and hair. Still not...
A very typical problem with GAS dryers is the soloniod coils that open the gas valve . When the coils are cool they operate just fine,but once the dryer gets warm from running the coils dont open the gas valve wwhen they are warm. If that is what your experiencing,the dryer heats when its cool but doesn't heat when it's been running for a while,the coils on the gas valve will need to be replaced.
GENE
Aug 16, 2011 | Roper RGX4634KQ Gas Dryer
No heat in my compact dryer.
there is only 1 reason as to the unit still running but not heating if its running then all thermos must be intact so it has to be the heating coil take the unit appart make sure the two heating points still have the cables attached if you can do a polarity test on the element that will define its blown then replace the coil in most cases when the coil blows you can see a burn mark were it did
best luck
please take the time to rank this advice
merry christmas
Dec 22, 2010 | Avanti Dryers
Dryer is running fine but no heat????
best luck
merry christmas
Dec 07, 2010 | Kenmore Dryers
My electric dryer wont heat took off the coil part
There are 2 things in series with the heating element.
One is on the element housing. One sets the amount of heat and the other blows out if it gets to hot from things that block the air flow.
Nov 03, 2009 | Dryers
No heat in dryer
What you have is probably some intermittant gas coils. they get hot and quit. later they cool down and work a little more. I have the pictures and advice right HERE
NOTE: here is ever more WISDOM
Apr 09, 2009 | Whirlpool LGB6300 Gas Dryer
Quits heating
umm. what was original problem that made you change coils to begin?? no heat i would imagine.dont rush to judgement thatyour fix didnt work, if your running the dryer empty to test your repair,its quite possible that the dryer is going to heat to desired temp quickly, and take a while to cycle back on. throwsome wet clothes in machine and test it then.
Mar 05, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer lights, heats up some but wont relite
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperately from any appliance parts retailer.
This worked for my dryer.
Feb 06, 2008 | Whirlpool LGR5634L Gas Dryer
Dryers Logo
37 people viewed this question
Top Dryers Experts
