Question about Pioneer Car Audio & Video
I like to know the rms on Qreference series by alphasonik QW10
    Sniper:
  • 50 Answers
Max power is 400 watts. Rms power is 200 watts.
20 year car audio/video installer
Bay manager
Posted on Mar 18, 2011
Alphasonik 12 inch series 800 is not working. I'm not sure what's wrong with it
Have you tried to hook up another sub (spk) to the amp? Or just wire it to a stereo to see if it works? single voice coil or dual?
Aug 15, 2016 | Alphasonik Car Audio & Video
I need to know how to hook up an alpine v12 amp 2 ohm i have two tens
This really depends if your 10" subs are 4 ohms each or 2 ohm - for this exercise, I'm presuming they are 4 ohm each.
You already know your amp can deliver 600W RMS (@ 2ohm), so you need to be careful you do not exceed the maximum RMS input power of your subs.
Normally you would wire subs in "parallel", which would reduce the circuit load to 2ohms - however, the 600W RMS power may be too high for your subs to handle.
In this case, it may be safer to wire your subs in "series" - this will increase the circuit load to 8ohms, which will effectively decrease the amps RMS power output.
Cheers,
Sep 05, 2011 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
I would like to know if I need a special plug to bridge the amp and were can I buy the owner manual
I just got an alphasonik pma800da today, it came with the cord you are talking about. Looks like a phone cord, its to hook up 2 of these amps together. I also have the book to the amp
Dec 26, 2010 | Alphasonik PMA800DA Car Audio Amplifier
I have an alphasonik pma600hca everytime i power it up it goes into protect rite away???? Any ideas???
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 21, 2010 | Alphasonik PMA600HCA Car Audio Amplifier
I have 2 positives and 2 negatives on back of my alphasonik sub, do i connect amp to one side or both sides?
Hello gaz69,
Your PSW815 has 2 ohm dual voice coils allowing you to better match the impedance to your amp. Each voice coil is 2 ohms. If you wire them in parallel (both +'s together and both -'s together and then to the amp terminals), the sub presents a 1 ohm load which is too low for most amps. Wiring the voice coils in series (one + to the other - and the remaining + and - to the amp terminals) results in a 4 ohm load.
This link shows the wiring diagram for both options. If you know for sure that your amp is 1 ohm stable, use Wiring Option #1. If the amp is not 1 ohm stable, use Wiring Option #2.
Hope this helps.
Aug 09, 2009 | Alphasonik PSW815 Car Subwoofer
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Alphasonik amp is getting power but no power to subs
either your rca inputs are bad or your mosfets are bad
Jul 05, 2009 | Alphasonik PMA1000D Car Audio Amplifier
How to wire pma100 voltmeter without amp
Hey dude- if you dont figure out how to wire that thing up -i need one for my pma-2500a i got it from the pawn shop yo for 150 bucks !!!!!!! shwinggggg its a beast 1600 rms at 4 ohms bridged - what a steal but yea i need one so lets make a deal dude !!!
Jun 06, 2009 | Alphasonik PMA1000HCA Car Audio Amplifier
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
Car Audio & Video Logo
105 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
