Question about HP J4680 Office Jet All-In-One Printer
I just connected my HP C7280 All in One to my new HP notebook. The Printer prints, but I can't send a fax. What do I need to do?
    Brigadier General:
  • 10,406 Answers
First, plug a telephone hand-set into the telephone-socket in the wall-jack.
PIck it up, and listen for the dial-tone. If there is no tone, you have a problem with your telephone service.
Then, you need to use a telephone-cable (2-wire or 4-wire) to connect from the HP to the telephone-jack in the wall. Now, you should be able to send a FAX.
Posted on Mar 17, 2011
How to hook up fax on HP C7280
The C7280 can be used as a stand-alone fax machine. All you need to hook up to the printer is a telephone line. Connect the phone line to the jack marked "1-Line" on the rear panel, below the power supply connector. If you want, you can connect an extension phone to the jack marked "2-Ext". The line connection is for a standard telephone line. Once the line is connected, faxing is pretty much the same as it is on any fax machine. Put your documents face up in the feeder on top, or for a single sheet, face down on the scanner glass. Press the "Fax menu" button on the control panel and you'll be asked for the number. Enter the number from the keypad and then press the "Start fax black" or "Start fax color" color button to send the fax. Other than the phone line, there isn't anything else you need to hook up.
You can download the manual from HP if you need it for reference. It explains how to use the special features of the fax machine, like broadcast faxing, memory dialing, printing fax reports, etc.
Aug 17, 2011 | HP Computers & Internet
I keep getting "image on fax send report is set to
Hi!!
Press the Setup button on the front panel of your All in One
Go to Print report
Check for Fax report it may be off turn it On
Apr 16, 2011 | HP Photosmart C7280 Printer
My HP C7280 will not recieve faxes. What do I need to connect? or change?
I am not certain, but if you have it connected to a DSL or other broadband telco line, it won't work for faxes. You need a simple regular landline for faxes in and out.
Check the manuals to be sure.
-a.
Aug 14, 2010 | HP Photosmart C7280 Laser Printer
I need to know if there are Win98SE drivers for my HP C7280 Photosmart printer. HP does not provide drivers for OS prior to Win2K or WinME. I have a Compaq notebook that cannot be upgraded to WinXP and the...
This printer does not and will not have a Windows 98 driver.
However, it's printing part is more-or-less compatible with the HP DeskJet 990C printer, so go to the HP site, choose DJ990C and Windows95 system, and download the full feature drivers for it - they are also for 98/Me.
Under W98 or WMe you will not find a driver, only an uninstall utility - one of HP's little jokes.
Of course this will be print only, no scan or fax features will be available.
Link for your convenience:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj988en&lc=en&dlc=en&cc=ca&product=61686&os=19&lang=en
Nov 30, 2009 | HP Photosmart C7280 Printer
HP C7280 doesn't print 2-side from my computer
have you use duplex unit?
you have to change your driver option both side print
Thanks
Oct 27, 2009 | HP Photosmart C7280 Printer
How do i set up the fax to print a confirmation sheet when it sends something?
Try this:
Press the Setup button (it might be the sign of a monkey range)
  1. Press the Down arrow (c00844971.gif ) to highlight Print Report , then press OK .
  2. Press the Down arrow (c00844971.gif ) to highlight Fax Confirmation , then press OK .
  3. Press the Down arrow (c00844971.gif ) to select one of the following options in the table below, then press OK
On Fax Send Prints a fax confirmation report for every fax you send. On Fax Receive Prints a fax confirmation report for every fax you receive. Send and Receive Prints a fax confirmation report for every fax you send and receive. Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
Select the one you would like to choose ;
For further help click on the following Link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01083680&cc=us&lc=en&dlc=en&product=3204785
Regards Soumajit
Sep 21, 2009 | HP Photosmart C7280 Laser Printer
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP C7280 All in one wont send faxes
First clear the fax memory and then go to go fax menu and then settings
then DRPD set it 9600, and then try to send a fax ...
Good luck...
Feb 02, 2009 | Office Equipment & Supplies
HAD A PARER JAM.CLEARED IT. NOW NOT PRINTING.
Open the printer by double clicking on its name in the "Printers and Faxes" area of your Start menu. Highlight the first document on the top of the list, and delete it. If the following print jobs don't print, delete all of them, restart the computer, then send a print job to the printer.
Dec 08, 2008 | HP Photosmart C7280 Laser Printer
HP J4680 Office Jet All-In-One Printer Logo
63 people viewed this question
Seeker5211
Seeker5211
