Question about Shimano Cycling
How do I operate my Shimano Sora Triple gears. I up shifted the rear de-railer, how do I down shift? The front de-railer is not moving?
    Brigadier General:
  • 8,546 Answers
Triple to double crankset, problem with left shifter-shimano ultegra
Derailleurs have a return spring in them that will always return them to the smaller cog (whether it is front or rear). The derailleur cable resists this spring tension. If your front der. is on the large ring and will not shift to a smaller ring then it could be a couple things. First, too much cable tension preventing the spring from returning the derailleur to a smaller cog. Second, you low limit screw is set too far in so the derailleur cannot travel back to a lower gear. This will be evident if you shift to a smaller cog, the derailleur does not move and the cable becomes slack. Third, something else is preventing the derailleur from moving, perhaps the derailleur was moved when installing the new crankset and it is getting hung up on a tooth of the large chainring, there could be some foreign matter lodged in the derailleur spring preventing it from operating, the spring could have broken so there is no longer enough tension to move the derailleur back to it's "home" position. Good luck.
Jan 01, 2018 | Shimano Ultegra Triple Front Derailleur Fd...
My shimano ultegra left shifter is super stiff/hard to push in; what is going on?
Try flushing out the shifter(s) with WD-40, use plenty. The next step will be replacing the shift cables and cable housings.
  • Take the bicycle in an area free of cars and obstacles, such as an open parking lot. Concentration is required when learning to use Ultegra shifters or any other type of bicycle shifter.
  • 2 Mount the bicycle and rest both hands on the proper Ultegra hand control. The left-hand control operates the front derailleur. The right-hand control operates the rear derailleur.
  • 3 Start pedaling, smoothly and evenly. While pedaling is crucial to propelling the bicycle forward, it is also necessary when shifting the derailleur. Pedaling forces the chain to rotate. The chain must rotate before it can transfer to another gear.
  • 4 Push the outside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a smaller rear gear.
  • 5 Push the inside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a larger rear gear.
Rear Ultegra Derailleur Control
  • 1 Push the outside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to larger front gear.
  • 2 Push the inside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to a smaller front gear.
  • 3 Use the front and rear Ultregra hand controls interchangeably. For small changes in gearing, using the rear control. For larger changes, choose the front control. A smaller gear causes the bicycle to travel a shorter distance per pedal stroke but also requires less energy to use. A larger gear requires greater effort but in turn causes the bicycle to travel farther per pedal stroke.
Oct 25, 2011 | Cycling
I need instructions on how to use Shimano Sora STI 9 speed 27 gears total)(integrated with brake levers)
http://techdocs.shimano.com/techdocs/blevel.jsp
Key SORA into the FIND field.
About 5th up from the bottom are the tech docs for ST-3303 levers. Download them both.
Shifting in general...
Google "how to shift a road bike". Many videos.
Good real world advice...
http://www.sheldonbrown.com/gears.html
Find good information on various adjustments here...
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
May 08, 2011 | Cycling
Hi Everyone! I have a Shimano 5603 Hollowtech 2 triple chainring.......(10 Speed) I want to add a Utlegra 6600 front derailleur and Ultegra 6600 rear derailleur. Also 10 speed cassette, Ultegra...
No -
If you are going to use the front triple crankset, then you need to use the 6603 components. These are for Triple set-ups.
If you intend to keep your bike a triple, then everything in the drivetrain must be the triple designation, hence the XX03.
If you want to change the crankset to a compact, then you can use the 6600 (double) equipment, but you will need to change the left (front shifter) to a double as well. The compact crankset, will give you virtually the same range as the triple and be much lighter and shift better.
The cassette: You can use any 10 spd cassette from Shimano or SRAM as long as the rear cog is no larger than 27. if you want to use a larger cog like a 28, then you will have to use the 6700 group, assuming yoiu want to stay with shimano ultegra.
Final Note: Since you are chainging everything, you may want to consider the SRAM Apex group, this gives you more gear ratio than the Ultegra, is slightly less expensive and around the same weight. Great alternative to Triple bikes.
Parts you will need to convert:
Rear Derailleur
Front Derailleur (if changing to compact double or Apex)
Chain
Shifter set (if Apex)
Crankset (if Apex or compact shimano)
Bottom Bracket (if Apex)
The biggest thing is that Shifters and rear derailleur must be from the same company (shimano, SRAM, etc.) after that just make sure that yoiu use 10spd with 10spd, 9 with 9, and so on. Everything else can mix and match.
