Running Windows XP Problem with HP Director Every time I try to open it an error message pops up that says... One or more ActiveX controls could not be displayed because either: 1) Your current security setting prohibits running ActiveX controls on this page, or 2) You have blocked a publisher of one of the controls. As a result, the page might not display correctly.
  • 1,591 Answers
Upgrade from director to solution center.
With the limited information you have given, that's the best advice I can give off the top of my head. Director is old, solution center is current.
Posted on Mar 17, 2011
2 Suggested Answers
Holygrass
  • 443 Answers
SOURCE: When start HP director on
Cause:
This issue occurs if the following conditions are true:
  • The Project Guide is enabled.
  • Security settings for the Local Machine zone are configured to prevent ActiveX content from running.
Note The security settings for the Local Machine zone control the browsing of local content in Windows Internet Explorer. The Project Guide is an Internet Explorer page that displays in Project.
Resolution:
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. Please Click the link below to know how to back up.
http://support.microsoft.com/kb/322756/
To resolve this issue, use one of the following methods.
Method 1 loadTOCNode(2, 'resolution');
  1. Click Start, click Run, type regedit, and then click OK.
  2. Expand the following registry subkey: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\0
  3. In the right pane, right-click 1200, and then click Modify.
  4. In the Value data box, type either 1 or 0 to overwrite the existing value of 3. Then, click OK.
    Note If you type 1 in the Value data box, you will receive the following prompt when you start Microsoft Project: Do you want to allow software such as ActiveX controls and plug-ins to run?Additionally, you will receive this prompt at other times when you use Microsoft Project. If you do not want to receive this prompt, type 0 in the Value data box.
    The values 0, 1, and 3 are associated with the following behavior:
    • 0 = Enabled, or the action is permitted
    • 1 = Prompt
    • 3 = Disabled, or the action is not permitted
  5. Quit Registry Editor.
If this issue still occurs after you perform this procedure, your administrator may have set a policy that prevents ActiveX content from running in the Local Machine zone. We recommend that you contact your administrator to configure the settings for the Local Machine zone. For more information about the Microsoft Internet Explorer security settings that cause this error message, click the following article number to view the article in the Microsoft Knowledge Base: 833633 (http://support.microsoft.com/kb/833633/ ) How to strengthen the security settings for the Local Machine zone in Internet Explorer
Method 2 loadTOCNode(2, 'resolution'); Turn off the Project Guide. To do this, perform one of the following actions, depending on your version of Project:
  • Project 2007
    On the View menu, click Turn Off Project Guide.
  • Project 2002 and 2003
    On the Tools menu, click Options, click the Interface tab, and then click to clear the Display Project Guide check box. Then, click OK.
Posted on Dec 24, 2010
Hi There! I am having problem opening my hp director program
  1. Open HP Director using one of the following methods:
    • From the desktop : On your computer's desktop, look for the HP Director icon (c01425509.gif), and then double-click it.
    • From the Windows taskbar : Click Start , click All Programs , click the HP orHewlett-Packard folder, and then click HP Director .
    Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
  2. Without navigating to another open window, press Alt and Space bar at the same time. The Shortcut menu displays near the top-left corner of the computer. Figure 1: Shortcut menuc00833293.gif If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
  3. Select Minimize from the Shortcut menu.HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen). If HP Director does not minimize, click Minimize again until it does.
  4. Click the HP Director icon on the taskbar . The software opens and functions normally.
Dec 08, 2009 | Microsoft Windows XP Home Edition
Can't open HP Director since XP installed updates. I have uninstalled & reinstalled several times. HP imagezone still works.
remove the windos xp and tray xp deffant version and working your hp director if you have any problem logon www.compudesk.in and send me offilne message for live chat and offlen chat support
Oct 12, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hpqselsk.exe clr error 8004005 & cant open hp director
Its also known as .net framework. Its a software which few applications use for support like chat applications. Below is the system requirement for .net framework to work properly If your system does not fall under the category then you shall uninstall it.
  • upported Operating Systems: Windows 2000; Windows Server 2003 Service Pack 1 for Itanium-based Systems; Windows Server 2003 x64 editions; Windows Server 2008 Datacenter; Windows Server 2008 Enterprise; Windows Server 2008 for Itanium-based Systems; Windows Server 2008 Standard; Windows Vista Business; Windows Vista Enterprise; Windows Vista Home Basic; Windows Vista Home Premium; Windows Vista Starter; Windows Vista Ultimate; Windows XP; Windows XP Professional x64 Edition
Jul 26, 2009 | Office Equipment & Supplies
When I try to validate my Windows version I get an ActiveX error
turn pop up for cookies on, certain activex controls would popup in the seperate windows for that popup should turn on...
Mar 23, 2009 | Microsoft Windows XP Home Edition
Can't open Hp director
I read ur problem.This problem with HP director occurs if you are running Internet version (7.0).If u have difficulties knowing your Internet version, pls do the things mentioned below.
1.Open internet explorer->click help->then click on "about internet explorer".---There you will see the version of your browser.
SOLUTION.
If see an hour glass appearing and disappearing without displaying the HP director window after clicking on HP director, You got the following solutions.
Solution 1.
1.Double click HP director icon.
2.Then Press Alt + space key together.
Result:YOU will see a small pop menu appearing on the desktop screen.
3.Click on "minimize" on that pop up screen.
Result:Now u will see a tab on the taskbar.
4.Right click the tab(hp director),then click restore...Now you will see your HP director window.
Note: Above solution should be performed while trying to open HP director.(ie) You should try this every time if u want to open HP director.To go for full time resolution,then try solution 2.
SOLUTION 2:
1.Open "www.HP.com"
2.Select "software and driver downloads"
3.Type your product name in the "for product text box",then hit enter.{(eg) if u type 7410 for office 7410,then u have to select the exact model in the next window}
4.Select the operating system.(if u dont see a option to select operating sys, there u will see "software and driver downloads"
5.In the next page, you will see a list call "Updates" you have to download a update which says "
Critical update to resolve an issue with HP Director after installing Internet Explorer "
6.After downloading the update, run the file and thentry to open HP director it will open the director window.
This will work.I assure u total problem resolution
Regards
Chittaranjan
Dec 25, 2008 | HP Scanjet 3570 Flatbed Scanner
Flash Player 10
Is your PC running with Win XP with Service Pack 2 or higher? Which browser do you use ( Internet explorer or Mozilla Firefox)
Check out the Add Remove Panel for the Latest installation of
1. Adobe Flash Player ActiveX
2. Adobe Flash Player Plugin
3. Adove Shockwave Player 11
Download it from this weblink: Flash Player http://labs.adobe.com/downloads/flashplayer10_ax.html
Also check this update for Microsoft: http://support.microsoft.com/kb/912945
Let me know the exact error message coming up, to narrow down problem. For more help you can email at techin.scott at gmail.
Regards,
Ellin
Oct 31, 2008 | Adobe Photoshop 7.0 for PC
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Cant access HP DIRECTOR facility.
http://www.fix-all-dll-errors.com/xmlparse.dll/
Here is the solution for your problem.Visit the link and click the button"Fix dll errors now" and your problem will be solved.
Nov 30, 2007 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1317 unable to use hp director scanning
Uninstall "HP Director" and replace with "HP Solution Center" New Updates (especially IE 7) make this application incompatible. Ed
Aug 06, 2007 | HP PSC 1315 All-In-One InkJet Printer
Computers & Internet Logo
150 people viewed this question
David Payne
David Payne
