Question about Car Audio & Video
Hi my pioneer AVH-P5750 screen has no picture it is just black but when i push it the noise sound as normal
  • 1 more comment
  • eric435 Mar 17, 2011
    my screen on my pioneer ahv-p5750dvd stays black when i turn it on when i touch tje screen it makes noises as usual my car was putting 24 volts through everything then the screen went dull then went black
  • eric435 Mar 18, 2011
    cheers great help
    great help told me eveything i could do awesome
  • 1,940 Answers
  1. First, you could try resetting the AVH-P5750. With the ignition switch Off, press the Reset button on the Right side of the device, above the Navigation Arrows. If you use Pioneer Vehicle Dynamics Processor, be sure ACC OFF is selected before you RESET to avoid further problems.
  2. To perform a Factory Reset, press the Reset button with the ignition to ACC ON.
  3. Check to make sure your Parking Brake wire is connected properly.
  4. If none of the above fix the problem, you may have a faulty LCD screen, cable, or board. It is recommended to not disassemble or modify this unit, as there are high-voltage components inside which may cause an electric shock. Consult your dealer or the nearest authorized Pioneer Service Station for internal inspection, adjustments or repairs.
  5. If you can find a spare AVH-P5750, you could try and swap parts to make a working AVH-P5750. I don't think Pioneer sells parts for this device, but you can contact them directly to find out: http://www.pioneerelectronics.com/PUSA/Support
  6. Here is your manual: http://www.pioneer-latin.com/downloads/crb2055a.pdf
Posted on Mar 18, 2011
    Genius:
  • 1,622 Answers
Hi, first hope you connected it properly?..troubleshoot all cables and see what happens..
Below iis how you can connect pioneer AVH-P5750 properly..
Instruction:
How to Install a pioneer AVH-P5750
The pioneer AVH-P5750 DVD is an in-dash aftermarket car stereo featuring a CD/DVD player, touch screen, 6.5-inch display and an iPod connection. The screen enables car owners to watch DVD movies in their car when parked. The connection of the wiring during installation is crucial to ensure that the unit works correctly with all of the car appliances and controls, such as the parking brake and mobile phone.
things you'll need:
* Adjustable wrench
* Face plate adapter
* Wire harness adapter
Disconnect the negative battery terminal of the car battery, using an adjustable wrench.
Prepare the dashboard housing of the car. Slide the radio installation sleeve provided with the AVH-P5750 DVD into the dashboard housing. Bend the tabs on the sleeve to secure it in place. Attach any necessary installation kits for the vehicle.
Connect the wire harness. This contains the power connection and the wires enabling the stereo to work with the car functions, such as reverse indicator, parking break and mobile phone connection. Ensure these connections are wired into the car's harness. Connect the wire harness to the wire harness adapter. Push the connections together until they click into place. Connect the other end of the wire harness adapter to the wire harness of the stereo. Plug in the black radio antenna cable to the radio antenna port on the rear-right side of the stereo (Some cars, such as those by General Motors, require an antenna adapter).
Slide the stereo into the dashboard housing until it clicks into the installation sleeve. Reconnect the car battery. Turn on the stereo to test the installation. Make sure that the DVD screen works only in park mode, and check the other features of the stereo.
Tips & Warnings
The Pioneer AVH-P5750 DVD will only work with cars that have an ACC position on the ignition switch.
You can also use the Video below:
http://www.youtube.com/watch?v=exIWp_7v63s
Take care...
Posted on Mar 17, 2011
STUCK ON BLACK SCREEN SAYING OBJECTS MAY BE IN REVERSE TRYED RESETTING STILL THE SAME UNHOOKED VIOLET WIRE STILL THE SAME
I have a Pioneer AVH-P4900, I bought the video bypass for mine, once I did that I had the same problem. I tried pressing buttons, and the V.Adj button returned the screen back to my normal screen playing my disc. It might happen again, but I think it's it's way of a "screensaver ". Hope this helps to patch this up for ya.
Jul 10, 2015 | Pioneer AVH-4100NEX 2-DIN Multimedia DVD...
Pioneer avh p5750 screen wont close
look for a small reset button behind face. or unplug the unit, wait 30 seconds and reconnect.
a simple reset should do the trick.
Nov 22, 2012 | Pioneer AVH-P6500DVD Car DVD Player
Hi, In my Pioneer Avh-P3100Dvd' s screens appear
hi boss my nokia 3230 do restsrt & hanging problam
Mar 01, 2010 | Pioneer AVIC-D3 Car DVD Player
Movie plays but screen is black
insert external AGP card in the cpu because internal display card does not suppot to picture or movie the other problems will also automatically solved
Feb 28, 2010 | Pioneer AVH-P4000DVD Monitor
No picture after bypass of pioneer AVH-P4000DVD
remove the toggle switch and pray you didnt do damage to your delicate stereo system
Sep 27, 2009 | Pioneer AVH-P4000DVD Monitor
I have a pioneer AVH-P4000dvd 2 din in dash dvd player. I hooked it up right, I did not do the by-pass, I hooked it up to the e-brake. When I play a dvd I get audio but no video. I have full control of the...
push in the driving brake. while holding in the brake , engage the parking brake. disengage the parking brake.then repeat this step again. a notice should pop up and you should be fine after that. I put one in a F-350 and had the same problem.
Jun 27, 2009 | Pioneer AVH-P4000DVD Monitor
No pics on avh-p4000
Right after I send my problem with my p4000, I found what's where wrong... I forgot the little black wire ground. I simply put wires togheter (the big on and the small) and now, it works !!! I can see pictures and sound from DVD and listen music with USB flash drive...
Hope this will help you...
Phil
Jun 13, 2009 | Pioneer AVH-P4000DVD Monitor
Pioneer avh 5700
i would suggest re doing all the wiring. you may have blown an ic chip inside the unit. if so you will need to get unit repaired
Sep 05, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Black screen
hi there,
try to check if your using pal or ntsc...try adjusting the video output and you'll probably get the picture eventually.
hope this helps.
fixya!
Jan 30, 2008 | Pioneer Car DVD AVH-P6600DVD Car Video...
Car Audio & Video Logo
222 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
