I had to manually unlock my washer when it wouldt cancel for me, so now i can open door, but when i plug machine back in it locks and makes draining noises again, nothing else but draining
    Sniper:
  • 88 Answers
A model number would help a lot, but I'll take a shot at this. Typically, when a washer locks out, requiring a manual unlock, it does so after the machine fails to drain within a specified amount of time. So, that being said, if your machine does not have water left standing in it, there is a good chance you have a bad pressure switch, which is telling the control that your washer is still full of water. With many models, one way to test it would be to disconnect the wire harness from the pressure switch, then try to start a cycle. If the washer then begins to fill normally, replace the pressure switch. Before jumping to the pressure switch though, make sure ALL the water is drained out of the washer, and unplug the machine for several minutes to allow a CCU reset.
Posted on Mar 17, 2011
I can't open the door on my front loader
If you take to top off and look down where the door lock is there will be a circular plunger on the bottom. pull it down and you can manually unlock the door.
Feb 14, 2015 | Samsung WF337AA Front Load Washer
The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
More common issues with the door lock.
Is water hooked up to the washer?
The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
Jun 10, 2011 | Washing Machines
Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
Hello there and thank you for chosing fixya
Here is a few things to check before you do a manual opening of the door
You may have already done these steps but please try this again in this order ok?
Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
UNPLUG THE MACHINE
Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door locked.... tried to unplug and cancel button - still not open??
Try holding end cycle button for 30 seconds if no. Then try reset process Press "Pause/Cancel" two times to cancel the cycle. Press "Drain/Spin" if there is water in the tub. Unplug the or disconnect power for two minutes, then plug the washer back in or reconnect power.If no then here is the manual open process. Unplug the power cord of the washer from the outlet. Locate the toe panel. This is the section of metal at the bottom of the front of the washer, directly below the door. Remove the three screws on the bottom flange of the toe panel, which connect it to the washer. Lift the panel slightly and pull it forward to remove. Manually unlock door Reach up inside the front panel and locate the door latch assembly on the right side of door.Feel for a tear-drop shaped tab on the bottom of the door latch assembly. This tab will manually unlock the door.Gently pull down on tab about 1/4 inch or until you hear a click. The door should open.
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I want to unlock my door
Manually Unlocking the Door Lock System
1. Unplug washer or disconnect power. 2. Remove the lower kick panel. 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a ¼" or until a click is heard. 6. The door may be opened.
Apr 12, 2010 | Kenmore HE2 Plus Front Load Washer
Door won't unlock
try the cancel button it will drain the water and release the lock
May 30, 2009 | Maytag Neptune MAH9700 Front Load Washer
Control lock light will not go off.
Do you have any error codes?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Door locked light stays on so cannot open door
Make sure that all the water has drained or the door will not open, lay the hose into a bowl or other shallow vessel and let any remaining water run out. Wait a for a while for lock to release,if it still does not open then the door is going to have to be opened by force.
Plz rate this solution.
Thanks
Dec 16, 2008 | Hotpoint Aquarius WD63 Front Load...
I get an error code: F dU and my washer won't drain properly
I too, had the same issue with the door not opening. My solution was to unplug the power cord and then plug it back in and press the green button's as if to start a cycle and while it starts putting water into the washer I put my knee and weight into the door lock area and held pressure from my knee and press the red stop button until the lights went out, and I took my knee off the door lock area and opened the door!!! No taking off the lower panel.
If this works for you too please email me email4millers@cinci.rr.com.
Nov 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
