Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Hello, We have a Fisher & Paykel dishwasher m# dd602 znwn showing After we fixed a hole in the drain line an F1 code still appears and the pump keeps running. What should I do from here?
  • 77 Answers
F1 means that your dishwashers have flooded. You can download the video in the link below to see how to get rid of the error and fix your dish drawer for numerous other problems. If your drawer is noisy you may want to replace the rotors at this time as well.
Appliance Repair Video
Order Fisher Paykel Rotor in this link if needed
Posted on Mar 18, 2011
  • Jerry LeBaron Oct 08, 2011
    We found the video download from Appliance repair.com to be quite useful in understanding how to take off the front panel. We then saw that the basin under the drawer was indeed "flooded" per the F1 error code. When we dried the basin, the dishwasher returned to correct operation without F1 error code.
F1 fault shows flood switch activated, how to
Hello there
This is how i did mine
saved about 300 dollars
First thing I did was pull the front panel off the drawer, batch%2010-23-04%200031.jpg
Fisher Paykel DD602 dishdrawer with the front panel removed.
With that front panel off, I pulled the wire harness connectors off the main control board (lower right-hand side) to inspect for gookus. None found--my quest continued.
The next step to remove the botton drawer from the unit so I could inspect the flood switch. In order to do this, I had to remove the wire harness cover on the underside of the drawer. This is what the underside of the dishdrawer looks like with the botton cover panel removed:
Fisher Paykel DD602 dishdrawer, looking at the underside of one of the drawers with the wire cover plate removed.
With the bottom cover off, I could unclip the wire harness, fill hose, and drain hose. Then I unclipped the linkage at the back of the drawer and lifted the drawer off the slider arms. All this to expose the flood switch, shown on the left-hand side of the bottom panel in the picture below:.
Fisher Paykel DD602 dishdrawer with the lower drawer removed. The flood switch in mounted on the base, left hand side.
After noting the positions of the wires on the flood switch and removing them, I unclipped the switch housing from the base panel. The switch housing contains one switch for each drawer. The switches are wired normally closed (NC) and each switch has three spade connections, so it's important to note where the wires went. With the switch housing out, I could ohm out both switches and both checked good. I inspected the contacts and noticed that one of them was oxidized, evidenced by discoloration.
and clean off the contacts. That'll restore the current flow for that circuit. ." So I cleaned the contacts and reassembled the dishdrawer. I ran the top drawer and...no F1 error code! I ran it several more times just to be sure.
May 15, 2010 | Dishwashers
Fisher& paykel F1 Fault code
F1 means u have a leak on the machine somewhere. they leak from , lid, drain hose , lid activatiors, the leak has flood sensor to come on. to stop the F1 code u have to repair leak. please reply 4 more help.
Apr 25, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Its showing f1 error when machine is turned on
too have had this problem and looking at fixing it. I found a google cached thread on a different website that may assist you:
http://72.14.207.104/search?q=cache:B0R4JOEfwBAJ:serviceeveryday.com/forums/showthread.php%3Ft%3D124%26goto%3Dnextoldest+fisher+paykel+fault+code+reset&hl=en&gl=au&ct=clnk&cd=8
(copy and paste the entire line in your address bar)
Using the thread above, this is what I'll be trying tonight:
1. Check the drain hose and make sure there is no blockage. Also ensure the hose isn't raised too high as water might run back to the machine.
2. Check the port hole and make sure it's big enough for drainage. If not I'll be either bashing it or drilling it out to make it bigger.
3. Reset the machine by powering off the breaker for a few minutes. Turning the power off at the wall doesn't work.
4. Last option would be to use the advice from Fisher & Paykel themselves and leave the door ajar for 5-7 days.
I'll let you know how I go. Anyways, hoped I've helped and good luck!
Mar 15, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Hi Both drawers show error F1 flashing beeping with rinse light on and both pumps run after power is applied to machine
F1 error indicates flood switch in base has activated, meaning machine has leaked. This causes machine to drain continously, and can only be stopped by switching off power. Not easy to fix if you don't have experience- bottom drawer has to be removed to access flood switch, then machine needs to be test run and checked for leaks. Best to call the professionals!!
Oct 03, 2009 | Fisher and Paykel 23 in. DD603H SS...
Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
May 25, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
U3 fault code
http://d.scribd.com/docs/1nt2h7ei2nuuw9vihz41.pdf
Jan 16, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Fisher Paykel F1 error / double dishwasher drawer
F1-water on bottom of dishwasher. Uselly it cost by broken drain hose. Need expert tech to fix the problem.
Dec 01, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
300 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
