Question about Dishwashers
I recently tried to fix my ge potscrubber dishwasher that wasn't running, I pushed the fin portion of the motor that was stuck in place. The washer runs great but now leaks near the pump but only when the washer is on/draining.
    Master:
  • 414 Answers
This is a common problem with this pump. The only solution is to replace the pump
assembly. The price is between 75 and 100 dollars for the pump (usually).
This motor also had issues with the fins breaking off and becoming lodged
in the motor itself. The replacement is pretty straightforward but you must remove
the dishwasher from under the counter first. Hope this helps.
Posted on Mar 17, 2011
Dishwasher fills with water but won't run after that
Sounds like you have a bad (locked-up) motor. You MAY be able to unlock it. First, unplug your dishwasher. Then remove the toe-kick panel(s). I'm not sure of the model, but in most older GE dishwashers, you can see the back end of the motor facing the front of the DW. You should be able to see the cooling fins (fan blades, actually). Carefully, take a screwdriver and try pushing those fins to manually turn the motor. That may un-freeze the motor. But if you feel continued resistance as you try to turn the motor, or the fins keep "bouncing back", then the motor can't be freed up, and it will have to be replaced. Time to call a repairman (or depending on it's age, it might be better to go shopping for a new dishwasher).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 05, 2014 | GE Dishwashers
Ge potscrubber dishwasher #2230
try removing the bottom panel with washer off look for small fan on motor turn to make sure it is turning free. This happens a lot with the snowbirds in Fl. Simple fix.
May 15, 2014 | Dishwashers
I have the GE 206c1513p001 Potscrubber and recently found a black seal or rubber band in the dishwasher. Since then, it has been making a continuous clicking noise when it is run and does not clean the...
I have the exact same problem!!! Found 2 loose rubber bands, the bottom doesn't drain completely, and the dishes are left either dirty with a white film on them. Please help!
Oct 06, 2010 | GE Dishwashers
Ge potscrubber 650 Dishwasher is humming when turned on and will fill but not wash and drain
This happens when the DW goes unused for a while. The motor is stuck. Open up the lower panels and move the Motor Fan by hand until it moves freely. This worked for me until a seal broke.
Freeing the motor may break the seal between the motor and pump assembly. I'm in the process of replacing that now.
Check for leaks by running the DW before putting the lower panels back on.
Aug 14, 2010 | Dishwashers
Water not coming into dishwasher
Without knowing the model number of your GE dishwasher, but some dishwashers don't notice when the float / float switch is stuck. That could cause the dish washer to move through all the cycles but never have water flow into the dishwasher. That would be the first place I would look. But please post back here with what you find (plus the model number of your dishwasher) before ou rate me level of helpfulness, OK?
May 09, 2009 | Dishwashers
GE Potscrubber Dishwasher Stuck on Cycles
Could be a defective cycle timer
Jan 30, 2018 | GE Dishwashers
I have a GE Potscrubber dishwasher that only hums, won't run
I have a portable that had the same problem. I called a repairman and he turned a fan blade on the motor. Mine is located on the right side about 12" in. It gets hung up when it is run often enough. If your problem is the same is mine all you have to do is turn the blade and it works like a charm. Hope this helps.
Feb 18, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
GE potscrubber 700
upc leaks when dishwasher is emptying
May 12, 2008 | GE Dishwashers
Dishwashers Logo
163 people viewed this question
Top Dishwashers Experts
