I have a packard bell netbook and i just purchased a VGA to S-video cable. i want to connect my netbook to my tv. i have managed to do this on my old dell laptop via a s-video cable just fine but i cant seem to do it on my netbook...my netbook does not have the option on the graphics option to switch output to television nor does it pick up tv on the display properties setting. how would i find and select the tv so i can see whats on my netbook on my tv?? thank u
    Master:
  • 325 Answers
You should have a little blue fn button near your shift key and if you hold the and one of your function keys (usualy F5) with a picture that kind of looks like a tv screen shape it should switch between display options
Posted on Mar 17, 2011
How to connect packard bell pc tower to my baird tv
If your tv has an RGB/VGA port on the back, you can use a VGA cable. http://en.wikipedia.org/wiki/File:Male_VGA_connector.jpg
If not, you will need to upgrade the video card in your computer to one that has the same kind of output as your tv's input (HDMI, Component, Composite, ect..) and make sure you have the proper cable to connect them. Once you do that, and you have changed your tv to the proper input, you should your computer displayed on the tv. You may need to adjust the screen resolution on your computer to make it fit you tv correctly.
May 10, 2014 | Computers & Internet
Connect toshiba nb500 netbook to RCA tv win 7 stater with VGA cable and s video no displaying in the monitor tv didn't recognize
Does you notebook shows any connection information after connect to tv. If not you need to install. If this didn't work you have to change VGA cable. If not your notebook doesnot supports the tv
Jan 21, 2013 | Computers & Internet
How to connect my Pavilion g7 notebook to my Toshiba TV
If the TV doesn't have a VGA port, but does have HDMI, purchase a HDMI to VGA cable and insert the VGA into the netbook and the HDMI into the TV. Hope this helps. Get back in touch. Steven :D
Jan 01, 2013 | HEWLETT-PACKARD Pavilion g7t Notebook PC...
I want to connect my sony tritron tv to my hp laptop
If you Sony TV has a VGA video input socket then connect a VGA video cable to the TV and the other end of the VGA cable to the VGA video connector on your laptop.
Power up the TV and go to the Input selection Menu and select PC connector then boot up your laptop and the Windows video data will automatically to the TV.
You can toggle between the TV the LCD or both by pressing Fn key plus F4 key.
May 29, 2012 | HEWLETT-PACKARD G71340US Laptop
I have a TJ68 packard bell Easynote laptop, it will power up, but display screen is black and flickers. I connect a vga cable to an external monitor and can see contents of laptop on external monitor.
The fact that you can see the desktop on the external monitor means your LCD Inverter on the laptop is bad. The video card in the laptop is good, otherwise you would not be able to see the desktop on either screen.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
The lcd inverter can be purchased on ebay for less than $15. It is located at the bottom of the lcd screen. You'll have to remove the plastic strip that is around the lcd screen by removing the plastic or rubber bumpers that have screws under them. Normally there will be bumpers at each corner and maybe along the insides on the plastic strip. Remove the bumpers, the screws and pry the plastic strip off with a little force with your fingers. You will then see the lcd inverter at the bottom of the lcd screen.
Just put your computer's name and model in the ebay search followed by lcd inverter.
Actually it looks like your laptop uses the LED screen instead of LCD so it will not have the LCD Inverter. You will have to purchase a new screen. I found the one below on ebay.
http://www.ebay.com/itm/Packard-Bell-EasyNote-TJ68-AU-065UK-LAPTOP-LED-LCD-SCREEN-/400293582889?pt=US_Laptop_Screens_LCD_Panels&hash=item5d335b5829
May 13, 2012 | Packard Bell Computers & Internet
How do I connect the Acer netbook to the TV?
The only option is using the VGA port on the Aspire One to hook it up to the TV.
Your TV must have a VGA in port for your to be able to hook your computer to your TV. All you need is a regular VGA cord.
Mar 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
Why wot it let my packard bell easynote r4250 connect to a tv through a VGA ports
There is not enough info here. Many things could be wrong. Are you actually plugging the VGA cable into the VGA port on the tv or computer? Does your tv even have a VGA input? Is your tbs input switched to the tv? Please contact me with questions.
Feb 28, 2011 | Packard Bell EASYNOTE R4250 COMPATIBLE...
How do i connect my computer to my tv
you shuld have s-vedio out from your vga card
if have it now you can connect it from the cable coming with card
Dec 16, 2007 | Compaq Deskpro 2000 PC Desktop
Computers & Internet Logo
David Payne
David Payne
