Question about Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut
The back wheels want go cause somethings locked how do i fix that?
    Brigadier General:
  • 3,911 Answers
The hydrostatic transmission has failed. about 1200 for a new one and the mower is only worth 250 running. sell the mower AS IS on eBay and buy a new one.
Posted on Mar 17, 2011
Steering wheel is not straight, and I have an appointment for getting a wheel alignment, and my question is that will the wheel alignment also fix my steering wheel to be back straight and normal ?
A wheel alignment will help if that is the only thing causing the car to go right. If you have hit something , like a curb it could have bent or broken something in the front end. The wheel should return to straight if the alignment is all that is needed.
Oct 21, 2017 | Cars & Trucks
WHEEL BEARING REPLACED NOW THE AWD AND ATL LOCK LIGHT ARE ON AND MY CAR WONT GET PAST 30MPH, IF I TRY TOO FAST
Buick Rendezvous Service Traction system and Anti-Lock warning ...
forums.edmunds.com > Buick > Buick Rendezvous
Jul 15, 2007 - 31 posts - ‎19 authors See Also: Buick Rendezvous FIX Trac Off ABS warning light DTC sensor hub wheel.... For the service traction,ABS,AWD lights it may be a wheel speed sensor (also .... I drive a 2004 Buick Rendezvous with about 120K miles.Missing: atl
Sep 12, 2015 | 2004 Buick Rendezvous
I just had my transmission fix and I need to know why is my back wheels locked up on my taurus
The rear wheels are not connected mechanically to the engine. They are passive. Most likely cause: someone used the emergency brake and the cable is stuck and won't release. Has to be something to do with the braking system. Check coolant level for the engine. If there was air in the system it is possible they thought it was full, but it wasn't really even close. Factory thermoststat with the check valved vent hole should be used to help prevent this issue.
Sep 22, 2014 | Ford Taurus Cars & Trucks
Rear wheel locked up
What type of vehicle ? Check Emergency brake cable.
Jun 16, 2013 | 2002 Chevrolet Monte Carlo
My key wont turn. ignition is locked. brakes and wheel are all locked. had it happen before fixed it but cant remember what i did.
If the steering wheel lock is engaged with the wheel turned sharply in either direction - weight of the vehicle at rest on the wheels can cause the steering column and ignition key lock to bind. To get the ignition to turn and unlock, you may have to grasp and turn the wheel or wiggle it a little back and forth to get it to come off the steering lock. This will relieve the pressure and allow you to turn the ignition lock if done right.
May 10, 2010 | 1998 Chrysler Sebring
My 2005 dodge neon made a clunk noise and then the passenger rear tire locked up. Up until this point it drove fine. Help!
Your problem would appear to be something amiss in the rear brake on the locked wheel. If a wheel sylinder was leaking the brake shoes would become "sticky" and cause the shoes to "lock on" to the drum. Or if the brake was out of adjustment, the assembly could come apart and pieces of it jamb the wheel. This problem is fairly common with drum brakes. You need to have the rear brakes serviced, & checked for fluid or grease on the braking surfaces. All leaks fixed, backing plates cleaned, the wheel cylinders overhauled, & the brake shoes replaced.
Mar 20, 2010 | 2005 Dodge Neon
97 Acura cl abs light on? What does this mean and how to fix
This indicates a problem with the anti-lock brake system, make sure fluid levels are correct, but it is likely that a sensor at one of the wheels has disconnected, causing the light to go on. If you have driven over road debris, snow, ice, etc. something may have damaged a sensor at one of the wheels. Jack up the car and support it to safely go underneath to inspect all 4 wheels at the back sides for damage.
Dec 18, 2009 | 1997 Acura CL
My back tire locks up on my 4x4 pic up on my Mazda b4000 4x4 1996
U MUST REMVOVE THE WHEEL TO CHECK THE BRAKES FOR OIL CONTAMINATION FROM A POSS LEAKING AXLE SEAL.
Nov 11, 2009 | 2007 Mazda B4000
Rear wheel locks down
Have rear brakes checked for improperly adjusted, as well as emergency cables partially seized. Backing up and stopping quick, frequently, can also cause self adjusters to operate & tighten things up too much.
Oct 06, 2009 | 2002 Kia Sportage
Rear wheels not spinning. Front wheels spin when in 4 drive.
Hi First of all check the adjustment on the rear wheel thats sticking sometimes the brake pad comes away from the metal it is fixed to this maybe the case on your vehicle, the make & year of vehicle would help further but I a sure you got something to check now. Please leave me feedback, Malcolm Campbell.
Sep 23, 2017 | 1994 GMC Sierra
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Logo
228 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
