Question about American DJ Tri Phase Led Lighting Dmx Proaudiostar Nyc
Parts for american dj tri phase no sound attvation mic is fine
  • American DJ Master
  • 5,603 Answers
Usual problem is unit hasn't been put into sound activation mode. Make sure the display says:
"SOUn" and select the "on" in that mode.
Posted on Mar 18, 2011
  • acesteve Mar 18, 2011
    wot ! yes it is where can i get a new part
  • Fred Yearian Mar 18, 2011
    If the optocoupler has been damaged, take the number that is marked and search at
    http://www.digikey.com/
    The part MAY be surface mounted and it takes a bit of skill and care to replace it. The parts ae small and it is easy to install some backwards.
    Before you replace it however, do check the wiring of the DMX connectors. Some of the stuff coming through has not been tested and I have seen wires reversed... compare wiring to a working unit. Also sometimes the wires break. The boards that are mounted with the connector leads directly attached to the board OFTEN have broken solder at those points... resolder suspicious joints.
Appears that the 3.5MM input jack (for my ipod) is loose/broken. How to replace it?
to do that you'd actually have to disassemble the unit. ( start by removeing scews on the bottom ) and dropping out the pc boards that hold the jack or are in the way of the pcb with the jack on it. at which you'd just have to un-solder old jack and install replacement and reassemble and your done. you cann call american audio to find distributers of their parts.
Sep 05, 2011 | American Audio CK 800 MP3 CD PLAYERS SOUND...
I have an American DJ Hyper Gem LED light and have used it at 4-5 dances...its okay in small halls, but I have a friend that also bought one and his is super bright and throws the effect far, mine does...
Uncover it... you will probably find that some of the LED's are not lighting. OFTEN soldering on circuit boards OR a bad LED in a string kills several like Christmas strings. More than this you need to be somewaht adept at electronics to repair it.
Jul 02, 2011 | American Dj Hyper Gem Led 4way Led...
Hi there, I have an american DJ Dekker LED. I plugged it in and put it into Sound active / sound to light mode. I'm getting response to sound because I can hear and see the fan inside the unit...
I have OFTEN found that a cable has come loose. Open the unit and look for such a situation. Also make sure the motion (probably a disc) is working/rotating since with high power LED devices, they have interlocks for safety to keep beams moving.
Jun 24, 2011 | American DJ Supply American Dj Dekker Led...
I have two American DJ Emerald Scans. One of the lasers is not as bright as the other. What can I do to fix the problem?
Often mirror adjustments get knocked out of alignment. Open and check for this. Carefull of eyes from laser.
May 26, 2011 | American DJ Supply American DJ Emerald Sky...
It doesnt heat , i tested the heater n works fine ,change the termaL DIODE NOTHING HAPPENS, THE WIRE CONTROL ALWAYS HAD GREEN LIGHT ON I HOP YOU CANHELP ME THANKS¡¡
It sounds like you need to take it to a tech. Try a TV repairman rather than a music shop for this, should be cheaper and they will still understand how it works.
May 02, 2011 | American DJ Fog Storm 700 Fog Machine
I am having trouble running an american dj quad gem in dmx mode. I have other lights that are working fine.
If by chance teh light is on the end of a long DMX cable run, read about putting a terminating resistor at the end of the chain. You say you are having "trouble"... that doesn't tell us anything that we could help you with.
Apr 23, 2011 | American DJ Supply American Dj Quad Gem...
American DJ Tri Phase Led Lighting Dmx Proaudiostar Nyc Logo
90 people viewed this question
Top American DJ Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an American DJ Music Expert? Answer questions, earn points and help others
