Door error on maytag front loader washing machine
We pulled the yellow tag ( bottom right hand corner ) can it be reconnected as the washine machine just comes up with the error code and won't start !
  • 770 Answers
That is the emergcy door release once the door is closed it will eset it self what is the Model Make and code you are getting
Posted on Aug 02, 2008
I have a Maytag 3000 front loader. It looks the wash is done but I cannot open the door
Unplug the power. Wait 2 minutes, then reconnect the power. You should be able to open the door.
Alternatively, you can UNPLUG the washer and remove the bottom front service panel. Carefully reach up along the inside of that front panel and pull down on the manual release tab that is on the bottom of the door latch assembly. You should then be able to open the washer door. If this doesn't work, you will need to call Maytag for assistance.
Apr 19, 2017 | Maytag Washing Machines
How do I open the front of a Meile W911 Front loader
remove soap draw, remove screws on left hand side(T20), open drum door, three 10mm bolts around drum, open filter flap and unhook black hose from flap if there is one, the bottom left hand corner sits on top of a metal clip to hold it in position just pull to remove,
Sep 18, 2014 | Washing Machines
How do I take the loader part of a Maytag PAV5158AWW out to get to the motor
I'm not sure what you mean by that but I'll tell you how to get to the motor. What your going to want to do is remove the front of the washer, which if I remember right has two screws in the front near the bottom. Then you pull the bottom out towards you and thats it. The motor will be right in front of you on the right hand side. The belt that drives the pump and transmission by means of the motor is under the washer, so just tilt it back. The belt rolls on and off easily.
Apr 29, 2012 | Maytag Washing Machines
Washer door latch will not open. there is no power to the machine at all. outlet works.
If you remove the bottom panel in front you can reach up on the right hand side to near the middle of the door you will feel a tab coming out of the door lock switch. Pull down and the door should release.
Oct 25, 2010 | Maytag MAH8700A Front Load Washer
We have a Kenmore Elite front loader and yesterday while washing a load of laundry, the lights flickered and then the machine turned off. I checked all the breakers, unplugged and replugged and nothing...
There is a pull tab at the bottom of the door latch assembly that can be used as a manual release for the door by pulling it down.
Lean the washer backwards and unscrew the 3 screws under the bottom edge on the front of the washer to remove the lower panel under the door. Once the panel is removed, reach the tab with your hand up inside the washer behind the front casing on the right side and pull it down. The door will open.
If there is an error prior to the jamming of the door, the door latch assembly must be replaced. Feel free to let me know if that is the case.
Dec 01, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool washine machine #AWM 3082 - door wont open
Try to unplug the unit for five minutes, then plug back in. Try to start a load, as soon as the door locks agian, hit cancel. That will sometimes let you get back in. Im not sure if this is a top loader or front loader, but there is a way (if its a front loader) to remove the bottom front kick plate, then you have to reach up the inside to the door latch assm, on the bottom of that is a small round handle, pull it straight down, and the door will unlock. If its a top loader (i.e. Cabrio, Oasis, Etc), you can open the top only by unclipping the top from the base. You can do this by putting a putty knife in between the top and cabinet, then finding the clips, pushing them in and lfting, you can get your stuff out that way.
Nov 16, 2008 | Whirlpool LHW0050PQ Front Load Washer
Maytag neptune MAH 9700 AWW - error code nd
you need to remove the front cover by removing th escrews holding on the door hinge nad 2 other screws oppisite the hinge, after taking off screws the front "u" shaped panel will pull foward and off( hoeld on by 2 clips along the bottom. the drain pump is located right back corner of machine..ill assume that the machine is still full of water so youll need ot **** out as much as possible before removing the hose connected to the pump. theris going to be some water no matter how much you remove nut might as well get as much as you can. youll either find debris in hose, or debris lodged in imoeller of pump, even seen coins standing in the plastic hosing preventing flow of water.VERY< VERY rarely bad pump ussually just a clog.IMPORTANT UNPLUG UNIT FIRST LOTS OF LIVE WIRES UNDER HERE
Nov 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Maytag Neptune Washer Door Locked
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Clean the drain by opening the door on the bottum left.
Use the yellow plastic thingy in the front of the soap drawer to do it.
You can open the machine door by pulling the yellow tag in the bottom door.
Drain the water through the filter, clean the filter and close.
Then unplug the machine and tilt it forward by about 1 foot until you see water coming out of the bottom (put towel on floor).
Plug back in and voila!
I do think that this machine is a major pain. No spin cycle and this kind of stuff to go through. Anyone want to buy mine?
Dec 24, 2007 | Miele Touchtronic W1213 Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
