Question about Motorola Mobility RAZR V3
White screen i got a few drops of water in my keypad so i took a hair dryer and dried it out...then i took my battery out of my phone and reset my phone.....i can do everything like make and receive calls....but when i flip open my phone, my screen stays white for about 5 seconds! What should I do? and i have a Motorola v3 razr
  • Anonymous Aug 07, 2008
    My screen chooses the when it will be all white or actually work. It is white when I need to use it and it works properly when I am trying to show someone how screwed up it is.
  • Anonymous Sep 03, 2008
    when i turn on my phone it makes the cingular sound and it stays white but i can make and recieve calls.
    Novelist:
  • 152 Answers
May be some water get into the phone.Yo need to temove all moisture trapped in the phone: Dry the phone, battery, any accessory, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
Posted on May 21, 2010
Yesterday, I was texting my boyfriend... I was in the bath tub, but I was drying my hands off onto a towel... I didn't think much of it, because my phone has been dropped into the dogs water bowl by...
Try this :
Bring a hair dryer ,then remove your battery and sim card,then turn the hair dryer on (the hot air)
make the hair dryer focus on the phone from the battery side becuase there are some holes wich the
hot air can get inside the mobile and dry the mobile hard ware.
Make the hair dryer focus on the mobile for 5 minutes but be careful and make a distance between
the hair dryer and between the mobile to avoid damage the plastic mobile case becuase of hot air.
After five minutes turn the hair dryer off and wait until the mobile gets cold,then turn it on
This way is effective 50% to 90 %
If your mobile worked that means congratulations.
If it worked but not 100% that means there is improvement and keep drying it by the hair dryer as
i explained before,,,every dry for 5 minutes only.
But if it doesnt work at all ...that means your mobile needs a hardware repair and you have to send
it to a mobile repair store.
Jun 03, 2011 | Cell Phones
Maybe rzr v3m; black screen after dropping phonein water
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Apr 29, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Instrument got wet
I had the same problem with my slvr.I removed the battery and took a hair dryer adnspent many hours slowly drying phone.Been working for two years now!
Feb 02, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Dropped phone in water
no much. probably it already has a short internal.
you can open the pone and try to use a hair dryer to dry out the phone, but I don't think that is going help.
Nov 07, 2008 | LG enV VX9900 Cellular Phone
Dropped my LG Scoop in water. It turns on but when I try to dial a number it pulls up a screen or types in wrong number, etc. I can make calls from my contact list. I can't get to voicemail because,...
Hi , if you can , open the battery compartment and remove the battery . then use a hair dryer or other heating device to completely dry the inside area of the phone as well as the battery , then reassemble the phone and it should work . Hope this helps
Sep 15, 2008 | Cell Phones
I have an Telus LG 210 phone and got it wet, and when i turn it on all i get is the LG letters and the symbol beside it and the phone never starts up. It just keeps shutting off and turning back on at...
Normally the extent of the problem will depend on the amount of water seepage. I don't know the details of this particular phone but in general it is the moisture trapped under the keypad that can cause the problem. If you can open the keypad and run a hair dryer on low heat across for a few minutes that might help. It is also possilble the battery is discharged because of the drain of current due to water causing internal short circuits. Take out the battery, dry off the phone with hair dryer and put the battery in. Connect the charger and hope for the best. By the way I am not a phone technician.
Jul 27, 2008 | Lands Phones
Sidekick 3 dropped in a cup of water. Water got into screen.
Is the screen blank all the time?
If you look really hard can you see the items on the screen but they are really dark? If so the back light for the lcd may have burned out.
Take a look at the following site for instructions on disassembly.
http://www.gsfx.org/disassembly/index.htm
If you feel comfortable with it, you can easily replace your own.
A new lcd runs about 50 dollars shipped. If you buy it from ebay, they will usually come with instructions and the screwdriver you need. A T6 torx driver is the type needed.
Sidekick LCD screens
Good job on drying it out and pulling the battery. Thats the best thing you can do when you get it wet!
Jan 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone will not turn on
ok, take out the battery and look and see you can see a white dot pice of circular paper, if it is red, your phone somehow got water in it, look at your battery(white dot paper) if it is red than you have water in you phone. now you need to dry it! leave it on your car dast board in the sun 24hrs or use a hair dryer ( use low heat) you must dry your phone and battery completely before the next step, Next step- find a good working battery and insert it in your phone, see if this will correct your problem, sometime the battery volt are very low or maybe the battery itself its bad, but make sure you put in a new battery to test this out, don't pay for the battery until you check you phone at the counter, ask for the right model for you phone.
good luck
z
Nov 30, 2007 | LG CHOCOLATE VX8500 Cellular Phone
It was soaked with lake water
you need to have the phone fully service take the phone to a mobile service center and have them service it for you.
Aug 27, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
74 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
