Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint refrigerator sounds like a high pitched siren
  • Hotpoint Master
  • 43,501 Answers
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Posted on Mar 18, 2011
    Director Badge:
    Uploaded 100 video answers.
  • Hotpoint Master
  • 488 Answers
this might be bad bearings on evaporator fan motor if sound comes from freezer section. Check this video how to replace it. I hope it will help.
Posted on Oct 16, 2014
High pitched sound coming from refrigerator sounds like loud whiny humm
TRY AND LISTEN TO UR COMPRESSOR SEE IF U HEAR ANNYTHING THERE? IF NOT CHECK UR COMPRESSOR CONDENSOR FAN AND FREEZER EVAPORATOR FAN FOR BLOCKAGE OR OBSTRUCTIONS? OR POSSIBLY 1 OF THE FANS MOTOR IS GOING OUT MAKING FUNNY SOUNDS, ANOTHER THING COULD BE A BAD DOOR SEAL ISSUES WHICH OVERWORKS THE COMPRESSOR AND CAN CAUSE IT TO MAKE FUNNY NOISES
Oct 02, 2014 | Hotpoint Refrigerators
High pitch whine when tv started then it lowers in pitch
That could be either the color wheel or one of the fans. try listening to which area of the set its coming from.
Apr 04, 2012 | Televison & Video
Hotpoint side by side makes a high pitched "howling" noise. Sometimes is worse then others and will sometimes stop when the door is opened.
ANY TIME YOU HAVE SIDE BY SIDE REFRIGERATOR IT ALWAYS RECOMMANDED TO HAVE LEVEL FLOOR AND YOU MOST SET UP THE BOTTOM ADJUSTEMENT SO THE REFRIDG CAN BE LEVREL AND STABLE WHILE RUNING.
Oct 24, 2010 | Hotpoint HSS25GFP Side by Side...
I HAVE A wailing HOTPOINT HSS25GFPH WW refrigerator
change the rubber isolating washers on the pump and compessor too hard a compound will make things worse ,neoprene works best ......
Feb 07, 2010 | Hotpoint HSS25GFP Side by Side...
Refrigerator making a high pitch vibrating sound
Sounds like the fan from the freezer that blows the cold air into the refrigerator is noisy. It either needs replacement, or lubrication. Good Luck, I hope this helped Please rate me, Thanks
Jan 12, 2010 | Refrigerators
High pitched whirring noise in motor/fan?
the bearings in the motor are going bad. you probably need a new fan motor.
Nov 06, 2009 | Hotpoint HSM25GFRSA
Alarm siren sounds every 5 seconds.
sounds like a defective door ajar switch or a defective seat belt switch.
Mar 27, 2009 | 2000 Renault 181
Hss25gfpdww The unit makes a horriable high pitch whining noise a
I am not posotive, but it sounds like you may have a piece of debris stuck in the fan underneath. You can check if you pull it out from the wall, make sure you unplug it as to not have the fan come on while you are toying. But thats what it sounds like. If that is not it, I am sure you could locate the noise with it pulled out from the wall, and go from there, Possibly your compressor, but sounds like the fan the way you're explaining it. Good luck
Feb 14, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Fridge is making noise
The high pitched sound could be from the evap fan motor. If you can get to it a drop of silicon oil would solve the problem.
Dec 18, 2007 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
373 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De GO PATS
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
