My dell works only with battery ,not work with adapter ac,not charche battery ,i have to charce batery on other laptop and then i put in my laptop then work otherwise not work i try other ac adapter result is same,please help
    Master:
  • 325 Answers
Sounds like your socket is damaged a very common problem
read socket damage at the bottom of this page
http://www.2pages.co.uk/laptops.html
Posted on Mar 17, 2011
I have an m5310 and i have troubles with the battery charge i bought a new battery but is still the same , i plug the notebook to the ac power and batery start to load (the front green light is on ) after...
Try to perform power drain on the motherboard.
heres the steps:
take out the battery
unplug the power adapter
press and hold power button for 30secs
put the battery back in
plug in the power adapter
power on the computer
if same issue will happen then you need a battery replacement.
May 21, 2010 | E-Machines M5310 PC Notebook
Dell latitude 400 charging problem
Your english is actually above average!
For you to get the best solution to this problem, I'll suggest that you should just try and get a friend, or a technician that has a charger of the same type, i.e a Dell Laptop Charger, to test it with. Now, if it still doesnt work, then you can try and swap the Battery with a working one also. All these are just to clarify things for you and to teach you the easiest way of troubleshooting it yourself.
Then If the new charger charges it, it means you just have to get a new charger, and if the Battery swapping is the one that works, then you might have to get a new battery too.
At the same time also try this quick solution :
Remove the battery from the back of your laptop, and power the laptop without the battery inside. If it works this way, then just try and get a new battery instead.
Hope this helps you out!
Goodluck
Jul 13, 2009 | Dell Latitude D400 Notebook
My dell vostro 1000 laptop's display aint working. The screen remains black. Even the battery light doesnt glows. Only the power light comes on. Please help.
hi,
try these two things if both don't work you should call dell tech support
1) take out the battery and the ac adapter and then push and hold down the power button for 15 seconds, this releases flea power in the laptop and makes it work sometimes
if it didn't work
2) take out the battery and put in the AC adapter and try to start your laptop on AC adapter alone, if it starts that means either your battery or *********** board is bad, you can check if the battery is bad by replacing it with a new battery and if it works with new battery that means the old battery was bad but if it only works without battery with ac adapter and new battery also didn't work, that means motherboard is bad, Call dell tech support
If you think the info given by me was helpfull please do rate me
Regards
Ltoso
Jul 07, 2009 | Computers & Internet
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Brand new dell inspiron 1545 says it is the wrong charger but it is the wright one battery will not charge but will run from ac adaptor
take another adapter , same type you have it and prove is working or not?
if yes meaning that output current in your adapter is wrong it is defektive , and change, if even second adapter is making same thing try to get another model adpter that is close in power and curent ratin with yours or same, if isnt working this too try another batery because maybe is finished, if even new batery dont work with your adapter or a second adapter you have to service your laptop inside in electric circuit entering is blown out.
Apr 04, 2009 | Dell Dimension 8400 power supply ** FREE...
Dell Inspiron will not work on Battery.
At the very minimum its your battery. The other side is that it could be your power utility inside your laptop. Lets try getting a new battery first.
Note: Try a different AC outlet first.
Mar 12, 2009 | Dell Inspiron 1525 Notebook
Replacement adapter will not charge battery
Did the old one do the same thing? If true, your battery sounds like it is dead.
Jan 17, 2009 | Dell Inspiron 1501 Notebook
Dell latidue D610
The light indicator for the battery is; green-charging, yellow-battery failure, and red-charging system failure. The charging system failure happens when the power management chip fails. The pm chip regulates and controls the power input & usage, allows the machine to switch from AC to battery, and cotrols the charging. This will also cause the problem with the power button not workin or being hard to start. Unfortunately, the motherboard will have to be replaced in order to fix this.
Jul 26, 2008 | Dell (F2273) Motherboard
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Unable to charge my battery on Dell 510m
can you plzz be more specific , you have an issue with the batery charging , but you are able to turn the system on with the AC adapter connected to the laptop.
you can try updating the BIOS of your computer from the website support.dell.com also restore defaults in the system setup...
Apr 30, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
