Question about GPS
I have a maxon MCB-30 and i cant hear what other people are saying,but it can transmit but not very far. what is my problem?
  • 391 Answers
Hi I presume you have matched your antenna to your radio ( VSWR) Im not familar with this radio ,does it have am/fm if so set to am ,if this is ok your problem could be the audio ic mighr need to be replaced ,or check with an external speaker ,open bottom panel check for any broken wirering also check microphone wirering as this gives you the receive ,hope this helps you...
Posted on Mar 18, 2011
Maxon wire fuses
If a inline fuse in a holder the old one will aside from length have the amperage printed on it---very few mobile radios use larger than a 3 amp fuse-----look on metal ends of old fuse if have it for markings like 3ag 3 250---3AG is size, 3 is 3 amp, 250 is max working voltage (120 is fine).
Oct 24, 2012 | Maxon MCB-30 40-Channels Base CB Radio
Microphone din pin wiring for mcb30
Look at Defcom Radio mods or other sites. Snake doctors radio mods. Look up Microphone wiring for Maxon MCB-30. Just type it in to WWW.Google.com
May 01, 2011 | Maxon MCB-30 40-Channels Base CB Radio
Hello there, I have the maxon mcb 30 and I have lost the mic. Do you know what kind of mic I must use to work good?
Try the stock mic from cobra, the regular 4 pin mic, its a great mic..... enjoy.... hope this helps....
Mar 13, 2010 | Maxon MCB-30 40-Channels Base CB Radio
Is my maxon mcb-30 pa capible
According to the page below, it does not have PA capabilities.
http://www3.dealtime.com/xPF-Maxon-MCB-30
Aug 22, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Maxon mcb-30 manual
Try CBtricks.com......hope this helps....enjoy.....
Aug 06, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Maxon mcb30 which way to turn the mod
RV 2 is the modulation pod that needs to be turned
Mar 18, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Maxon MCB-30 CB Raido
what do you mean program it? swr?
Looking for a Maxon mcb-30 manual
I think I have the service manual for this radio please send me your email so I can send it to you
I believe the MCB-30 Crosses with the SM2500 from what I have been reading.
Oct 29, 2008 | Maxon MCB-30 40-Channels Base CB Radio
When I Press the mic to talk, others hear me key down, but no sound is transmitted
Hello lummox30,
Check you mic first to see if it is indeed working. Then if it is the below advice is applicable.
It sounds as if your TX audio amplifiers might be malfunctioning or the TCXO might be bad. If you have a background in Electronics I would suggest that you open up the unit and using a dummy load on the antenna check the two TX audio amps to see if when you key the mic and speak into it the amplifiers are amplifying your voice and sending it to the modulator. If the problem is not amps or the filters in between the amps, the modulator and the VCO buffer are suspect. If the TCXO is being modulated I would check the PPL IC and the Drive amp to see if the modulated signal is getting through. The last two checks I would perform are on the final amp and the TX switch prior to the antenna jack.
If you do not have a background in electronics, still check your mic, but the rest of the above advice can be done by a qualified Radio Technician.
I hope this helps,
Thank you,
Shuttle83
Oct 01, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Meter Shows Signal, no noise
when you have no RX or TX at the same time, that most often means the pre-driver audio transistor is bad.
Thanks,
Dodgem
http://dodgem250.angelfire.com
May 06, 2008 | Maxon MCB-30 40-Channels Base CB Radio
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
