Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Water wont drain from the bottom, removed hose and not stopped up. float switch is working but dont know how to test the discharge valve that controls where the water goes, either out drain or back into sprayers
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Mar 18, 2011
Manitowok ID0452A-161 water not draining one water tray is filled causing water to over flow into ice bin melting ice. Need to know where the float switch is and dump valve solenoid. FOR TROUBLESHOOTING
Remove side panel on left. Dump valve and drain hose usually blocked with silt, but may be dump valve coil open circuit. No float switch, water level sensor above tray.
Mar 04, 2014 | Manitowoc ID0452A-161 Dice Cube Air Cooled...
Indesit de3542 starts to go but stops after about 30 seconds
That is a discharging problem. What you can try initially is turn it off and unplug the power cable for about 2-3 hours to release any static charges. Then plug it back in. If that doesn't work, there's an internal electronics component that needs to be check. Discharging is a capacitor problem. There might a burned or bulged capacitor that needs to be replaced.
Oct 04, 2008 | Dishwashers
Miele dishwasher Model G1023 drain light stays on and dishwsher will not work
Hello fellow DIY'ers,
Have just had the red light drain/inlet error terror!
Tried all the basics, including:
- check and clean inlet hose filter,
- check and clean drain hose,
- remove and clean all the filters in the bottom, and
-remove and clean the non-return valve.
Still was left with water in the bottom at the end of the wash and the red light drain/inlet error.
After researching further I found that this light also indicates a flooded unit. There in a shallow pan in the base plate and if water collects there it activates a float switch, stops the wash, and lights up the drain/inlet error.
To fix it:
- Disconnect power, water and drainage.
- Pull out your dishwasher, suction/remove all the water from the bottom. This includes the water in the salt reservoir, the drain pump and non-return valve.
- Tip the dishwasher onto its back.
- Remove the four star head screws (sometimes a small flat blade screwdriver will fit these) from the base plate.
- Remove and inspect the base plate. It won't have any water in it as you've just tipped it up. But you will see if it's wet and any staining where the water has sat. It only takes a small amount of water to activate the switch.
- Clean and dry the base plate.
- Have a good look around for leaks in the base of the unit. There was none in mine. Our dishwasher is a snug fit under the bench and we had been doing 2-3 washes per day for several humid weeks leading up to this problem. I believe the water builds up over time and doesn't get a chance to evaporate.
- Put it all back together again and test it.
- If it works, go buy yourself/your family dinner because you just saved yourself about $420!
Regards,
DIYTom
Aug 25, 2011 | Dishwashers
MAYTAG PERFORMA PDBTT49AWW, SN 10120630ET - Under counter model, ABOUT 6 YEARS OLD. No longer gets dishes clean. Problem got progressively worse over 2 year period. After washing cycles, the inside of...
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 22, 2011 | Maytag Dishwashers
Gu1200xlkb0, water left in tub after wash. Checked hose for clog. Drain pump working. Drain loop check valve functioning.
Hello & Welcome to FixYa
If the drain pump is taken apart and cleaned completely then the problem can be with the float switch. You have to take out the bottom front panel out and then clean the drain filter pump assembly completely. Please get back to me if you have any other questions.
Kevin
Jun 28, 2011 | Whirlpool Dishwashers
I have changed the pump, the check valve and cleared the drain hose but the unit does not drain. model# DU1055XTSS2
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it.Hope this helps...please post back for further assistance.
Daniel
Jun 08, 2011 | Whirlpool Dishwashers
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Tank wont refill after flushing.
The ball **** controls the water flow into the tank when flushed. If the float is stuck in the up position, the water will not fill the tank or the valve could be defective. If after pushing down the float and observing little or no water you need to replace the ball **** or the water valve is turned off. Turn the water off at the shutoff valve. Put a towel under the water supply hose and unscrew the water supply hose at the bottom of the ball ****. Drain any excess water at the bottom of the tank using a shop towel or paper towels ringing them out when they become saturated with water. Remove the ball **** and replace the old one with a new one available from a hardware store. Make sure to follow instructions on washer placement to avoid leaks. Replace the water supply hose and tighten snugly and be careful not to over tighten to crack any plastic. Turn on the water shutoff valve and adjust the float so the water stops at the tank water line.
Sep 07, 2009 | Kohler Home
Dishwasher Won't Take Water
power for your water valve is controlled by the timer and the float switch. You can remove the bottom cover to access the float switch and water valve. They both are on the left side of the unit, float switch is right up front and water valve is on the bottom. Test float switch continuity with ohms( always test ohms with power off!) and check for ac voltage at water valve. You can make a test lead and hook up water valve straight to ac to by-pass timer. If you need any more help let me know. Here is a parts and wiring diagram
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=MDB9150AWS&mfgModelNum=&fkMfgID=1
Apr 30, 2009 | Maytag Dishwashers
No water to dishwasher
There's no water entering the machine If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
The water doesn't drain from the machine If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Feb 10, 2009 | Dishwashers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
125 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
