Question about Microwave Ovens
Can this dishwasher wich is from france be used in england
    Brigadier General:
  • 3,006 Answers
You didn't state a make and model, but the voltage and AC frequency isn't a problem and French mains water pressure is very similar to the UK so it shouldn't be a problem. The mains plug will need to be changed though, but it's only ten minutes work to do that (don't use an adapter: very few are deigned for appliances with powerful heating elements like a dishwasher has).
Posted on Mar 17, 2011
Where do I find manual for Sharp Model SPC314 clock?
As an answer I post often.
Micro waves are now throw away items , but if you want to go down the route to fix in England you need a REETRA qualification .
Next go to a parts centre , show your REETRA then you will find all you need.
Oct 14, 2014 | Microwave Ovens
I bought my nespresso magimix in France and now I am living in japan. It's humming quietly but not making any coffee. Would ot have anything to do with the voltage?
Hi, I would say so. You may have to get a voltage ( transformer). France they have 220v and in Japan they have 100v . Good luck.
Aug 12, 2011 | Microwave Ovens
My maytag dishwasher's "clean light"
If this is a Whirlpool manufactured dishwasher, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat related problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccurring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel.
If you still need assistance, please post back and let me know
Jul 26, 2011 | Microwave Ovens
I have just purchased this appliance from the local Hospice shop. It has the top pressure balance knob thing (if this is any help) but I have no idea how to use it. There is alot of information on sites...
Just sounds like an old school pressure cooker. Look up Pressure cookers online and you should be able to find instructions. Try looking up this, is this what you have??
Presto 01362 6-Quart Stainless Steel Pressure Cooker
Aug 24, 2017 | Microwave Ovens
The microwave is working except it doesn't heat up whatever you put in it. Could this be a problem with the way they installed the vent system
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 19, 2011 | GE JVM1540DM Microwave Oven
Did Thermador range model ESC30 require 240 volts?
I searched this model,but all i could figure out is that it requires a 3-wire 40 amp cord .wich i believe is used for 240 volt applications.sorry couldnt be more help
Oct 11, 2010 | Thermador Microwave Ovens
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Microwave Ovens Logo
14 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
