I think you are right. The core may be restricted or leaking refridgerant. The moisture could be condensation on the evaporator that is building up inside because of a plugged or broken drain hose. (the water you see on the ground under a car when the A/C is running might be dripping inside the cabin)
try pinching off one of the hoses going to your heater core. even tho the heat setting is off it could still be leaking hot water thru your heater core which will decrease the efficiency of your evaporator and thus your airconditioning system. [email protected]
