Question about Casio MTP3050D Watch
How do I adjust casio module no. 3050 watch band-steel
    Novelist:
  • 117 Answers
Your casio MTP3050D 2AV had a module number of 2719.
If your looking for module 3050 here is the link.
If your looking for module 2719 here is the link.
I hope this will be able to help you.
Thank you for choosing Fixya
Posted on Mar 18, 2011
Hey so i just got my new watch and f-ed up already because i adjusted the date and now it wont sync with the days, does anyone know how i can fix this?
Download the instructions from the Casio web site and look for a "master reset" You'll need to get the instructions for your "module" which is printed on the back cover of the watch.
Dec 25, 2014 | Casio Mens Edifice EF129SG-1AV Silver...
How to adjust a Casio Men's Atomic-Solar G-Shock Watch, Stainless-Steel Bracelet
Read the module number on the back of the watch and download the manual from Casio. There is no easy way to explain it. I have been adjusting my Casio twice a year for more than 5 years WITH the manual in hand.
Aug 31, 2014 | Watches
How do I adjust the band on a Casio AQ 160 watch?
try this link below there are several diffarant band adjustments that may help you
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Nov 02, 2012 | Casio Watches
My Casio watch band has split apart where the rubber part holds the main pin to the steel watch band making the band unable to be repaired. I would like to find a replacement watch band.Can you help me?
are you referring to casio mtg900 if so do you mean the rubber part below the G button . If so I do believe casio sells that first link . You can call them if you would like to order it if they still have in stock or for a whole new band
you can see the parts store here
http://www.pacparts.com/model.cfm?CFID=3663724&CFTOKEN=19469938&mfg=CASIO&model_id=MTG900DA-9V&row_start=1&src_model_id=mtg-900&action=list_part
I believe the 12 h and 6 h are the parts you are looking for I am not sure what side you need 12 oclock or 6 oclock , but give them a call they should be able to help you out
the other company that handles watch parts is here
http://www.americanperfit.com/parts/parts.htm
Oct 26, 2010 | Casio G-Shock MTG900DA-8V Wrist Watch
How do I adjust the length of the bracelet (watch band) for a Casio EF106D-2AV bracelet watch?
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Aug 21, 2010 | Casio Edifice EF106D2AV Wrist Watch
    Adjust-a-Casio-S-1087DY-Watch-Band
    On most brands, there are pins that form hinges for the links of strap. You need to push them out to remove links. Usually you would find arrows marked from inside of the metal bracelet which show you the direction in which to remove the pins. You can remove it if you have a small watch maker's screwdriver but you have to be careful. or get one of these ..
    http://www.amazon.co.uk/Watch-bracelet-link-adjuster-remover/dp/B001ZKIL2S/ref=sr_1_1?ie=UTF8&s=watch&qid=1254695541&sr=8-1
    which should help you to remove the link pins safely without scratching.
    Aug 31, 2009 | Casio Edifice EFA110D-1AV Wrist Watch
    Adjust the band links for Casio MTP4500D-1AV ( model #4755 )
    You can tap out the pins in the band with a small punch. a ground off needle may do it
    Jun 22, 2009 | Casio MTP4500D 1AV Analog with Chronograph...
    Band size adjustment
    Try entering Casio`s page and search the manual.
    Jul 29, 2008 | Casio AW80-7AV Wrist Watch
    Repliciment wrist gand for Casio Pathfinder
    you can go to this link and in the upper right corner type in the model number not the module number (there are instructions for finding the model number if you don't know it) I found a band for a watch that is over 8 years old on here.
    http://www.fsiwebs.com/shopcart3/SC_ProdList.asp?
    Jan 05, 2008 | Casio Casual Sports Watch HDC6007BVCF
    Casio MTP3050D  Watch Logo
    862 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
