My LG Fuzzy Logic 7.5kg washing machine is stuck at 9 minutes left in the spin cycle however will not spin and does not turn itself off. I have turned off the machine and tried to get it to do only the spin cycle and I get the same result.
  • 77 Answers
SOURCE: LG Fuzzy Logic
it could be the sensor that detects that the lid is closed during every cycle.try hitting the lid when it stops it might work
Posted on Feb 12, 2008
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
  • 11 Answers
SOURCE: Bowl keeps slowly filling with water when turned off.
I think your water valve is bad , change it
Posted on Aug 12, 2009
  • 155 Answers
SOURCE: LG washing machine fuzzy logic 8.5 kg not agitating
The reason to this problem can be due to any one
of these reasons.
Lid Switch
Motor Coupler
Belts
Clutch
Drive Motor
Drive Pulleys
Transmission
Agitator
Posted on Sep 06, 2009
  • 4 Answers
Place a piece of magnetic material at the edge of the lid, for the wf-s6697tc model.
Standing in front of the washer, it is slightly off centre to the right (at the edge where the lid covers, space between the wording speedy soak & fuzzy). If you pay attention to the lid, you might notice some brownish rust stain.
This is where they place the magnet.
Posted on Sep 07, 2009
LG Fuzzy Logic 8.5 kg washing machine WF-T855A Turbo Drum I sensor will not fully spin, stops with 2 minutes to go till end and clothes are in a ball, not spun properly,never had a problem until now??
Unplug the machine over night and then plug it back in the morning. this should reset the internal cycle back to manufacturers specs.
This problem occurs because someone may have opened the door during operations and the onboard computer recognized and remembered this, so it is now part of the standard operating proceedure.
Nov 10, 2016 | LG Washing Machines
What causes my LG fuzzy logic fully automatic washing machine model WF-T1050TP does not do washing cycle but can spin during spin cycle
it appears the motor's sensors could be going bad on it so the diagnostic computer doesnt know what to do but spin the motor in a spin cycle contact LG for a replacement motor for this washer
Sep 11, 2016 | LG Washing Machines
Lg fuzzy logic washing machine
Sounds like it's stuck in rinse, try unplugging it for 5 mins then power up turn the selector to normal cycle and start, see what happens. There might be a reset cycle it has to do. Or a programming mode. LG 18002430000 customer service
May 15, 2014 | Washing Machines
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
I have an LG front loader, gets stuck on spin cycle at 9 min
The timer is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | LG Washing Machines
LG Fuzzy Logic won't spin
I had the same problem with my machine. so i just jammed the sensor that deactivates the machine when it starts spinning wildly. doing this allows the machine to work it just sounds like its going to blow up for the first two or three spins and then it sorts itself out.
Dec 04, 2008 | Washing Machines
LG FUZZY LOGIC
Are you sure it is the bowl and not inside the pump with the impellar hitting it on spin cycle? I just had the same problem and had to remove a dime from inside the pump.
Sep 22, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
