Question about Oster Barber Shop,hair Salon Stim u lax Massager
How do I disassemble the OSTER Stim-u-lax Massager for cleaning? Thank you.
Disassemble brookstone messager?
A lot of these units have clips that hold the case together. Using a screwdriver to open up the case is the way to get into the ones we have in our house.
Jul 24, 2014 | Brookstone Theraspa Turbo Massager
Burnt smell on oster blender
If you have eelctric knowledge, disassemble the case and look for some corroded contact or cable.
You can follow some of these youtube tutorials or look for additional info by doing a Google search using terms
Youtube disassemble blender
iFixit Blendtec Total Blender Disassembly
How to open and repair Braun Hand Blender Part1
KitchenAid Blender Coupler Repair KSB5 Model
OSTER Blender Repair How to fix an broken driver
If you are not familiar with disassembling a blender but you feel you have the knowledge to do it, take a photo of each step so when you have repaired the problem, you should have no problem to reassemble it again
Sep 04, 2013 | Blenders
I have a older model Oster bread maker I cant find the model. I brought it from Salvation Army and I need a manuel
Oster manuals are not the easiest to find; here are three; hope one is is for a model similar to yours. If you can find your model number on the botton or back might be able to assist further.
Thank you for using FixYa!
CKSTBRTW20 - Oster® 2lb. Expressbake® Bread Maker
http://www.oster.com/manuals/MANUALS/CKSTBRTW20_43_33506787.PDF
5838 - Oster® 58-Minute Expressbake® Breadmaker
http://www.oster.com/manuals/MANUALS/005838-000-000_ENGLISH.PDF
Deluxe 2-Pound Bread & Dough Maker
http://kitchen.manualsonline.com/manuals/mfg/oster/deluxe_2pound_bread_dough_maker_p_n_101017.html?idRes=2148332
Sep 14, 2011 | Oster 5838 ExpressBake Bread Maker
How many watts are consumed by wahl 2 spd ********
Thank you for using FixYa.com. Your 2 speed all body massager is rated 8 to 10 watts model.
Apr 17, 2011 | Wahl 4196 500 All Body Massager
5838 ExpressBake Bread Maker: I have the Oster breadmaker 5815 and need the manu...
you will get any Oster breadmaker manual with the manualfox search engine. Check results here:
http://manualfox.com/link/oster.htm
May 17, 2010 | Oster 5838 ExpressBake Bread Maker
How to replace power cord om homedics massager
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Jun 20, 2009 | Homedics Inc Massager Neck Massager W/heat
Can't disassemble massager.
I don't have the Homedics programmable, but I have taken apart my Brookstone programmable (and lots of old Homedics massagers).
I'm going to guess the screws concealment method is similar. On the under side of the massager, look for small oval-shaped outlines that are the same color as the rest of the body. Mine had four. These are little plastic plugs that you can pry out with a tiny flat screwdriver or a razor blade. The screws are hidden under these plastic plugs.
I hope this helps
Feb 23, 2009 | Homedics PA-4H Programmable Percussion...
Jeanie rub massager
Out-of-Warranty Service
Core Products will repair most Jeanie Rub Massagers after the warranty has expired. Some of the very early models can not be repaired but can be returned for a $50.00 credit towards a new unit.
It is difficult to determine the extent of the repair until the unit is inspected however, we guarantee the service call will not exceed $89.00 plus shipping.
1-800-338-7014
Basic Service Package - $49.00 + $13.00 Shipping
- Cleaning
- Replace worn parts & pad
Complete Service Package - $89.00 + $13.00 Shipping
- Cleaning
- Replace motor
Cord Replacement - $25.00 + $13.00 Shipping
- Replace worn cord
There is a 90-day warranty on any service that is performed by Core Products International.
Where to send it
Core Products International, Inc.
RETURNS DEPARTMENT
1505 Parker Ave, PO Box 627
Chetek, WI 54728
If you have any questions regarding our service,
please call 1-800-338-7014.
Sep 14, 2008 | Jeanie Rub Variable Speed Personal...
How to clean massager
Be sure to unplug the unit and allow it to cool. Clean it only with a soft, slightly damp sponge. Never allow water or other liquids to come in contact with the unit.
Aug 27, 2008 | Human Touch Portable Massager Blue AV680
Oster Kitchen Center won't hold a steady speed
My wifes Oster Kitchen Center slowed down and I think finally stopped. I say I think it did because I took it apart two years ago and am finally finding the time to get it back together. I cleaned it, checked the brushes on the motor(all of this is in the base unit with the control buttons on it. The upper blender/beater arm has no electrics in it.) The brushes were coated with some kind of dried crusty stuff which was keeping them from contacting the motor.I put it back together and tried it but it only hummed and did not move.
I took it apart again, this time everything came out. Motor, electric wiring plus the metal gearbox attached to the motor which drives the blender and the upper arm. I took the transmission apart (it's attached to the motor in the base unit) and found the gears in it were so gummed up with who knows what. Probably everything that leaked out of the blender.
You see, what happens is that the seal between the blender black base and the glass jar started to leak after a few years but we don't notice it. Maybe we did but we cleaned it and we thought it was all good. But the liquid can leak down into the bottom unit around the drive teeth and that little square drive that the blender locks onto. And then it goes into the gearbox and the motor. So it is a major job to clean it. Since I don't have a manual for disassembling the lower base unit, I'm just putting it back together. I cleaned all the gunk out, put some grease on the gears and the gearbox is working better but I fear not perfect. It is 30 years old!! So unless you take it apart yourself or find an appliance repair shop (is there such a place anymore?) it might not be worth the effort. But it is do-able. How long have you got?
Mar 01, 2008 | Food Mixers
Oster Barber Shop,hair Salon Stim u lax Massager Logo
115 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
