Question about HP PSC 950 All-In-One InkJet Printer
Every time i try to scan, there is a error message SMTP ERROR.
    Master:
  • 325 Answers
Sounds like you are trying to email rather than scan, I think your pressing the wrong button. try selecting scan from your start menu instead.
Posted on Mar 17, 2011
Can't send message from outlook express just receive the following:The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was...
It is possible that your OS is infected with a malware or virus. The outlook files could be affected and so it might be necessary to reinstall the OS and the outlook once again, then configure your settings with the mail id and password so as to receive and send from your server.
Try and scan the PC for possible virus , run a check to confirm for registry files loss.
Oct 01, 2011 | Acer Computers & Internet
I tried the scan to email feature of lexmark x544. I get an error message on the SMTP gateway. Is SMTP gateway the same as incoming and outgoing server?
SMTP is the outgoing mail server. If you're getting a error on the smtp gateway, please verify with email provider and check what is the correct outgoing mail server
For further assistance, please contact Lexmark Technical Support
Jun 07, 2011 | Lexmark X544dn All-In-One Laser Printer
My dpc356 scanner error 716 comes up once document scanned
incorrect smtp server address is set. these error messages are very accurate. check all ip address settings, ip address, subnet mask and gateway as well as smtp.
Apr 15, 2010 | Panasonic DP-C354 Copier
We cannot scan to email from our Sharp AR-M237 Multi-function "Error[973]: Incorrect format for Primary SMTP Server." I am using all the settings for SMTP that I use everywhere else. HELP?-pjm
Model AR-M257 - I have several Sharp MFP devices at different locations and all are set up to scan through our email server using a special account I have just for this purpose. I have all of them setup using the external IP address of our Exchange server (not its name or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this one. I was getting the following error when trying to send a status message (under Log) from the device to my email account as a test: [error 973] incorrect format for primary smtp server. And when I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and DNS but as I was trying anything I could to get it working I went to mDNS under Services and it was enabled. I disabled it and then I could get a status message to be sent to me and we could send a scan through our email server.
Apr 12, 2010 | Sharp AR-BC260 Color Copier
I get sending error 0x800ccc80 when trying to send messages...But all messages are send once or twice a day at random times...otherwise they sit in the outbox
Outlook 2007 is stricter than 2003 about SMTP authentication. It could be the case that 2003 tried automatically to connect without authentication when authentication failed, while 2007 throws an error.
Please verify the settings for authentication in your account, and uncheck the box “My outgoing server (SMTP) requires authentication", on the "Outgoing Server" tab.
Mar 18, 2010 | Microsoft Office Professional 2007 Full...
Scan to email gives server response error in home network. SMTP server tried by IP address and DNS name. Port 25 Authorisation POP for SMTP. The other authorisation types give a network error straight...
I've just discovered that Ricoh's built in software only works if your SMTP server sends out without picking up password or authentication.
Having same issue and it worked fine when it was behind corporate firewall with the same connection settings (IP address) as the SMTP server.
Once I changed web hosting - it won't recognize the SMTP server or any authentication methods. According to IKON (Ricoh support for the USA) - your SMTP server has to have "relay exception"
Feb 20, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
Oct 20, 2008 | Konica Minolta bizhub C250 All-In-One...
Outlook Express Setup - error message
contact comcast and get the pop3(outcoming) address, and the SMTP (incoming) address
"mail.comcast.net seems correct but the outcoming smtp.comcast.net seems wrong.
Oct 13, 2008 | Microsoft Windows XP Home Edition
Ricoh Aficio 1075 - SMTP error message
To use the scan to email function on your copier you need some settings from your internet provider (email setting specifically). Go into Outlook options and get your SMTP server, user name and password.
On your copier you need to change under User tools, system setting and file transfer and put these settings in. As long as your machine is set up for scan to folder thats all you should need.
Apr 18, 2008 | Ricoh Aficio 1013F Copier
Brother MFC-420CN USB All-in-one
It is not a big problem, you first need to refresh your internet settings. Click on internet icon, scroll down to properties, click on advanced, and down the bottom on refresh or rest, ok, now turn pc off, restart and go again. I f this does not work, email me at amethystgerry@bluemaxx.com.au
Aug 15, 2007 | Brother MFC 420CN All-In-One InkJet...
HP PSC 950 All-In-One InkJet Printer Logo
50 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
