Question about Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer
What size box should i build fro two pioneer 12inch speakers 1200watts each
    Guru:
  • 256 Answers
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches.
Posted on Apr 24, 2011
I don't get d true bass quality from my car system...
Firstly, If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 13 inches x 13 inches x 13 inches.
May 14, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
May 04, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What is the recommened air space for kicker comp vr sealed do you know the specs for building a sealed box
Really it all depends on how you want them to sound, and to be set up. There really is not specific air space, but there are general air spaces that work, and some times the manufacture will list some specs for different set ups. It also depends on the size of the sub, which you did not specify.
Kicker recommends as follows.
0.4 cubs per sub for a compact box, and 1.8 for an SQ box. SQ stand for sound quality.
So if you want a small box, do .4 per sub. If you want a better sounding box do 1.8.
Rule of thumb and something to think about.
The more air space in the sub, the less power you can run, the less air space, the more power you can run.
For example you can run 200 watts RMS per sub at .4 cubes, but only 140 watts RMS with 1.8.
As well, the smaller box will be louder, But not sound as good.
Dec 24, 2009 | Kicker CompVR 05CVR84 Car Subwoofer
Spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
Dec 16, 2008 | Pioneer TS-W125C/DVC Car Subwoofer
Cubic inches of a Audiofonics 12
You should be able to download the owners manual for these speakers. The manufacturer will give detailed specs. on the type and dimensions of recommended enclosures for this particular speaker. If nothing is available to download, you could try to contact the manufacturer directly.
Jan 03, 2008 | Audiofonics ADF-272 Car Speaker
Sub box inner space measurements in inches
First off I have some questions to ask you? what size are your subs and what is the max power on them and the brand name?
Dec 18, 2007 | Car Audio & Video
Pioneer ts w33c
Recommended volume for these speakers is 1-2 cu ft each speaker. Best materials are marine grade plywood and epoxy resin/matting. decide what space you think you can spare and see if you can make a box that will be about the right size in the space. always try and leave as much space behind the speaker as the speaker takes up from the front. look at the link below for some ideas of the ready made boxes you can buy. http://www.pioneerelectronics.com/pna/v3/pg/album/compare/0,,2076_310069931,00.html the speakers you have will need at least 2 one inch ports each in the back of the box, or equivalent. completely sealed can have bad effects on these speakers at high volume. I personally recommend keeping both subs in a seperate box completely, but a good solid box with a divider will probably work - make sure that no holes of any size exist between the two as this will cause distortion with certain channel set ups and is best avoided although some good results have been achieved with back flow between sub sets - it is a bit too hit and miss to be worth trying. If you need ideas how to fit these into your car so they look good - check out http://www.mtv.com/ontv/dyn/pimp_my_ride if you haven't seen it, check out a few episodes and you will get some great ideas and construction tips. Hope this helps :)
Mar 08, 2007 | Pioneer TS-W33C Car Subwoofer
Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer Logo
532 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