Dec 18, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
With Shimano 6603 Group can you use Shimano 5703 shifters, or even triple Tiagra shifters?? Thanks for the reply
The answer is yes and no.
The 5703 shifters will work both derailleurs and match the 6603 group as they are both 10spd.
The Tiagra will not work because it is 9spd, it will functionally shift the derailluer but you will not be able to line up the gearing.
The rear shifter needs to match the number of gears on the back (cassette) in the case of the 6603 group that is 10spd, so you can use any 10spd rear shifter from shimano. The Tiagra is either an 8spd or 9spd depending on the model and will not work with the cassette. You can use a 6603 rear derailleur with a Tiagra group, as long as the shifter and cassette are both the same.
Dec 14, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
My shimno sora front derailler shifts perfectly to the small and large chain set cogs, but on the middle, the chain rubs along the cage.
Set the rear derailleur to the lowest gear (big cog) and the front to the lowest gear (small chain ring). Disconnect the derailleur cable. Screw in the adjuster for the cable tension all the way (this adjuster is on the shifter of a mountain bike or the down tube of a road bike). Pedal to make sure the chain is not rubbing on the derailleur cage. If it is, adjust the "L" setting on the derailleur until the chain moves by without touching the cage. Now pull taut and reattch the cable and shift the front to the big ring while pedaling. If it does not shift up well or completely, hold the shifter past its normal shift and adjust the "H" screw so that the derailleur allows the shift. Shift into the highest cassette gear and keep pedaling. The chain should not be touching the front derailleur's cage when you pedal. Adjust with the barrel adjuster until the chain moves freely without touching the derailleur cage.
i hope this helps
-matthew
Oct 30, 2009 | Cycling
Why the derailleur shift automatically while climbing
you need to reset the front Derailleur. there are 2 screws that set the limits. one screw is for all the way one way, and another screw for all the way the other way. when you begin shift to the smallest gear. you want the metal part of the Derailleur to be close to the chain while its on that small gear. then shift all the way to the 3rd cog and set the outer limit with the other screw and your done!
Oct 18, 2009 | Shimano 105 Triple Braze On Front...
Shimano 105. Front derailleur won't shift down
It sounds like you could have two different problems. Your derailleur has become contaminated or your shifter may need to be lubed. Either way, the likely solution is the same. The best solution to get the derailleur operating again is to spray it with GT-85 or PB blaster and manually move in back and furth until it is working again. The same goes for the 105 shifter, spray GT-85 inside the shifter by compressing the brake lever and spraying towards the head of the shift cable. This will solve a non-functioning shifter many times.
The only other problem that fits is the limit screws could be wrong or the deraileur is in the wrong position. This would not be the case unless someone adjusted your derailleur before the ride you started have that problem. Or if the derailleur has moved. Both of which require the derailleur to be fully readjusted.
Hope this helps. Thank you
Jul 15, 2009 | Shimano 105 Triple Braze On Front...
On my bike with shimano ultegra shifters and 105 front deraileur, I can't shift onto the big chainring. The deraileur is not at the stop, but I can't move it any farther. How do I fix that.
Try this first:
Shift into the little ring and release the cable. Pull it tight (with pliers) and re-tighten the cable. It should shift now. If it doesn't, the solution is a little time consuming, so i apologize in advance.
First, flip your bike onto the bars and saddle. Now shift into the small chainring and your lowest cassette cog (the largest in number of teeth). Release the cable from the front derailleur and set the adjustment knob for the front derailleur to its center point. You should find it on your down tube. Now adjust the "L" setting on the derailleur while turning the crank so that its stop sets it in a position where it just skims the chain but does not touch it. Now pull the cable taut and re-clamp the cable. Shift into the middle ring and shift the rear derailleur to its highest and lowest gears, making sure the chain does not rub the front derailleur. If it does rub (it will be in either the lowest or highest cog on the cassette), adjust the front derailleur by way of the adjustment knob to clear the rub. Then shift into the big ring and you should have no problem. Set the "H" stop if necessary.
Jun 23, 2009 | Shimano 105 Triple Braze On Front...
Cycling Logo
265 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
john h
Paul Bade
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
