Question about SanDisk Sansa e250 MP3 Player
Random stop whilst playing music.- puts music on pause & several times has just turned off completly. Can this be repaired , if so where or less expensive to buy another MP3? Also have Sansa Fuze & no problems & have tested above with idendical tracks
  • versii Mar 18, 2011
    Thank you Ezrahite,
    no luck, although I am unclear when you refer to "hod" button ? -Also creating a new folder - ,Where on Sansa Media Converter - no provision there or am I totally on the wrong track ?
    Rgds,
    Sidney.
    sorry, never used the hold button before ! In Case so hidden.
    Didn't get to 1st base - so will toss in bin.
    Many thanks for yoyr help,
    Rgds,Sidney.
    Genius:
  • 1,570 Answers
Yes, this can be repair if you can identify which song corrupting your mp3 player. All you have to do is to plug your mp3 player in a computer and then transfer all the songs there. After, delete all the song in your mp3 player. Then go back to computer where you sve the song and play each song so that you can see which one is corrupted. Unplayable song mean that is the corrupted files that cause problem in your mp3. Check all the rest and then transfer all the playable song. This is what I did before and it surely solve your problem.
Regards
Posted on Mar 18, 2011
  • 2,632 Answers
Welcome to Fixya. You can try to reset the player and see if it will works if not then you need to bring the system to a service center or local tech to check that part of the mp3 that is causing the problem. Regarding the cost it will depends on the problem of the mp3. Try resetting the mp3 first and hopefully it will work
Recovery Mode:
Tturn off the player, move the hold button to the right, and press the on and rec button, then conecting to the computer. When folder opens create a NEW FOLDER (not a text document) called "Sansa.fmt". then disconec the usb and it was fixed.
If you have questions please let me know. Thanks for using Fixya
Posted on Mar 17, 2011
  • Rofel Lantican
    Rofel Lantican Mar 18, 2011
    Just try this first:
    1) Turn on the "hold" function (move slider on top of the player so orange is showing).
    2) Hold down the "Rec" button on the left side of the player.
    3) Power the player on.
    The
    player will enter recovery mode and ask you to connect it to your PC
    via the USB cable. Do this. The player will then display "Enter USB2.0
    MSD mode." Disconnect the player, let it reboot, and reconnect the
    player.
    Your player may now be OK at this point, or it may show up in Windows Explorer as a removable disk. Open it create a NEW FOLDER called "Sansa.fmt". then disconnect the usb and it was fixed.
    If still wont work you might have a bad player.
  • Rofel Lantican
    Sidney if i was able to help you please rate me. accross my 1st solution you will see 4 thumbs. Please rate me so i can help others like you
Is it possible to change the order of the tracks?
When listening to music, you can hit 'M' to access the menu. Whilst in the menu, go down to Repeat. The sub-folder has several different options, among them being Random All on the second page. Though the order it plays songs in does not often differ (i.e. When you click random, it will always play Track 4, then 9, then 2, and so on and will do this again the next time you go into your music selection), it can be useful for when you have prior sub-folders to trade off between.
If you have already tried this, you can also plug your player into your desktop computer and move the songs off of the player via the folders available there. When you re-upload files, they tend to be in alphabetical order, so you can also rename them (i.e. from "Charlie on the M.T.A." to "01 Charlie on the M.T.A." and so on and so forth) to get them in a playlist-style format. If you have more than thirty files in a folder on the device, things tend to become out-of-sequence anyway, so that can add a pleasingly random element to your music.
Enjoy <3
Mar 28, 2016 | Eclipse Fit Clip Plus 8GB* MP3 Player
I have a coby mp-c582 that I bought used for my grandson. I like it fine but am not completely sure of what each button does. The o and x button on the side for instance. What is that one for. I thought it...
You are confused because the buttons have several purposes. The +/- are volume up and down and Next/Previous. If you press and hold the button, you control the volume. Quickly press and release for Next or Previous. The button below them is Pause/Play and Power (again press and hold to power on or off). The switches on the left side are Hold (no buttons work) and Random (play loaded songs in a randomized order)
For the hold feature, move the switch to the padlock. Unlock by sliding the other way. The Random switch has a more obvious label - Random or Normal.
The user's manual for the MP-C582 is available here: http://www.cobyusa.com/files/manuals/MPC582_MN.pdf . If the direct link doesn't work, try the support site: http://www.cobyusa.com/?p=doc and search for the model (MP3 & Portable, MP3&MP4 Players, MPC582.)
I hope this helps.
Feb 24, 2011 | Coby MP-C582 MP3 Player
Put in disk in 360. Play Playonline viewer, but screen goes black, and says cannot read disk, need to clean or restart. I did this several times and same result.
I had this problem recently. What happened was you closed the game without logging out of Playonline. The long shut down I call it. This corrupts the FFXI data on your HDD. And since FFXI does not appear in the memory you have to format your HDD and redownload. I can guarantee if you put the disc in your xbox with no HDD that it will read or even place it in an xbox with a HDD that has never had FFXI.
Dec 26, 2009 | Square Enix Final Fantasy XI for Xbox 360
Sylvania SMP2002 Shuffle?
how do i play the songs on my songs on my sylvania smp2002 mp3 player because it wont play
Mar 09, 2009 | Audio Players & Recorders
Bang & Olufsen Beosound 9000 - CD does not play
gently open cd player clean laser with a cotton bud and wipe all round laser part and lugs at top and bottom of unit
Feb 15, 2009 | Audio Players & Recorders
Forgot how to use my Insignia MP3 player.
Power up:
If the player is laying flat with the screen facing left, you will see a large circle button and two buttons above the circle. The button on left above the circle is the power button.
To start playing music:
Press the button in the middle of the large circle with a small triangle facing the right (the play button)
To stop music:
Pressing the same button mentioned above will pause the music while pressing the power button I first mentioned will turn off the unit completely and stop the music as well.
Nov 30, 2008 | Insignia NS-DV2G MP3 Player
Matsui MAT 140 MR mp3 player
If your Matsui is working suggest you leave well alone -- I've been looking for utilities (new firmware, reflash utility and firmware extractor) and it's all very confusing.
Apart from the ghastly menu system the only problem I've had with mine £8 ($16 used from a flea market) is that Win XP's data write-behind feature means that XP merrily suggests that file transfers are complete when the player is still digesting the files. If you interrupt this by mistake XP stops responding or complains that data has been lost.
Aug 29, 2008 | iLO (2 GB) MP3 Player
Hardisk problem...
Try holding down the play/pause button whilst pushing a paperclip into the reset hole. you should hopefully then get the choice of several options to try. If that doesn't work you could also try looking on creative american website for instructions for other players - some of these work for different models even when not specified. Good luck!
Dec 05, 2006 | Creative Labs Zen Touch MP3 Player
SanDisk Sansa e250 MP3 Player Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
