Question about GE DBXR463GB Gas Dryer
Dryer will not hold its position when the kob is turned to on..motor starts but when starting knob is released motor stops..is it the ignitor??att.net
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 20, 2011
How do I unlock the door of e43 Bosch washing machine error
E43 indicates a motor circuit error.
Lets try and reset the control board.
Switch the knob clockwise to off position. Now turn the knob clockwise to 6 O'Clock position and wait until the light starts flashing. Press and hold the spin button and while holding it turn the knob clockwise to 9 O'Clock position. Now release the spin button and switch the knob off. Tagged as: bosch
Dec 22, 2014 | Bosch Washing Machines
Push in knob to start dryer. The dry starts, but when I remove my finger off the knob the dryer stops running. Only runs when I hold the start knob in. Kenmore Model: 110.64982300. What is happening,...
heatman101
Aug 15, 2011 | Dryers
If you turn start knob motor will start, burner will start but when knob is released all stop. Could this be an interlock switch? If so can it be reset?
heatman101
Jul 11, 2011 | GE Dryers
F 21 appears on panel
Hi, This sounds like the motor brushes need replacing, but its possible that the machines control circuitry has been upset by mains surges or spikes, so try the following to reset the machine first....
1. Turn the appliance knob to the off or reset position, (12 o'clock)
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button & while holding it, turn the knob to the 7 o'clock position, keep holding the spin button and then release it after about 5 seconds, now turn the appliance knob back to off.
Hopefully when you turn the machine back on it will have reset the error and you can continue to use the machine.
If the machine goes back to F21 after a program has been started then it is most likely the motor brushes need replacing or you have a faulty motor drive module.
Hope this helps
Midge.
Feb 13, 2011 | Bosch Classixx WFL 2066 Front Load Washer
When I the start the GE dryer it will not start unless I will Hold it to On position. when I release it it will stop.in other words it will not hold to Run position
you could have a bad motor. the motor has an internal switch that is stuck in the start position and not switching to run. replace the motor.
Feb 05, 2011 | Dryers
When i hold the on kob on....you hear a humm....Is that a bad motor?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 12, 2010 | Kenmore 72822Gas Dryer
Bosch classixx 6 1400 machine stopped working during cycle f21 on display
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
Nov 27, 2010 | Bosch Washing Machines
My dryer won't tumble. I close the door and turn the spring knob to start it but all it does is hum while I hold the switch and stop when I release. It won't turn.
heatman101
Oct 20, 2010 | Dryers
HUM NOISE OCCURES WHEN TURNING KNOB TO LEFT BEFORE PUSHING KNOB TO START- STOPS WHEN POINTING TO OFF POSITION - MODEL GYC4000AWW . DRUM DOES NOT TURN
it sounds like you have a bad motor and door switch. the unit should not run unless you push a start button. the humming noise is the motor. either something is blocking it or your motor is bad,
Oct 12, 2009 | Magic Chef CYG2000AWW Gas Dryer
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
GE DBXR463GB Gas Dryer Logo
41 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
