Question about American Standard Home
American Standard model 3142 ...seems to allow the toilet to flush twice. How can I correct the problem?
frcs68
  • 1605 Answers
SOURCE: american standard cadet 3 leaking around seal
get a new filler assembly. the water in the tank is heavy enough to close the seal completely. or the rubber seal is not making contact. thats' why the leak.
change the whole assemble ususally correct the problem.
adjuste the flow to about 1/4 to 1/3 under the over flow. if that still don't give you the pressure. you ca adjust the flow tube to 1/5 under the cover. that is the max.
Posted on Nov 07, 2008
  • 35 Answers
SOURCE: American Standard Elongated toilet bowl water level slowly drops
The tank holding the proper amount of water is a good sign. The inside of the stool is like the GOOSE NECK under you sink. It always holds water. This may sound like a bit of a hassle to do but if all 3 toilets are identical, here is what you can try if you are a bit handy. Go to the hardware store and purchase 4 toilet wax rings with a plastic flange and a few sets of toilet floor flange bolts(they are cheap and you can always return if not used, as It is better to have xtra parts on hand). Turn off the water supply to the "Mystery Toilet". Leave the tank and everything connected to the stool. Flush the toilet and remove all excess water from the tank and bowl. This can be done with a shop vac, sponge or towel. Disconnect the water supply to the tank. Remove the bolts holding the stool to the floor and carefully remove toilet. Scrap off all the old wax from the floor flange and bottom of stool. Now go and repeat this proceedure to one of the toilets that is working properly. In other words Switch the "Mystery Toilet" with a "Working Toilet" and see how they react. If the working toilet does it in the same bathroom and the "Mystery Toilet" does not do it in the other bathroom then you probably have a VENTING PROBLEM. If the "Mysery Toilet" Does it in the other bathroom then you most likely have a Defective Toilet. This Job is best done by 2 people, as it can sometimes be challenging to center the new wax ring on the toilet flange. Reconnect to the floor and reconnect water supply to the tanks. DO NOT OVERTIGHTEN BOLTS to the floor flange as you may crack the toilet. All drain lines must be vented properly for water to flow. If you are curious check out drain venting on the internet. Also, sometimes a vent can become obstructed with debris, ice, bird nest, etc.. I would 1st check the vent on the roof visually and then have someone flush and listen. If you believe the vent is clear....Then do the toilet switch and go from there.....Hope this helps and Happy Holidays....Joe
Posted on Dec 21, 2008
  • 85 Answers
SOURCE: Square toilet seat made by American Standard Model TL 235.
I have not seen a square toilet seat. You need to check the date stamped inside the tank and check with american standard about the seat.
Posted on Jan 06, 2009
  • 3 Answers
SOURCE: New American Standard Flowise toilet won't flush
Same thing here. We have tree roots that occassionally grow into the sewer line out in front of the house. About every 6 months we would have to snake the whole line. We started buying Root-X which keeps the pipes clear of roots and which does not harm the pipe. Once a year we put it in there and leave overnight. No problems anymore. We get ours on EBay.
Posted on Apr 30, 2009
dmftrucker
  • 1922 Answers
SOURCE: running toilet
your float is stuck
Posted on Oct 13, 2009
What causes a loud gurgle after flush?
If the flapper does not seat correctly and completely, refill water flows into the bowl and causes a "false flush" and the loud gurgle. You can demonstrate this by holding the flush handle depressed after a normal flush. Also, there may not be sufficient slack in the flapper chain to allow it to seat correctly.
If the flush valves were installed exactly according to the instructions, they should work perfectly and can be excluded as a source of the problem.
Jan 23, 2016 | Home
My brand new toilet american standard round front model cadet 3 tank not fill water
If you verify that the water supply to the toilet is turned on, push down the float on the flush valve. Water should start flowing. If it doesn't, something (such as debris) may be blocking the valve and preventing filling. The new valve could be defective - permanently closed.
Jan 11, 2013 | American Standard Cadet 3 Right Height...
I bought a house that has some older fixtures and all of the toliets (3) are the American Standard 13.2 / 3.5 GPF models. The one toilet in the main washroom flushes odd, in that when it flushes often a...
You probably have excessive buildup on the pipe walls that have restricted the flow to the point of needing that second flush - or somebody flushed a plastic bag there and now it is acting like a flapper. This will also be evidenced by occasional flooding at that commode. There's only 2 solutions as I se4e it.; scrape the pipe walls ( rooter with a scraping head ) or replace the pipe for the build up, or rooter out the pipe to try to extract that blasted bag.
Good luck!!
Nov 20, 2010 | American Standard Home
Yellow attachment to flapper in Cadet 3 toilet tank
Some toilet flappers are designed with this some are not. It has to do with the particular flapper design, helping the flapper to stay in the open position to allow a better flush. Anyways you should be to adjust this float up or down to optimize it's usefulness. Trial and error is all you can do, keep watching and flushing until it no longer gets in the way. I hope this helps in at least knowing that for your toilet and the flapper you have, it's suppose to be there. Good luck and thanks for using FIXYA and have a great weekend. Jeff
Apr 09, 2010 | American Standard 4112.016 Cadet Toilet...
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
Flush valve drops before bowl completes flush
is the flapper weighted? if it is it will cause it to shut prematurely. one thing you can do is increase the water in the tank. you might have to buy a pvc cuppler to put on the over flow to allow it to fill up more. korky makes a nice flapper thats not weighted
Aug 01, 2009 | American Standard Traditional Champion4...
Toilet keeps flushing
you need to replace the flapper, it's allowing water to seep thru
Jul 09, 2009 | American Standard 2002.014 - Champion4...
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
Home Logo
1,859 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
