Question about Kenmore Washing Machines
I have a kenmore front loader recently it has decided to stop spinning and retain water. Help?
    Sniper:
  • 88 Answers
Regardless of model, this is probably a drain pump problem. With many Kenmore washers, there is a pump trap that can become plugged. Remove the washer's bottom front panel, if there is a white drain pump casing, turn out the pump trap counter-clockwise, making sure to have a bucket to catch the water. Check and clean the trap, and try to spin the pump impeller, if the pump impeller is stuck, something may actually be stuck in the impeller. If the impeller feels wobbly, you will want to just replace the drain pump entirely. Depending on the model, there may just be a hose connecting directly to the pump, with no trap available, just pull the hose off and check for an item plugging the pump. With any model, there will be WATER that will POUR out. Be prepared.
Posted on Mar 17, 2011
Front loader Kenmore HE3 drains but after several hours water accumulates in the machine. I can then spin it out but it will reaccumulate.
Thye problem is the water inlet valve is hanging up. The valve will need to be replaced. They sometimes get debris inside and stop seating. They are usually inexpensive and easy to replace. Here is a link that should help Water inlet valve replacement
Oct 02, 2010 | Kenmore HE2 Plus Front Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
Stopped working mid cycle. The timer still counts down but does not fill, agitate, spin, drain. And before it stopped, the water that was draining out smelled really bad.
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use quite hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 30, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
Apr 23, 2009 | Kenmore 45081 Front Load Washer / Dryer
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Water won't drain won't spin Kenmore front loader
glad i could help.if you have a chance ,i thank you for you great rating
Jan 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
Kenmore front loader trouble
If it is shutting off after a few seconds is the washer filling with water. If not you may need a water valve. If it fills with water then stops you may have a bad control and $350.00 is not really to bad for that repair. Besides if he is wrong he is stuck with the part not you. If he is correct then your washer is fixed and $350 is alot better than $1200.00 for a new one, so check that water and good luck to you. Mike
May 07, 2008 | Kenmore 44102 Front Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
Sep 12, 2007 | Kenmore 44102 Front Load Washer
Washing Machines Logo
fordexpert
Mike Squire
Robert Rankin
