Mitsubishi TV Screen. Model # WS65517 When I turn it on, the TV shuts off in 5 minutes. The message is that the air flow is blocked.
You need a new switch
Posted on Mar 17, 2011
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
When I turn on my 65" the message displayed reads the air flow is blocked and the tv will shut down which it does. I've vacumed & cleared all openings. I have to reset the tv about (5) times before the...
ok what you have there is a faulty thernal sensor nitisubishi has issued a bulliten to serice centers so check with local service center the repair might be covered under warennty
Oct 14, 2010 | Mitsubishi Televison & Video
Tv blacks out and saids block air flow
Call Mitsubishi and they will tell you a authorized service center in your area to come out and fix this issue. They have a recall on the thermal sensors in these sets. They will pay for the repair.
Oct 17, 2009 | Televison & Video
Message that TV is powering down, check air flow for obstruction
Mitsubishi has had some problems with these sets with the lamp cartridge(google the model number and look for how to replace lamp instructions) On some of the lamp cartridges they covered several openings with a fine screen like material---one is narrow and completely blocks up with dust---this will trigger the air flow message--if you get the lamp out and this screen is blocked, carefully clean the dirt off with a brush---if you don't get it soon enough it will kill the lamp----the replacement lamps for these sets use a bigger mesh that does not block with dirt---it blocks because there is a fan the pulls air and dirt into the set to cool the lamp during operation.
NEVER TOUCH THE FRONT GLASS OF THE LAMP WITH YOUR HAND
I do this here for free so if this helps you give me a vote here.
Aug 24, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Air flow blocked message appears when turning on
Replacing the thermal sensor is the cure for this. If you call Mitsubishi at 1-800-332-2119, press 5 for Customer Service. Explain the problem and they will probably approve a extended warranty claim and get the repair done for free through a Mitsubishi Auth. Repair Facility. They will also help get you in touch with one near you. Do not delay in acting on this. I do not know how long the extended warranty claims for this problem will last.
Hope this helps,
Skyassoc
Jun 20, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
May 15, 2009 | Mitsubishi WD-57732 Projection Television
Mitsubishi TV air flow
open the back of the television to check for dust buildup on the heat fins and other components. As well as the fan.
Mar 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
52' DLP Mitsubishi HD T.V. gets an error message on the bottom of the screen ''T.V. will shut down. Check that air flow is not blocked'' T.V. is in the open and air flow is not blocked. There is also a...
most rear projectors will turn themselves off whenever the lamp is dead. what we call protective mode. in this case the yellow light may be for the lamp. otherwise check if all the fan are working properly.
But MAKE SURE you let sufficient time for the tv to cool off before unplugging the main.
hope this helps
please rate me!
Mar 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 1080 LP HDLP TV
tv screen goes blank but still have sound
Feb 17, 2008 | Televison & Video
Amber system light is on
had the same issue, we even had a personal fan blowing air behind the tv and the message always comes up right when we turn on the set and the tv turns itself off after about 30 seconds. did some research and it turns out there is no air flow problem just a faulty temperature sensor inside the set. Mitzubishi knew about this since 2006 but didn't really aknowlege it until more recently, they admitted it was a problem with the sensor and are now extending everyone's warenty by 2 extra years so if you got it with a year warenty and you bought it less than 3 years ago, call mitzubishi's 800 number and tell them the temperature sensor needs to be replaced, they'll get you in touch with the nearest service center and a service man will come out and replace the sensor at no charge for parts or labor. hope this helps
Jan 13, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
