Question about Refrigerators
Water dispenser will not stop running when door on side by side is closed. Had to turn off water, and now am uncertain how to access the water dispenser internal parts on freezer door. I am afraid of breaking the cover on the door.
Most likey it is the water valve stuck in the open position. Or the the control has constant voltage to the control. use a meter and check for consistent volts at the water valve coil without depressing the dispenser. If you do not have voltage then replace the water valve
Posted on Mar 17, 2011
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
Ice dispenser stuck on
Either the paddle for the ice/water dispenser is stuck or you have a bad microswitch behind the dispenser.
To stop the ice/water from dispensing open the freezer door and press or hold the child lock button down. Once the unit is in child lock mode you can shut the door without energizing the dispenser.
Another option is to remove the upper freezer door hinge cover and disconnect the wire connector up there. This will remove voltage from the dispenser as well. Then either replace the paddle or switch. Sometimes the paddles/switches will get stuck because of splash up from ice dropping in sugary drinks.
May 05, 2017 | Amana ASD2328HE Side by Side Refrigerator
Water and ice maker not working line frozen everything frozen even when you turn it down is it the termostat or what
It sounds like your ICE Dispenser door is stuck partway open. Defrost the access door, ice bucket and crusher then check the Ice Dispenser door to be sure it fully closes, otherwise cold air will constantly drift out and freeze the whole mechanism.
Mar 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice and water dispenser sticks. I have to open
The door flap may not be opening and closing completely thereby trapping the ice. There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Feb 13, 2010 | Jenn-Air JSD2789GES Side by Side...
GSH25KGRWW dispenses ice/water all by itself! Heard noise last night, and refrigerator was dispensing ice all over the floor!! Attempted to stop by tapping the lever, but this had no effect; pushed water...
as you explained that by opening the freezer door the problem stopped the problem is: that you have a pinched dispenser wire or, two in the area between the door and, the door opening
these wires are low voltage so they are not going to cause a fire
but, if they touch the cabinet due to a bare wire they will ground and, start running the dispenser.
the door cover needs to be removed and, the problem (usually at the door hinge must be found and, corrected i.e. wire taped, shielded etc.
Sep 14, 2009 | GE GSH25KGRWW Side by Side Refrigerator
PCG23N ice cube dispenser area problem
This is probably due to the door flap in the ice chute not closing tightly. There is a solenoid that operates the door that could have stopped working. Can you hear it? The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Aug 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser won't stop. It started automatically and water keeps being dispensed even though we tried pushing the ice button and the lock button. It stopped when I opened the freezer door but would...
I take it this is a G E refrig ? Model number would have helped . If you still hear a hum with door closed , the microswitch behind the dispensor board is bad . Not a computer problem but a simple fix .
Aug 12, 2009 | GE Profile¿ Arctica® Energy...
Water leaking through ice maker
check out the temperature inside of the freezer your probebl going to have to clean the condenser coiul underneith the unit
May 23, 2009 | Whirlpool ES5FHAXS Side by Side...
Water dispenser starts running when freezer door closed
if you wich to disable the despenser for water in the door just unplug the electrial connector on the water valve it has 2 selenoids on it one is for water in the door it has the largest plastic line under the selenoid
just unplug the connector to that selenoid
you will still have ice and it will despense through the door
Apr 20, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
WATER RUNS OUT OF THE WATER DISPENSER ON THE DOOR OF THE SIDE BY SIDE
THe problem may be in the water valve for the water despenser,
you could try disconnecting the 2 wires on top of the water despenser side of the valve and see if that will stop it. IF not the valve may need replaceing, may be leaking thu water vavle when closed
Oct 18, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
