Question about Cycling
I have an FS507 electric start/gas running,made in china scooter that wont start. theres gas to the carberator,all wires in tact,sparkplug imits spark,so,what did i miss?
  • 6 Answers
SOURCE: gas SUNL 150cc-26 scooter major probs
the hose and screw you are talking about is for draining the carb for winter or maintance screw the adjustment screw on carb all the way in then screw it back out 1 and a half turns if dont start turn the screw out a half turn each time
Posted on Nov 11, 2008
SOURCE: 50cc Two Stroke Scooter Engine - Poor Idle
I had the same problem- from out of nowhere the scooter started dying at every stop. I adjusted the idle screw to 2000 and it still idled up and down. I bought some injector cleaner but this will take a while to work (several tanks of gas) and then found this link- seems to be a very simple thing to do once you read this link. I hope it helps. --
Posted on May 19, 2009
  • 12 Answers
SOURCE: I've just had the same problem
check the fuel cap for a vent it needs to be vented . the air displaces the fuel no vent on fuel try running with the cap off . if it runs the vent was clogged or the wrong gas cap
Posted on Aug 09, 2009
Testimonial: "The cap was clogged. Thanks for your Help"
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
hunter19_46m
  • 7482 Answers
SOURCE: have a bolens weedeater with a walbro
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Need repair or parts manual for a Na Za scooter ithink its a 50cc? i think its made in china?
Look on the engine most to all china made scooter's have these engine's (136qmb)(gy6) and other variants of these motor's for wire's they follow the frame once you take a good look where every thing goes I recommend finding the CDI it's a little box with about 6-8 wire's plugged into it this is the brain of you're scooter if you want part's just search (50cc chinese scooter parts) and most if not all the part's will fit you're motor.
Oct 23, 2017 | Sport & Outdoor - Others
Bad gas in yamaha c3 scooter
Pull the carberator off and clean it out at least drop the float bowl clean out make sure float and needle and seat are free if still won't run have to carb all apart
Jun 12, 2013 | Motorcycles
I just cleaned the carberator and new sparkplug it sounds like it not getting fuel when i put alittle gas in the carberator it starts and obviously stops? on my craftmen weedeater
if it is an older one, the gas lines like to rot away. you can usually tell by looking down inside the gas tank. you can also check to see if the primer is moving the fuel through the lines as you prime it
Jul 07, 2011 | Craftsman 25cc Gas Line Trimmer
Hello there i have problem this evening to start the engine of my scooter the model is pgo g-max125
NOT SURE OF THIS MODEL ,BUT WHAT I HAVE RUN INTO IS THE ELECTRIC CHOKES ON THESE CHINESE BRANDS.FIND YOUR CARBERATOR AND LOOK FOR A CHOKE TYPE SETUP ON THE TOP OR THE SIDE OF CARB.UNSCREW IT AND PULL IT OUT WITH THE GAS OFF,TURN YOUR KEY ON AND WAIT A MINUTE TO SEE IF IT MOVES,IF IT DOES MOVE IT SHOULD BE FINE IF NOT AND THERE IS 2 WIRES GOING TO IT DISCONNECT ANDDO A BEEP TEST,TAKE A VOLT METER ON BEEP SETTING ,HAS A LITTLE HORN SYMBLE,PUT A LEAD IN 1 CONNECTER AND 1 IN THE OTHER,DOESNT MATTER POS,OR NEG,IF IT BEEPS ITS GOOD IF IT DONT ITS BAD,THAT IS A EASY WAY TO TEST ANYTHING ELECTRICAL FOR CONTINUETY,NOT SURE HOW TO SPELL THAT.IF ALL THAT TEST FINE GET YOUR CARB CLEANED AND OR YOUR VALVES SET IF IT IS A 4 STROKE.ALSO THEY HAVE A COMMON KEYSWITCH PROBLEM,ACCUALLY ALL ELECTRICAL ITEMS.WHEN I NEED PARTS FOR THEM I JUST TYPE IN CHINEASE SCOOTER PARTS UNDER BING SEARCH.-HOPE I WAS OF SOME HELP
Apr 15, 2011 | Suzuki RGV 150 Megatone Motorcycles
1963 allstate 125 scooter will run like new than it won,t start even thought it's getting spark and gas
Hi! I assume your problem only applies when the engine is hot. This could be one of several things:
1 - bad seals 2 - broken engine body (heat expands it and lets air in / compression out) 3 - related to above, but happening on top end (cylinder/head)
All these are hard to fix at home, but there it could also be related to a carb problem... imagine your scooter is running too rich, it will run ok for the first kms, but after you stop and because the plug is dirty and/or the engine is flooded, it wont start anymore.
When this happened did you check the sparkplug look (is it dark? dry or oily?)
Hope this helps! Regards
Feb 08, 2011 | Peg Perego Vespa Scooter
My china phone is block
hey dude, ur using a china phone? anyway, there are 2 kinds of china phone, there's the authentic one and there's the imitation. the imitation really sucks coz its not guaranteed to last a long time. they are poor in quality and they easily breaks. why not get yourself a better one by purchasing the authentic coz they may be expensive but its worth all your effort. thanx!!!
Aug 18, 2010 | Cell Phones
I have a 4 stroke Chinese scooter. The engine is ...
an engine needs three things to run. Fuel, a spark at the right time and compression. Check your compression with a gauge. Check the ignition timing. Check for a big fat blue spark.
May 14, 2017 | Motorcycles
I have a sym 50 scooter that will not start there does not seem to be a spark from the spark plug have you any ideas. thanks M.Murphy
If you are sure that there is no spark from the sparkplug please clean the tip of the central and side electrodes to remove the carbon deposits and make sure that there is a sufficient gap between them.Also check for the electrical wire connections to the sparkplug and make sure that the battery is working properly.
Mar 21, 2010 | 2004 Factory bike Chrono SM 250
Problems starting G-Scooter
Initially and based on your description that it has not been used for some time, pls try:
  • check the sparkplug, clean, replace, verify spark;
  • verify any loose connection, wiring;
  • replace/drain stale gas;
  • if it is a two stroke engine, you may need to check that the 2T oil has not seeped to the bottom of the combustion chamber;
  • check/clean the carburetor;
  • verify that when you pull the starter cord, there is counter force; is it engaging the engine. This could be verified by removing the sparkplug and making sure the plug cap/wire is safely kept back, crank the engine (pull the starter cord) while keeping a finger covering the now empty sparkplug hole. If the starter cord is engaging the engine and there is sufficient compression, there would be tremendous pressure exerting on your finger.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | 2004 Factory bike Chrono SM 250
Cycling Logo
54 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
