Question about Stairmaster 4400 PT Stair Stepper
The left peddle has a periodic quick drop as if it is slipping or something. There is a low popping sound whenever this happens. The drop is very slight and occurs about once a minute.
  • Stairmaster Master
  • 914 Answers
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
Why does one Pedal Drop on my Stairmaster Stepper
Posted on May 20, 2014
I have a 99 335 sportman. It seems to vibrate in
There might be some worn parts in the differential. If you have a limited slip differential the clutches will make that noise.
Oct 09, 2014 | Cars & Trucks
Why is my truck making a chiming sound and then the check gages light will flash
The chiming sound is to get your attention that something is wrong. Most likely the oil pressure dropped for a short period of time. Add oil to the engine. My 5.9 Liter durango did that and was almost 2 quarts low and would chime when I came to quick stop
Aug 23, 2014 | Dodge Ram 1500 Cars & Trucks
Mitsubishi Eclipse GT clutch slipping
sounds like you need a new clutch and throwout bearing
Apr 14, 2017 | Mitsubishi Eclipse Spyder Cars & Trucks
When riding the peddles slip,it appears that the chain is engaged and that the axle is slipping and make s the peddles spin, not engaged
If this is a coaster brake bike (single speed, no hand brakes) then the problem might be inside the rear wheel hub. If that is the case then you can only fix it by completely dis-assembling the rear wheel hub - or it might be simply that the chain is slipping, which would not happen unless the chain is too loose which would be indicated by the bottom of the chain hanging down too low. However, if this is a multi-speed bike, then it could be that the chain and rear-wheel cogs are worn - which can be fixed by replacing the freewheel and the chain - however, it takes a lot of use or rust and dirt before that level of wear happens.
Aug 07, 2012 | Trek Mystic 16
Whenever i turn my wheels to the left or right i hear a squeeking noise as well as a popping sound coming from the front end area,whether im in motion or not?what could be the problem?
check your power steering fluid -- if that is low, your pump will make funny noises like that. If it is not that, have the pump itself checked out. If not that ... it might be something more major than that (but most steering parts won't squeak and pop unless they are VERY damaged ... if you are still able to turn the car reliably, it's probably the fluid or the pump.
May 30, 2011 | Chrysler LHS Cars & Trucks
Nissan altima 2002 while driving care starts to shut down pudering engine is still running but car is moving very slow while peddle is down all the way
I can't quite tell if you mean the engine runs but with very little power, or if there is power but the transmission is slipping?
If the power is failing, then the question is when does it happen?
Is it temperature related, only happens at high speed, or is it only after a period of driving fast? If so, it could be a temperature sensor, the fuel pump or filter, or it could be the air mass sensor being coated with foam from the PVC valve, or it could be a plugged catalytic converter.
Do the engine lights come on or any other indicator?
If the engine has power but transmission slips, then check the ATF (automatic tranmission fluid) to see if it is low or burned smelling, or dark. If it is, then either fill or change it, and have it checked by a tranmission specialist.
Sep 02, 2010 | 2002 Nissan Altima
Whenever I turn left and accelerate quickly, the transmission seems to "slip". It does not do that when I accelerate and turn right. Any ideas?
Have you checked the fluid level. It will do this when it's low. The fluid runs away from the filter pick-up.
Apr 13, 2010 | 1996 Pontiac Grand Prix
Transmission slips full turns & quick stops
Have you checked the fluid? It sounds like its low. If its fine, change the filter.
Jun 11, 2009 | 1997 Buick LeSabre
Knob is popping
Mcrib, sounds like one of your infinite switches is going bad. This is not a hard fix, you can get to them by removing the back panel behind the control panel. I would give you the part number but I would need the whole model number and whether it was a left or right front or rear burner causing the problem. Catriver...post back
Aug 15, 2006 | Whirlpool RF378 Electric Kitchen Range
Stairmaster 4400 PT Stair Stepper Logo
153 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
