Question about Dishwashers
My Ignis dishwasher will not work. The light flashes 7 times and I no lnger have the manual to establish what the problem is? Thank you.
  • zaky2k Apr 17, 2009
    same problem
5 Suggested Answers
  • 188 Answers
SOURCE: We have a kitchenaid dishwasher model#kud102irbl
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 02, 2009
  • 220 Answers
SOURCE: Whirlpool ADP 5500 dishwasher stops - light flashes 7 times.
It's a heating issue either a bad heater or bad sensor.
Posted on Sep 01, 2009
SOURCE: kenmore 665 17033400 Elite dishwasher clean light
That signals an issue with a faulty heater &/or heater drive circuit.
(that info comes from their troubleshooting guide)
I ran into it this weekend and discovered that the heater coil in the bottom of the washer was broken.
Posted on Jan 18, 2010
rylee_smith
  • 8619 Answers
SOURCE: Dishwasher is locked out. Clean light flashes 7
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 06, 2010
SOURCE: Ignis dishwasher beeps and flashes constantly
salt container is full of water
Posted on Jun 25, 2010
Kenmore dishwasher won't restart, green light flashes 7 times
Unless you have already tried the fix on this site, please see if you can reset your dishwasher. It appears to be linked to dishwasher not being able to heat water to correct wash temperature.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Apr 29, 2014 | Dishwashers
Clean light flashes and dishwasher will not work
when the clean light flashes its displaying a fault code based on the number of times it flashes...if it flashes 7 times then pauses then flashes 7 times again its displaying error code#7 if 4 times then pause its code#4 ect.
This tip i wrote will tell ya how to reset the board since sometimes its just electrical anomilie..reset the board and if it again flashes let me know how many times in a row it flashes and i will determine which error code it is , heres that tip to reset the control board http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Sep 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
My ignis adl 347 dishwasher will not empty its self i put it on a cycle it hums for a while then it starts bleeping continually and light flashes were you turn it off
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. The drain pump can be clogged and refuse to work as it hums. If so remove and clean the drain pump, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated.
Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Thank You for using fixya
Sep 21, 2011 | Dishwashers
My dishwasher isn't working. The clean button
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, and then repeats this occurs when the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
Thanks
Rylee
Jul 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light flashes 7 times and dishwasher not working
This is due to the water not heating properly. Below is a link to instructions I put together to show you how to reset the control and what may have caused the failure. Let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 17, 2010 | Dishwashers
Clean light flashing
Sorry you are having trouble, I put together a quick check list and instructions on how to reset the control. Let me know if this works for you, if not I can dig a bit deeper to help.
Apr 25, 2010 | Kenmore 24 in. 16293 Built-in Dishwasher
Mar 10, 2010 | Dishwashers
Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
Oct 20, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
-high temp wash
-heated dry
-high temp wash
-heated dry
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Here is the solution to your problem. Push in this order, High temp, heat dry, high temp, heat dry, all the lights will begin to blink. After they stop, the dishwasher will start. Press cancel twice.
May 06, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
